2021-02-21 23:53 »
Some of the languages below may be missing some files, such as the ie.txt and ieak stuff, but AS FAR AS I KNOW, nothing is missing that should prevent the installer (ie5setup.exe) from running and installing on any compatible OS. Note to '!', if you feel that this should be moved to 'Operating Systems', feel free.
Pay attention! All files for the chosen language need to be saved in the same folder. Two files need to be created and added to the same folder, this can be done in Notepad. MAKE CERTAIN THE FILES PROPER EXTENSION (DAT and INI).
FILELIST.DAT:
[General]
Version=1
IESETUP.INI:
[Version]
Signature="Active setup"
[Options]
IELiteMode=0
ConfirmFileList=0
Shell_Integration=1
ProductID="71929-932-2000023-12347"
LocalInstall=1
Regarding the line 'Shell_Integration=1', if installing on 95 (at least retail, not sure about OSR 2 or 2.5) you can change the line to 'Shell_Integration=0' to not have Shell Integration.
I'll add code for a batch script that creates the two files above at the end for those preferring not to do it by hand in Notepad. AGAIN, save all the files for the language you choose (including the two above) in the same folder! I recommend right-clicking the links and choosing Save File/Target As...to ensure your saving all files to the same folder.
ENU:
http://www.download.windowsupdate.com/m ... TSETUP.CAB
http://www.download.windowsupdate.com/m ... DVAUTH.CAB
http://www.download.windowsupdate.com/m ... OLSUPP.CAB
http://www.download.windowsupdate.com/m ... en/AXA.CAB
http://www.download.windowsupdate.com/m ... n/AXA2.CAB
http://www.download.windowsupdate.com/m ... n/AXA3.CAB
http://www.download.windowsupdate.com/m ... ANDING.CAB
http://www.download.windowsupdate.com/m ... DCOM95.EXE
http://www.download.windowsupdate.com/m ... DXDDEX.CAB
http://www.download.windowsupdate.com/m ... DXMINI.CAB
http://www.download.windowsupdate.com/m ... NTCORE.CAB
http://www.download.windowsupdate.com/m ... ONTSUP.CAB
http://www.download.windowsupdate.com/m ... ESETUP.CAB
http://www.download.windowsupdate.com/m ... ETUP95.CAB
http://www.download.windowsupdate.com/m ... ETUPNT.CAB
http://www.download.windowsupdate.com/m ... LPCONT.CAB
http://www.download.windowsupdate.com/m ... /HHUPD.CAB
http://www.download.windowsupdate.com/m ... en/ICW.CAB
http://www.download.windowsupdate.com/m ... ICWCON.CAB
http://www.download.windowsupdate.com/m ... _EXTRA.CAB
http://www.download.windowsupdate.com/m ... /IE_S1.CAB
http://www.download.windowsupdate.com/m ... /IE_S2.CAB
http://www.download.windowsupdate.com/m ... /IE_S3.CAB
http://www.download.windowsupdate.com/m ... /IE_S4.CAB
http://www.download.windowsupdate.com/m ... 4MFC40.CAB
http://www.download.windowsupdate.com/m ... 4SHL95.CAB
http://www.download.windowsupdate.com/m ... 4SHLNT.CAB
http://www.download.windowsupdate.com/m ... E5COMP.EXE
http://www.download.windowsupdate.com/m ... IE5OEM.EXE
http://www.download.windowsupdate.com/m ... 5setup.exe
http://www.download.windowsupdate.com/m ... /IEAK5.EXE
http://www.download.windowsupdate.com/m ... EAK5CD.EXE
http://www.download.windowsupdate.com/m ... AK5OPT.CAB
http://www.download.windowsupdate.com/m ... /iecif.cab
http://www.download.windowsupdate.com/m ... IEDATA.CAB
http://www.download.windowsupdate.com/m ... DATAJA.CAB
http://www.download.windowsupdate.com/m ... /IEDOM.CAB
http://www.download.windowsupdate.com/m ... n/IEDW.EXE
http://www.download.windowsupdate.com/m ... IEJAVA.CAB
http://www.download.windowsupdate.com/m ... ELPKAD.CAB
http://www.download.windowsupdate.com/m ... ELPKAR.CAB
http://www.download.windowsupdate.com/m ... ELPKIW.CAB
http://www.download.windowsupdate.com/m ... ELPKJA.CAB
http://www.download.windowsupdate.com/m ... ELPKKO.CAB
http://www.download.windowsupdate.com/m ... ELPKPE.CAB
http://www.download.windowsupdate.com/m ... ELPKTH.CAB
http://www.download.windowsupdate.com/m ... ELPKVI.CAB
http://www.download.windowsupdate.com/m ... LPKZHC.CAB
http://www.download.windowsupdate.com/m ... LPKZHT.CAB
http://www.download.windowsupdate.com/m ... ENT_S1.CAB
http://www.download.windowsupdate.com/m ... ENT_S2.CAB
http://www.download.windowsupdate.com/m ... ENT_S3.CAB
http://www.download.windowsupdate.com/m ... ENT_S4.CAB
http://www.download.windowsupdate.com/m ... EW2K_1.CAB
http://www.download.windowsupdate.com/m ... EW2K_2.CAB
http://www.download.windowsupdate.com/m ... EW2K_3.CAB
http://www.download.windowsupdate.com/m ... JAAIME.CAB
http://www.download.windowsupdate.com/m ... KOAIME.CAB
http://www.download.windowsupdate.com/m ... ILNEWS.CAB
http://www.download.windowsupdate.com/m ... AC_IE5.CAB
http://www.download.windowsupdate.com/m ... EWSW2K.CAB
http://www.download.windowsupdate.com/m ... BILE95.CAB
http://www.download.windowsupdate.com/m ... BILENT.CAB
http://www.download.windowsupdate.com/m ... MPCDCS.CAB
http://www.download.windowsupdate.com/m ... LAYER2.CAB
http://www.download.windowsupdate.com/m ... N_AUTH.CAB
http://www.download.windowsupdate.com/m ... OAINST.EXE
http://www.download.windowsupdate.com/m ... README.CAB
http://www.download.windowsupdate.com/m ... SCAIME.CAB
http://www.download.windowsupdate.com/m ... TUPW95.CAB
http://www.download.windowsupdate.com/m ... /SWDIR.CAB
http://www.download.windowsupdate.com/m ... WFLASH.CAB
http://www.download.windowsupdate.com/m ... TCAIME.CAB
http://www.download.windowsupdate.com/m ... n/TS95.CAB
http://www.download.windowsupdate.com/m ... n/TSNT.CAB
http://www.download.windowsupdate.com/m ... /USP10.CAB
http://www.download.windowsupdate.com/m ... SCRIPT.CAB
http://www.download.windowsupdate.com/m ... en/VGX.CAB
http://www.download.windowsupdate.com/m ... X86_01.CAB
http://www.download.windowsupdate.com/m ... X86_02.CAB
http://www.download.windowsupdate.com/m ... VRML2C.EXE
http://www.download.windowsupdate.com/m ... en/WAB.CAB
http://www.download.windowsupdate.com/m ... WABW2K.CAB
http://www.download.windowsupdate.com/m ... BFLDRS.CAB
http://www.download.windowsupdate.com/m ... IE5X86.CAB
ARA:
http://www.download.windowsupdate.com/m ... ar/AXA.CAB
http://www.download.windowsupdate.com/m ... r/AXA2.CAB
http://www.download.windowsupdate.com/m ... r/AXA3.CAB
http://www.download.windowsupdate.com/m ... ar/ICW.CAB
http://www.download.windowsupdate.com/m ... r/IEDW.EXE
http://www.download.windowsupdate.com/m ... r/TS95.CAB
http://www.download.windowsupdate.com/m ... r/TSNT.CAB
http://www.download.windowsupdate.com/m ... ar/VGX.CAB
http://www.download.windowsupdate.com/m ... ar/WAB.CAB
CHS:
http://www.download.windowsupdate.com/m ... cn/AXA.CAB
http://www.download.windowsupdate.com/m ... cn/ICW.CAB
http://www.download.windowsupdate.com/m ... cn/VGX.CAB
http://www.download.windowsupdate.com/m ... cn/WAB.CAB
CHT:
http://www.download.windowsupdate.com/m ... tw/AXA.CAB
http://www.download.windowsupdate.com/m ... w/AXA2.CAB
http://www.download.windowsupdate.com/m ... w/AXA3.CAB
http://www.download.windowsupdate.com/m ... tw/ICW.CAB
http://www.download.windowsupdate.com/m ... w/IEDW.EXE
http://www.download.windowsupdate.com/m ... w/TS95.CAB
http://www.download.windowsupdate.com/m ... w/TSNT.CAB
http://www.download.windowsupdate.com/m ... tw/VGX.CAB
http://www.download.windowsupdate.com/m ... tw/WAB.CAB
CSY:
http://www.download.windowsupdate.com/m ... cs/AXA.CAB
http://www.download.windowsupdate.com/m ... s/AXA2.CAB
http://www.download.windowsupdate.com/m ... s/AXA3.CAB
http://www.download.windowsupdate.com/m ... cs/ICW.CAB
http://www.download.windowsupdate.com/m ... s/IEDW.EXE
http://www.download.windowsupdate.com/m ... s/TS95.CAB
http://www.download.windowsupdate.com/m ... s/TSNT.CAB
http://www.download.windowsupdate.com/m ... cs/VGX.CAB
http://www.download.windowsupdate.com/m ... cs/WAB.CAB
DAN:
http://www.download.windowsupdate.com/m ... da/AXA.CAB
http://www.download.windowsupdate.com/m ... a/AXA2.CAB
http://www.download.windowsupdate.com/m ... a/AXA3.CAB
http://www.download.windowsupdate.com/m ... da/ICW.CAB
http://www.download.windowsupdate.com/m ... a/IEDW.EXE
http://www.download.windowsupdate.com/m ... a/TS95.CAB
http://www.download.windowsupdate.com/m ... a/TSNT.CAB
http://www.download.windowsupdate.com/m ... da/VGX.CAB
http://www.download.windowsupdate.com/m ... da/WAB.CAB
DEU:
http://www.download.windowsupdate.com/m ... de/AXA.CAB
http://www.download.windowsupdate.com/m ... e/AXA2.CAB
http://www.download.windowsupdate.com/m ... e/AXA3.CAB
http://www.download.windowsupdate.com/m ... de/ICW.CAB
http://www.download.windowsupdate.com/m ... e/IEDW.EXE
http://www.download.windowsupdate.com/m ... e/TS95.CAB
http://www.download.windowsupdate.com/m ... e/TSNT.CAB
http://www.download.windowsupdate.com/m ... de/VGX.CAB
http://www.download.windowsupdate.com/m ... de/WAB.CAB
ELL:
http://www.download.windowsupdate.com/m ... el/AXA.CAB
http://www.download.windowsupdate.com/m ... l/AXA2.CAB
http://www.download.windowsupdate.com/m ... l/AXA3.CAB
http://www.download.windowsupdate.com/m ... el/ICW.CAB
http://www.download.windowsupdate.com/m ... l/IEDW.EXE
http://www.download.windowsupdate.com/m ... l/TS95.CAB
http://www.download.windowsupdate.com/m ... l/TSNT.CAB
http://www.download.windowsupdate.com/m ... el/VGX.CAB
http://www.download.windowsupdate.com/m ... el/WAB.CAB
ESN:
http://www.download.windowsupdate.com/m ... es/AXA.CAB
http://www.download.windowsupdate.com/m ... es/ICW.CAB
http://www.download.windowsupdate.com/m ... es/VGX.CAB
http://www.download.windowsupdate.com/m ... es/WAB.CAB
FIN:
http://www.download.windowsupdate.com/m ... fi/AXA.CAB
http://www.download.windowsupdate.com/m ... i/AXA2.CAB
http://www.download.windowsupdate.com/m ... i/AXA3.CAB
http://www.download.windowsupdate.com/m ... fi/ICW.CAB
http://www.download.windowsupdate.com/m ... i/IEDW.EXE
http://www.download.windowsupdate.com/m ... i/TS95.CAB
http://www.download.windowsupdate.com/m ... i/TSNT.CAB
http://www.download.windowsupdate.com/m ... fi/VGX.CAB
http://www.download.windowsupdate.com/m ... fi/WAB.CAB
FRA:
http://www.download.windowsupdate.com/m ... fr/AXA.CAB
http://www.download.windowsupdate.com/m ... fr/ICW.CAB
http://www.download.windowsupdate.com/m ... fr/VGX.CAB
http://www.download.windowsupdate.com/m ... fr/WAB.CAB
HEB:
http://www.download.windowsupdate.com/m ... he/AXA.CAB
http://www.download.windowsupdate.com/m ... he/ICW.CAB
http://www.download.windowsupdate.com/m ... he/VGX.CAB
http://www.download.windowsupdate.com/m ... he/WAB.CAB
HUN:
http://www.download.windowsupdate.com/m ... hu/AXA.CAB
http://www.download.windowsupdate.com/m ... u/AXA2.CAB
http://www.download.windowsupdate.com/m ... u/AXA3.CAB
http://www.download.windowsupdate.com/m ... hu/ICW.CAB
http://www.download.windowsupdate.com/m ... u/IEDW.EXE
http://www.download.windowsupdate.com/m ... u/TS95.CAB
http://www.download.windowsupdate.com/m ... u/TSNT.CAB
http://www.download.windowsupdate.com/m ... hu/VGX.CAB
http://www.download.windowsupdate.com/m ... hu/WAB.CAB
ITA:
http://www.download.windowsupdate.com/m ... it/AXA.CAB
http://www.download.windowsupdate.com/m ... t/AXA2.CAB
http://www.download.windowsupdate.com/m ... t/AXA3.CAB
http://www.download.windowsupdate.com/m ... it/ICW.CAB
http://www.download.windowsupdate.com/m ... t/IEDW.EXE
http://www.download.windowsupdate.com/m ... t/TS95.CAB
http://www.download.windowsupdate.com/m ... t/TSNT.CAB
http://www.download.windowsupdate.com/m ... it/VGX.CAB
http://www.download.windowsupdate.com/m ... it/WAB.CAB
JPN:
http://www.download.windowsupdate.com/m ... ja/AXA.CAB
http://www.download.windowsupdate.com/m ... ja/ICW.CAB
http://www.download.windowsupdate.com/m ... ja/VGX.CAB
http://www.download.windowsupdate.com/m ... ja/WAB.CAB
KOR:
http://www.download.windowsupdate.com/m ... ko/AXA.CAB
http://www.download.windowsupdate.com/m ... o/AXA2.CAB
http://www.download.windowsupdate.com/m ... o/AXA3.CAB
http://www.download.windowsupdate.com/m ... ko/ICW.CAB
http://www.download.windowsupdate.com/m ... o/IEDW.EXE
http://www.download.windowsupdate.com/m ... o/TS95.CAB
http://www.download.windowsupdate.com/m ... o/TSNT.CAB
http://www.download.windowsupdate.com/m ... ko/VGX.CAB
http://www.download.windowsupdate.com/m ... ko/WAB.CAB
NLD:
http://www.download.windowsupdate.com/m ... nl/AXA.CAB
http://www.download.windowsupdate.com/m ... nl/ICW.CAB
http://www.download.windowsupdate.com/m ... nl/VGX.CAB
http://www.download.windowsupdate.com/m ... nl/WAB.CAB
NOR:
http://www.download.windowsupdate.com/m ... no/AXA.CAB
http://www.download.windowsupdate.com/m ... no/ICW.CAB
http://www.download.windowsupdate.com/m ... no/VGX.CAB
http://www.download.windowsupdate.com/m ... no/WAB.CAB
PLK:
http://www.download.windowsupdate.com/m ... pl/AXA.CAB
http://www.download.windowsupdate.com/m ... pl/ICW.CAB
http://www.download.windowsupdate.com/m ... pl/VGX.CAB
http://www.download.windowsupdate.com/m ... pl/WAB.CAB
PTB:
http://www.download.windowsupdate.com/m ... br/AXA.CAB
http://www.download.windowsupdate.com/m ... br/ICW.CAB
http://www.download.windowsupdate.com/m ... br/VGX.CAB
http://www.download.windowsupdate.com/m ... br/WAB.CAB
PTG:
http://www.download.windowsupdate.com/m ... pt/AXA.CAB
http://www.download.windowsupdate.com/m ... pt/ICW.CAB
http://www.download.windowsupdate.com/m ... pt/VGX.CAB
http://www.download.windowsupdate.com/m ... pt/WAB.CAB
RUS:
http://www.download.windowsupdate.com/m ... ru/AXA.CAB
http://www.download.windowsupdate.com/m ... ru/ICW.CAB
http://www.download.windowsupdate.com/m ... ru/VGX.CAB
http://www.download.windowsupdate.com/m ... ru/WAB.CAB
SLO (Slovenian):
http://www.download.windowsupdate.com/m ... sl/AXA.CAB
http://www.download.windowsupdate.com/m ... sl/ICW.CAB
http://www.download.windowsupdate.com/m ... sl/VGX.CAB
http://www.download.windowsupdate.com/m ... sl/WAB.CAB
SKV/SKY (Slovakian):
http://www.download.windowsupdate.com/m ... sk/AXA.CAB
http://www.download.windowsupdate.com/m ... k/AXA2.CAB
http://www.download.windowsupdate.com/m ... k/AXA3.CAB
http://www.download.windowsupdate.com/m ... sk/ICW.CAB
http://www.download.windowsupdate.com/m ... k/IEDW.EXE
http://www.download.windowsupdate.com/m ... k/TS95.CAB
http://www.download.windowsupdate.com/m ... k/TSNT.CAB
http://www.download.windowsupdate.com/m ... sk/VGX.CAB
http://www.download.windowsupdate.com/m ... sk/WAB.CAB
SVE:
http://www.download.windowsupdate.com/m ... sv/AXA.CAB
http://www.download.windowsupdate.com/m ... v/AXA2.CAB
http://www.download.windowsupdate.com/m ... v/AXA3.CAB
http://www.download.windowsupdate.com/m ... sv/ICW.CAB
http://www.download.windowsupdate.com/m ... v/IEDW.EXE
http://www.download.windowsupdate.com/m ... v/TS95.CAB
http://www.download.windowsupdate.com/m ... v/TSNT.CAB
http://www.download.windowsupdate.com/m ... sv/VGX.CAB
http://www.download.windowsupdate.com/m ... sv/WAB.CAB
TRK:
http://www.download.windowsupdate.com/m ... tr/AXA.CAB
http://www.download.windowsupdate.com/m ... tr/ICW.CAB
http://www.download.windowsupdate.com/m ... tr/VGX.CAB
http://www.download.windowsupdate.com/m ... tr/WAB.CAB
As promised, here's the code for the BAT to create FILELIST.DAT and IESETUP.INI (not needed if you created using Notepad as mentioned above):
CLS
@echo off
  echo [General]
  echo Version=1
) > "FILELIST.DAT"
  echo [Version]
  echo Signature="Active setup"
  echo.
  echo [Options]
  echo IELiteMode=0
  echo ConfirmFileList=0
  echo Shell_Integration=1
  echo ProductID="71929-932-2000023-12347"
  echo LocalInstall=1
) > "IESETUP.INI"
