We have now moved the Web site to a new hosting company.
We have used many hosting companies during the past 10+ years for the other communities we used to have with thousands of members and "Tilaa" is absolutely excellent. Please bear in mind that they have NOT paid us to write about them but we feel that they are so good that they deserve to be mentioned.
Again, if you are in need of a VPS, we strongly recommend you to check out their products and services at http://www.tilaa.com.
Excellent, excellent... excellent company! True story!
(For the record, there was nothing wrong with the Namecheap business hosting plan which we had earlier, it worked perfectly but this new place is much faster and we have full control over the machines so it fits our needs much better.)
There are still some small bugs we need to resolve because we decided to use the latest PHP 5.5.0 and phpBB have some issues with this version and is not fully compatible so if you see odd errors, please do let us know.
One visible issue is that the "Last post" does not work for some reason. It always shows "No posts". We are aware that "dates" do not work and show up right now. We are working on it. SOLVED!
Some fun facts, the Web site is now running on Microsoft SQL Server which makes life much easier and is also hosted on a 1Gbps line so things should be much faster. We have two servers running Windows Server 2012. One is the main server and the second one is a mirror server in case the first one goes down. Each of the servers are located at two different cities and are physically separated.
Please accept our apologies for the downtime.
Thank you,
Ps. All of this is of course possible due our friends at Paranormal Stories.
Ds. The old fool-AT-foolsdesign.org email is no longer valid!
/regards Fool's design
