But we'll see when I get there. Just don't hold your breath.
PROBLEMCHYLD ┬╗ Fri Mar 22, 2013 2:10 pm wrote:Coming Soon.........................................![]()
PROBLEMCHYLD wrote:There is no rush. I'm actually glad we fixed that bug because, users that have USB mice and keyboards can benefit from this as well. I just need to find a way to remove USB drivers with some type of file/script/batch etc....
Drugwash wrote:...[url="http://www.fileden.com/files/2012/10/20/3358834/apps/HDDB/HDDB0007.7z"]this utility[/url]...
(What the heck is wrong with the URL command????)[/i]
The .SYS files needs to be deleted also. One will either have to use Microsoft drivers or their manufacturer drivers. You can't use both. I would guess this is why Tihiy and maximus-decim says remove all drivers/controllers etc....Drugwash wrote:Only the registry keys need to be removed, if I'm not mistaken.
Fool's design wrote:Drugwash wrote:...[url="http://www.fileden.com/files/2012/10/20/3358834/apps/HDDB/HDDB0007.7z"]this utility[/url]...
You need to lose the quote characters, only [url=<url here directly without quotes>]...
I'll have to test and see if the actual driver files are being deleted when devices are removed from Device Manager. Maybe only the inf files should be removed (or, better, backed up somewhere along with the pertaining driver files - sys, vxd, etc), since the driver files (sys or whatever) wouldn't be loaded unless they're being referenced to in inf/registry. And overwriting them shouldn't be a problem either.PROBLEMCHYLD wrote:The .SYS files needs to be deleted also. One will either have to use Microsoft drivers or their manufacturer drivers. You can't use both. I would guess this is why Tihiy and maximus-decim says remove all drivers/controllers etc....
Drugwash wrote:Fool's design wrote:Drugwash wrote:...[url="http://www.fileden.com/files/2012/10/20/3358834/apps/HDDB/HDDB0007.7z"]this utility[/url]...
The only thing I hadn't tried at the time...Wasn't there a standard for those things? When I look just above while typing this, the quote sequence uses double quotes for all tags - why the double standards, it's confusing?! Maybe I'm getting too old for this.
Anyway, could you please do it for me, seeing that one can't edit their previous posts? Thank you.
I'll try again here though, just to make sure. Download [url=http://www.fileden.com/files/2012/10/20/3358834/apps/HDDB/HDDB0007.7z]HDDB 0.0.0.7[/url] ... and here's a sample of a fool's design: it doesn't work, even without quotes....
