2013-02-20 17:15 »
If you have a Remote Desktop window opened up, try hitting the start screen in it.
Double start screen, double the fun!
2013-02-21 07:47 »
contextfree` wrote:Corners are normally disabled while you run a desktop app in full screen mode, fyi.
(http://channel9.msdn.com/Forums/Coffeeh ... 6c0064d084)
A fool's solution: Accept and ignore the foolish design and do not use Remote Desktop unless it is in fullscreen.
2013-02-24 12:47 »
Haven't done this ( and the picture is too small ).
What is it that "contextfree" is trying to say here? ( He links over to Channel9 btw )
I find it hard to believe that he implies that little start screen sub-window is professional and makes any kind of sense.
2013-02-24 14:30 »
CharlotteTheHarlot wrote:...What is it that "contextfree" is trying to say here? ( He links over to Channel9 btw )...
What he basically suggests is to not use a windowed Remote Desktop session and always go to full screen when connecting to a Remote Desktop session. Completely ludicrous.
2014-02-12 16:44 »
You would think that they would have fixed this in Windows 8.x... but nooo.
double starter motherfuckers 03.png (573.63 KiB) Viewed 92586 times
double starter motherfuckers 02.png (2.67 MiB) Viewed 92586 times
double starter motherfuckers.png (2.75 MiB) Viewed 92586 times
