Software development, scripting and programming.
2015-12-19 10:12 »
How to delete and remove everything recursively including folders in a directory (or several directories with a list of them inside an array) with a batch file.
Like this:
@echo off
setlocal enabledelayedexpansion
set _folderstoclean[1]="c:myfoldera*"
set _folderstoclean[2]="c:myfolderb*"
set _folderstoclean[3]="c:myfolderc*"
for /l %%i in (1,1,3) do (
   del /q !_folderstoclean[%%i]!
   for /d %%x in (!_folderstoclean[%%i]!) do rd /s /q ^"%%x^"
This line:
"3" is the number of your folders in your array, in this case, we got 3 folders to clean:
So if you had a fourth folder, you would add another line:
set _folderstoclean[4]="c:myfoldera*"
...and change the 3 to 4:
for /l %%i in (1,1,4) do (
Etc.
2020-06-18 04:27 »
for /F "delims=" %%i in ('dir /b') do (rmdir "%%i" /s/q || del "%%i" /s/q)
:wink:
2020-06-18 04:32 »
Of course, that's a nuke it all.
2020-06-18 12:49 »
Oh, very cool addendum, thank you. :clap:
