Software development, scripting and programming.
fne
2018-05-17 19:11 »
Here is how to make custom scrollbars for Web sites in Vivaldi. This will not customize the Vivaldi gUI but the Web sites you visit. It is very nice and a special fuck you to Microsoft for their completely stupid moronic insane and almost invisible scrollbars in Windows.
Credit: I found the original code at Vivaldi forums in here: https://forum.vivaldi.net/topic/26798/t ... -var-color, a guy called https://forum.vivaldi.net/user/hadden89 made it. I altered it a little tiny bit. Full credit to hadden89.
Source code files:
scroll.zip
(5.62 KiB) Downloaded 16361 times
__________
This is my own .css file content which will result in scrollbars looking like this:
body::-webkit-scrollbar { width:14px !important; }
::-webkit-scrollbar-track {
background:rgba(255,255,255,1) !important;
border-radius:0px !important;
::-webkit-scrollbar-thumb {
background-color:#ff4147 !important;
background-image:-webkit-linear-gradient(294deg,rgba(255,255,255,.2) 25%,transparent 25%,transparent 50%,rgba(255,255,255,.2) 50%,rgba(255, 255, 255,.2) 75%,transparent 75%,transparent);
min-height:17px;
-webkit-box-shadow:inset 0 0 4px rgba(0,0,0,0.5) !important;
fne
2018-05-20 06:29 »
A small update, it seems that you don't need to alter "browser.html". As long as you install the extension, it will work just fine!
fne
2018-05-20 06:33 »
Update to my scroll css:
body::-webkit-scrollbar { width:21px !important; }
/*this makes scrollbar lines visible: -webkit-box-shadow:inset 0 0 4px rgba(77,77,77,1) !important;*/
min-height:21px;
-webkit-box-shadow:inset 0 0 4px rgba(0,0,0,0) !important;
::-webkit-scrollbar-button {
    background-size: 90%;
    width:21px;
    height:21px;
    background-repeat: no-repeat;
    background-position: center;
	background-color:#000000 !important;
