2019-04-20 20:35 »
This is a locked topic.
Do NOT use the settings in this topic. They are wrong and will break your Windows installation.
Made a new topic, please go here: viewtopic.php?f=1047&t=4031
Windows Server 2019 light / lite edition.
(Don't use this yet! There is an issue with something breaking "Task Scheduler", trying to find the issue.)
Eats about 700 MB on fresh boot. (Also running IIS webserver)
Here is what I turned off. Everything still works perfectly fine. Fast, snappy and smooth!
Oh, yes, to hell with Microsoft store and the "apps", of course. :sick:
Windows Server 2019 - i.png (2.9 MiB) Viewed 35661 times
Windows Server 2019 - ii.png (1.44 MiB) Viewed 35661 times
Windows Server 2019 - iii.png (2.59 MiB) Viewed 35661 times
2019-04-22 01:07 »
Not sure which service but one of them fucked the "Task Scheduler" service, it won't start. I'm reinstalling this and retry to see which one fucked things up. Didn't have a snapshot from BEFORE I altered stuff so I have to re-do everything again. Took me weeks! LOL Good thing I have the GPO backed up so probably will just have to put in a few days and not weeks.
I will update this when I know what caused this issue.
2019-04-29 21:56 »
Still working on this, not sure which one but some setting kills task scheduler + also disabled remote desktop licensing. Going to test this step by step to see if I can find what caused the issue. :think:
2019-05-10 08:00 »
Found what killed "Task Scheduler".
REM (manual trigger start) - registry 3->4
sc config "TimeBrokerSvc" start=disabled
Can't disable "TimeBrokerSvc"! :!:
Still not done though, there might be more settings which could break things. Still testing. Will update again.
2019-05-12 09:39 »
Locking this topic because the settings are wrong. A new topic here viewtopic.php?f=1047&t=4031. :oops:
Locked
