JiaoTongNan
2019-06-16 00:54 »
Hello,
I am more or less doing a project of installing Windows ME on a Thinkpad R60. The process so far has been nearly perfect. Aside from a motherboard resource conflict, which cannot be fixed, I just need a Windows 9x driver for Soundmax Audio (945GM chipset) and get the wireless card to work.
A while ago, I did this project on a Dell Latitude D600 and problemchyld tweaked the broadcom wireless driver to work on a Windows 9x machine. He did this and his C600 worked fine with it.
If possible, is anyone here capable of modifying this very driver to work on Windows 9x? The driver installs but gives an error just like the driver problemchyld had modified.
http://wireless-drivers.blogspot.com/20 ... pci-e.html
I believe this driver is likely to work if modified due to its age. It was compiled around the near-end of Windows 98/ME support. I just happened to notice that drivers meant for successor systems occasionally work on their predecessors, if the predecessor's lifespan did not quite end.
Wednesday, October 19, 2011
Atheros AR5BXB6 (AR5424) mini PCI-E Wireless Card Driver Download
| Wireless Driver & Software
Atheros AR5BXB6(AR5424) mini PCI-E Wireless Card Driver Download
Atheros 5424(AR5BXB6) wireless module
Device PCI ID:
PCI\VEN_168C&DEV_1014&SUBSYS_05891014
PCI\VEN_168C&DEV_1014&SUBSYS_058A1014
PCI\VEN_168C&DEV_1014&SUBSYS_057E1014
PCI\VEN_168C&DEV_0013&SUBSYS_04081468
When you installed the driver, the device’s name displayed:
11b/g Wireless LAN Mini PCI Express Adapter
11a/b/g Wireless LAN Mini PCI Express Adapter
11b/g Wireless LAN Mini PCI Adapter
11a/b/g Wireless LAN Mini PCI Adapter II
Atheros AR5BXB6(AR5424) mini PCI-E Wireless Card Driver for Win2000/WinXP: Download
Copyright (c) 2001-2004 Atheros Communications, Incorporated All Rights Reserved
Posted by Jet (https://www.blogger.com/profile/02363912003140260350) at 11:31 PM
Atheros.5424.WINXP_2K.rar
(250.48 KiB) Downloaded 2896 times
2019-06-21 06:17 »
Boy, it's a tough one. I certainly can't do this but maybe you are lucky and someone around here can. :???:
JiaoTongNan
2019-07-14 08:29 »
Someone edited my first post to include another driver...unfortunately, I can confirm it does not work.
2019-07-23 00:08 »
I just cached the file from the link you provided. In case someone needed it in the future or something. :oops:
2019-08-31 07:58 »
Looking at the INF file extracted from your RAR:
; Installs ar5211.sys (NDIS 5/5.1 driver) on NT platforms (2000, XP and greater)
; Installs ar52119x.sys (NDIS 5 driver) on 9x platforms
there is no ar52119x.sys in your download, however the same file can be extracted from the following using 7-zip:
https://content.us.dynabook.com/content ... twlan8.exe
Hope this helps!
2019-08-31 09:29 »
I'm seeing references to people saying that the Atheros Client Utility is required, I obviously can't confirm, but here's a link:
https://support.dynabook.com/support/vi ... tId=461288
By the way, the files from that site are self-extracting, I think they'll extract to a folder when you run the EXE (alternatively extract with 7-zip), you'll still need to go to the Device Manager and point to that folder for the drivers or run the EXE files in the folder....
While I'd try the above first, I'll attach a file with newer versions of the driver and the monitoring utility (you could try it out, not sure any of this will work for you).
330150.zip
(7.63 MiB) Downloaded 2033 times
2019-08-31 16:41 »
I found one more updated version of the driver with the 9x file included. Again, not certain about any of this, but this is the latest that I can find.
xp32-3.1.1.54.zip
(425.56 KiB) Downloaded 1415 times
Anyway, several you can at least try.
2019-09-14 10:25 »
What device ID are you looking at specifically?
HKEY_LOCAL_MACHINE\Enum\PCI
Kinda odd, but I note that the inf for the newest driver I found that includes the ar52119x.sys file the line:
[ControlFlags]
ExcludeFromSelect = \ ;for win95 and legacy support
The same device isn't excluded in previous versions.... :?:
2019-09-14 10:39 »
FYI, there are several utilities out there to help identify devices, here's a couple (can't attest to quality):
https://www.majorgeeks.com/files/detail ... vices.html
https://www.majorgeeks.com/files/detail ... ifier.html
2019-09-19 04:43 »
One last addition (sans reply from JiaoTongNan):
https://support.lenovo.com/us/en/downloads/ds013753
I think this is the same drivers with a different name, probably has the client utility (or something similar too).
Driver for 11b/g Wireless LAN Mini PCI Adapter (2.4.2.2903) - AM52119X.SYS
