2019-09-08 04:31 »
Those Windows XP 32 bit Updates for SSE2 or later processors.
This post is to list all of the Windows Updates that I downloaded and the Windows Update site installed on my computer to bring it up to date. This is at least partially based on my my somewhat messed up methodology. Let me explain. After installing SP3 and IE8, I attempted to download the first set of updates listed on the Windows Update site. I then installed Windows Media Player 11 and then let Windows Update install the rest of the updates, this required at least 2 more visits to the Windows Update site. I meant to refine this before Microsoft started killing all of this off, but alas, time got away from me. Anyway, I do believe this will leave you with an up-to-date XP installation. Yes, I know there are unofficial Service Packs out there, but some people like to do things by hand. If you have a different method, please sing out. Also, if you know of some download links for hotfixes, et cetra, sing out too.
OKay, before going any further, let's cover a few things. What processors include the SSE2 instruction set? I'll let Wikipedia answer that one:
https://en.wikipedia.org/wiki/SSE2
...first introduced by Intel with the initial version of the Pentium 4 in 2000.
Competing chip-maker AMD added support for SSE2 with the introduction of their Opteron and Athlon 64 ranges of AMD64 64-bit CPUs in 2003.
First I'm gonna provide a list of downloads that are official updates/patches for XP from Microsoft. This list will be for English (ENU) versions. Those of you needing localized versions for other languages can find most of them by visiting Microsoft's Update Catalog site:
https://www.catalog.update.microsoft.com/
You can then copy and paste the descriptions below that end with the KB number in parentheses. There may be a few, like IE8, you'll have to find. I strongly suggest making sure that IE 8, SP 3, and WMP 11 are standalone, not requiring additional files to be downloaded.
After I list all of the official downloads for XP in the this post, I will show a registry entry that needs to be added to XP to allow the unofficial Windows POS 2009 updates to be installed on the system in the next. Windows Embedded XP/POS 2009 was based off of Windows XP. While not officially supported by Microsoft, these updates are, as far as I know compatible. Also, in my second post, I will list all of those updates that were installed on my computer. In my third post, I'm planning to provide text that you can use to create BAT files to use to help install these updates easily. I'll mention things NOT covered by the BAT files. Also, in the third post I'll provide a link and a command to run when everything else is done.
In short, for those that wish to do things my way:
  • Download all the files to a single folder
  • Install SP3 and IE 8
  • Create a BAT files from the text that I provide in my third post, I suggest naming the first one 1.bat, the second one 2.bat... also save to the folder with downloads.
  • Run first BAT file
  • Reboot
  • Run second bat file
  • Reboot
  • Update registry (add registry entry from second post)
  • Run thrid BAT file
  • Reboot
  • Install final update and run the command (mentioned at the end of third post, Reboot if advised
For those not in the know:
To create BAT files, open notepad, copy the sections in Code sections in following post, save as 1.bat, 2.bat...
They say a picture's worth a thousands words:
To create a reg files, it's the same thing, just use reg extension (filename.reg)
When ready to run BAT, double click it, when ready to add entries to registry double click REG file.
Got it? Good!
Okay, let's get going with the downloads:
Official XP compatible files:
1. XP SP3:
Reboot
2. IE 8:
Reboot (Gonna run a slew after this without rebooting):
3. Security Update for Windows XP (KB979309)
4. Security Update for Windows XP (KB2922229)
5. Security Update for Windows XP (KB2929961)
6. Security Update for Windows XP (KB2930275)
7. Security Update for Windows XP (KB2916036)
8. Security Update for Windows XP (KB2914368)
9. Security Update for Windows XP (KB2898715)
10. Security Update for Windows XP (KB2892075)
11. Security Update for Windows XP (KB2893294)
12. Update for Windows XP (KB2904266)
13. Cumulative Security Update for ActiveX Killbits for Windows XP (KB2900986)
14. Security Update for Windows XP (KB2876331)
15. Security Update for Windows XP (KB2868626)
16. Security Update for Windows XP (KB2862152)
17. Security Update for Windows XP (KB2847311)
18. Security Update for Windows XP (KB2868038)
19. Security Update for Windows XP (KB2862330)
20. Security Update for Windows XP (KB2862335)
21. Security Update for Windows XP (KB2876217)
22. Security Update for Windows XP (KB2864063)
23. Security Update for Windows XP (KB2850869)
24. Security Update for Windows XP (KB2859537)
25. Security Update for Windows XP (KB2834886)
26. Security Update for Windows XP (KB2820917)
27. Security Update for Windows XP (KB2813345)
28. Security Update for Windows XP (KB2807986)
29. Security Update for Windows XP (KB2802968)
30. Security Update for Windows XP (KB2780091)
31. Security Update for Windows XP (KB2757638)
32. Security Update for Windows XP (KB2770660)
33. Security Update for Windows XP (KB2727528)
34. Update for Windows XP (KB2749655)
35. Security Update for Windows XP (KB2723135)
36. Security Update for Windows XP (KB2705219)
37. Security Update for Windows XP (KB2691442)
38. Security Update for Windows XP (KB2655992)
39. Security Update for Windows XP (KB2719985)
40. Security Update for Windows XP (KB2698365)
41. Security Update for Windows XP (KB2712808)
42. Security Update for Windows XP (KB2686509)
43 Security Update for Windows XP (KB2676562)
44. Security Update for Windows XP (KB2653956)
45. Security Update for Windows XP (KB2659262)
46. Security Update for Windows XP (KB2661637)
47. Security Update for Windows XP (KB2584146)
48. Security Update for Windows XP (KB2631813)
49. Security Update for Windows XP (KB2585542)
50. Security Update for Windows XP (KB2603381)
51. Security Update for Windows XP (KB2598479)
52. Security Update for Windows XP (KB2619339)
53. Security Update for Windows XP (KB2620712)
54. Security Update for Windows XP (KB2544893)
55. Security Update for Windows XP (KB2592799)
56. Security Update for Windows XP (KB2564958)
57. Security Update for Windows XP (KB2570947)
58. Security Update for Windows XP (KB2566454)
59. Security Update for Windows XP (KB2536276)
60. Security Update for Windows XP (KB2507938)
61. Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB973688)
62. Security Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB954430)
63. Security Update for Windows XP (KB2535512)
64. Security Update for Windows XP (KB2485663)
65. Security Update for Windows XP (KB2508429)
66. Security Update for Windows XP (KB2506212)
67. Security Update for Windows XP (KB2510531)
68. Security Update for Windows XP (KB2509553)
69. Security Update for Windows XP (KB2479943)
70. Security Update for Windows XP (KB2481109)
71. Update for Windows XP (KB971029)
72. Security Update for Windows XP (KB2478971)
73. Security Update for Windows XP (KB2483185)
74. Security Update for Windows XP (KB2478960)
75. Security Update for Windows XP (KB2393802)
76. Security Update for Windows XP (KB2419632)
77. Security Update for Windows XP (KB2423089
78. Security Update for Windows XP (KB2443105)
79. Security Update for Windows XP (KB975558)
80. Security Update for Windows XP (KB979687)
81. Security Update for Windows XP (KB2296011)
82. Security Update for Windows XP (KB2378111)
83. Security Update for Windows XP (KB2387149)
84. Security Update for Windows XP (KB982132)
85. Security Update for Windows XP (KB2347290)
86. Security Update for Windows XP (KB2115168)
87. Security Update for Windows XP (KB982665)
88. Security Update for Windows XP (KB981997)
89. Security Update for Windows XP (KB2229593)
90. Security Update for Windows Media Format Runtime 9, 9.5 & 11 for Windows XP SP3 (KB978695)
91. Security Update for Windows XP (KB979482)
92. Security Update for Windows XP (KB978542)
93. Security Update for Windows XP (KB977816)
94. Security Update for Windows XP (KB978338)
95. Security Update for Windows XP (KB975713)
96. Security Update for Windows XP (KB975560)
97. Security Update for Windows XP (KB977914)
98. Security Update for Windows XP (KB978706)
99. Security Update for Windows XP (KB972270)
100. Security Update for Windows XP (KB974318)
101. Security Update for Windows XP (KB974392)
102. Security Update for Windows XP (KB973904)
103. Security Update for Windows XP Service Pack 3 (KB952069)
104. Security Update for Windows Media Format Runtime 9, 9.5 & 11 for Windows XP SP 3 (KB954155)
105. Security Update for Windows XP (KB975025)
106. Security Update for Windows XP (KB974571)
107. Security Update for Windows XP (KB974112)
108. Security Update for Windows XP (KB969059)
109. Security Update for Windows XP (KB975467)
110. Update for Windows XP (KB968389)
111. Security Update for Windows XP (KB956844)
112. Security Update for Windows XP Service Pack 3 (KB973540)
113. Security Update for Windows XP (KB973869)
114. Security Update for Windows XP (KB973507)
115. Security Update for Windows XP (KB960859)
116. Security Update for Windows XP (KB973815)
117. Security Update for Windows XP (KB971657)
118. Security Update for Windows XP (KB923561)
119. Security Update for Windows XP (KB956572)
120. Security Update for Windows XP (KB960803)
121. Security Update for Windows XP (KB959426)
122. Security Update for Windows XP (KB950974)
123. Update for Windows XP (KB952287)
124. Security Update for Windows XP (KB946648)
125. Security Update for Windows XP (KB952954)
126. Update for Windows XP (KB951978)
127. Security Update for Windows XP (KB951376)
128. Security Update for Windows XP (KB950762)
129. Security Update for Windows XP with Windows Media Format Runtime 9 (KB941569
130. Update for Windows XP (KB2808679)
131. Update for Windows XP (KB2632503)
132. Update for Internet Explorer 8 Compatibility View List for Windows XP (KB2598845)
133. Update for Windows XP (KB2492386)
134. Update for Windows XP (KB971513)
135. Windows Media Player 11
136. windowsxp-mscomppackv1-x86.exe
(582.31 KiB) Downloaded 3412 times
137. Update for Windows Media Player 11 for Windows XP (KB939683)
138. Update for Windows Media Format 11 SDK for Windows XP (KB929399)
139. Security Update for Windows XP (KB954154)
140. Security Update for Windows XP (KB963093)
141. Security Update for Windows XP (KB952004)
142. Update for Windows XP (KB970430)
143. Update for Windows XP (KB2345886)
144. Security Update for Windows Media Format Runtime 11 for Windows XP (KB2834904)
Hopefully, if you clever guys and dolls can refine this, we'll get '!' to update this post and note a thank you in it :thumbup:
2019-09-08 04:39 »
As promised, here's the registry entry required to get these updates to work on Windows XP 32 bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001
Now on with the Downloads:
XP Embedded /WEPOS 2009 updates/patches
1. Security Update for WEPOS and POSReady 2009 (KB2926765)
2. Security Update for WEPOS and POSReady 2009 (KB2993651)
3. Security Update for WEPOS and POSReady 2009 (KB2993254)
4. Security Update for WEPOS and POSReady 2009 (KB2998579)
5. Security Update for WEPOS and POSReady 2009 (KB3013126)
6. Security Update for WEPOS and POSReady 2009 (KB3020393)
7. Security Update for WEPOS and POSReady 2009 (KB3021674)
8. Security Update for WEPOS and POSReady 2009 (KB3004361)
9. Security Update for WEPOS and POSReady 2009 (KB3029944)
10. Security Update for WEPOS and POSReady 2009 (KB3033889)
11. Security Update for WEPOS and POSReady 2009 (KB3035132)
12. Security Update for WEPOS and POSReady 2009 (KB3033890)
13. Security Update for WEPOS and POSReady 2009 (KB2926765)
14. Update for WEPOS and POSReady 2009 (KB3065979)
15. Security Update for WEPOS and POSReady 2009 (KB3067903)
16. Security Update for WEPOS and POSReady 2009 (KB3078601)
17. Security Update for WEPOS and POSReady 2009 (KB3087039)
18. Security Update for WEPOS and POSReady 2009 (KB2957503)
19. Security Update for WEPOS and POSReady 2009 (KB3109560)
20. Security Update for WEPOS and POSReady 2009 (KB3121918)
21. Security Update for WEPOS and POSReady 2009 (KB3126593)
22. Security Update for WEPOS and POSReady 2009 (KB3126587)
23. Security Update for WEPOS and POSReady 2009 (KB3139398)
24. Security Update for WEPOS and POSReady 2009 (KB3081320)
25. Security Update for WEPOS and POSReady 2009 (KB3139914)
26. Security Update for WEPOS and POSReady 2009 (KB3140709)
27. Security Update for WEPOS and POSReady 2009 (KB3149090)
28. Security Update for WEPOS and POSReady 2009 (KB3145739)
29. Security Update for WES09 and POSReady 2009 (KB3161561)
30. Security Update for WES09 and POSReady 2009 (KB3161949)
31. Security Update for WES09 and POSReady 2009 (KB3170455)
32. Security Update for WEPOS and POSReady 2009 (KB3092601)
33. Security Update for WES09 and POSReady 2009 (KB3178034)
34. Security Update for WES09 and POSReady 2009 (KB3196718)
35. Security Update for WES09 and POSReady 2009 (KB3198510)
36. Security Update for WES09 and POSReady 2009 (KB4012583)
37. Security Update for WES09 and POSReady 2009 (KB3185911)
38. Security Update for WES09 and POSReady 2009 (KB4012584)
39. Security Update for WES09 and POSReady 2009 (KB4014652)
40. Security Update for WES09 and POSReady 2009 (KB4014794)
41. Security Update for WES09 and POSReady 2009 (KB4015383)
42. Security Update for WES09 and POSReady 2009 (KB4022747)
43. Security Update for WES09 and POSReady 2009 (KB4024323)
44. Security Update for WES09 and POSReady 2009 (KB4025218)
45. Security Update for WES09 and POSReady 2009 (KB4026061)
46. Security Update for WES09 and POSReady 2009 (KB4025497)
47. Security Update for WES09 and POSReady 2009 (KB4025409)
48. Security Update for WES09 and POSReady 2009 (KB4034775)
49. Security Update for WES09 and POSReady 2009 (KB3183431)
50. Security Update for WES09 and POSReady 2009 (KB4047211)
51. 2017-12 Security Update for Windows XP Embedded SP3 for x86-based Systems (KB4052303)
52. 2018-01 Security Update for Windows XP Embedded SP3 for x86-based Systems (KB4056941)
53. 2018-03 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4089175)
54. 2018-03 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4089082)
55. 2018-03 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4089694)
56. Security Update for WES09 and POSReady 2009 (KB4039384)
57. 2018-04 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4091756)
58. 2018-05 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4130957)
59. 2018-05 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4101477)
60. 2018-05 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4056564)
61. 2018-05 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4089453)
62. 2018-06 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4294413)
63. 2018-07 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4291391)
64. 2018-08 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4343674)
65. Security Update for WES09 and POSReady 2009 (KB4041995)
66. 2018-09 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4458000)
67. 2018-09 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4458318)
68. 2018-09 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4458006)
69. 2018-10 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4462935)
70. 2018-10 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4462987)
71. 2018-09 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4458001)
72. 2018-10 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4463103)
73. 2018-10 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4463573)
74. 2018-11 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4470118)
75. 2018-11 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4467689)
76. 2018-12 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4473077)
77. Update for WES09 and POSReady 2009 (KB4468323)
78. 2019-02 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4486463)
79. 2018-09 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4457163)
80. 2019-02 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4487086)
81. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4489493)
82. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4490228)
83. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4489973)
84. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4490501)
85. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4490385)
86. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4486468)
87. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4486538)
88. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4486536)
89. 2019-02 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4486465)
90. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4493341)
91. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4489977)
92. 2019-03 Security Update for POSReady 2009 for x86-based Systems (KB4489974)
93. 2019-03 Update for POSReady 2009 for x86-based Systems (KB4487989)
94. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4491443)
95. 2019-02 Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4486924)
96. Security Update for WES09 and POSReady 2009 for x86-based Systems (KB4487085)
http://download.windowsupdate.com/d/msd ... ba1ca3.exe
97. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4494059)
98. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493797)
99. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493796)
100. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493927)
101. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493795)
102. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493793)
103. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493563)
104. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493794)
105. 2019-04 Update for POSReady 2009 for x86-based Systems (KB4487990)
106. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4495022)
107. 2019-04 Cumulative Security Update for Internet Explorer 8 for POSReady 2009 for x86-based systems (KB4493435)
108. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4493790)
109. 2019-04 Security Update for POSReady 2009 for x86-based Systems (KB4494528)
110. Update for WES09 and POSReady 2009 (KB4019276)
111. Update for WES09 and POSReady 2009 (KB4459091)
112. Update for WES09 and POSReady 2009 (KB4467770)
2019-09-08 05:40 »
Here's my cheesy BAT files!
This one REQUIRES that you have already installed Service Pack 3 and IE 8 before running. It does give a message and pauses to allow you to close it if you forgot, but does not have the ability to actually check if you did install SP3 and IE 8. Really, you should know. :lol: Again, I recommend naming this one '1.BAT' and all these BATs must be in the same folder as the downloaded files to work, as should all these BAT files. These should close when they've finished and will likely take a good bit of time. REBOOT after running each!
@echo off
title  Updates for XP 32 bit part 1
echo Ensure SP3 and IE 8 have been installed before continuing. If SP3 and IE 8 aren't installed, close this update by clicking 'X' in upper right-hand corner.
pause
echo Installing updates and patches, please wait....
@echo off
start /wait windowsxp-kb979309-x86-enu_b6a3d8953714847d02d614e8fcb5b4171d1029fb.exe /quiet /passive /norestart
start /wait windowsxp-kb2922229-x86-enu_0e149634fac7cb51e39d557c60549bea43f027bc.exe /quiet /passive /norestart
start /wait windowsxp-kb2929961-x86-enu_fa34fa05e955ffd2ddce10e3a9dda275cd214b06.exe /quiet /passive /norestart
start /wait windowsxp-kb2930275-x86-enu_9dd04b8c0bcc2ac895b36f92648ca00de6083157.exe /quiet /passive /norestart
start /wait windowsxp-kb2916036-x86-enu_e45581340485f6f9a5ded9a73afd51f126c37239.exe /quiet /passive /norestart
start /wait windowsxp-kb2914368-x86-enu_1d9a306f9e5dd564c8ffdcdb8717c4ae2588db3d.exe /quiet /passive /norestart
start /wait windowsxp-kb2898715-x86-enu_a5a457cf2bcbf3f0cd73f422b7cc3af5b086d95e.exe /quiet /passive /norestart
start /wait windowsxp-kb2892075-x86-enu_17de2e03645b5d87bd09f161d996cb0a07c289e1.exe /quiet /passive /norestart
start /wait windowsxp-kb2893294-x86-enu_f13e5e517b86f5cad62d9e0e6efa1c411efae1ef.exe /quiet /passive /norestart
start /wait windowsxp-kb2904266-x86-enu_dbb1b301ba862c02e0b34570e3c78a719144f823.exe /quiet /passive /norestart
start /wait windowsxp-kb2900986-x86-enu_0d694f8de9ef0063d06b08985224759abdb7ef9a.exe /quiet /passive /norestart
start /wait windowsxp-kb2876331-x86-enu_3e44451e40197240c9eaaf2b0275756e205bf5b8.exe /quiet /passive /norestart
start /wait windowsxp-kb2868626-x86-enu_1a00424d2070b57a4d9e2e73e54d90f51bb0562a.exe /quiet /passive /norestart
start /wait windowsxp-kb2862152-x86-enu_0457906284ff7fd706d77a69ac337ce7f65c7919.exe /quiet /passive /norestart
start /wait windowsxp-kb2847311-x86-enu_f7d56448ca8e09d96837125424f7058ca7297a71.exe /quiet /passive /norestart
start /wait windowsxp-kb2868038-x86-enu_0cc9f04af1cfc59b088f1c426792c7746fdf695f.exe /quiet /passive /norestart
start /wait windowsxp-kb2862330-x86-enu_00e64588c6eaf60c184d31d65a42ba950b020c28.exe /quiet /passive /norestart
start /wait windowsxp-kb2862335-x86-enu_baeaacdc07fa53a6e4a1ef558c0b4638d2541fd4.exe /quiet /passive /norestart
start /wait windowsxp-kb2876217-x86-enu_a662db07022635ce69613fa2819472862efe4531.exe /quiet /passive /norestart
start /wait windowsxp-kb2864063-x86-enu_135f76c6e66a127411cf3e406959ca56eae8e551.exe /quiet /passive /norestart
start /wait windowsxp-kb2850869-x86-enu_f95a8470be09e5afd4d987a9d89b7ea26b428acf.exe /quiet /passive /norestart
start /wait windowsxp-kb2859537-x86-enu_8eb81b4b8339fa12bd4a5ede7ec9e4d225ec209c.exe /quiet /passive /norestart
start /wait windowsxp-kb2834886-x86-enu_4c6b8f13c24e41e5c9815780d09459f24c14183b.exe /quiet /passive /norestart
start /wait windowsxp-kb2820917-x86-enu_44b31849d4c3bfbeea9023d68db2ed8537662e0b.exe /quiet /passive /norestart
start /wait windowsxp-kb2813345-x86-enu_a87abf527c0b8026208e99f7771478bd82b45c90.exe /quiet /passive /norestart
start /wait windowsxp-kb2807986-x86-enu_8cf50640e3fa43fe236c61c31859768795eaa048.exe /quiet /passive /norestart
start /wait windowsxp-kb2802968-x86-enu_c0515dbf62a0f679e5cf7d77c054ec717d4a5a8e.exe /quiet /passive /norestart
start /wait windowsxp-kb2780091-x86-enu_048e2d351378500825a48ec960624dd217604807.exe /quiet /passive /norestart
start /wait windowsxp-kb2757638-x86-enu_df96d391e60c5be205071dd64d8c59884e9ae7c6.exe /quiet /passive /norestart
start /wait windowsxp-kb2770660-x86-enu_2ea121f18e223eb0610260035e2ded1d785e5629.exe /quiet /passive /norestart
start /wait windowsxp-kb2727528-x86-enu_0a3eac9e820944e76cff5a6c2e8e4b6a6a31ce20.exe /quiet /passive /norestart
start /wait windowsxp-kb2749655-x86-enu_81e0108b1a83bc558dc2aee86e40eca769c5e9d8.exe /quiet /passive /norestart
start /wait windowsxp-kb2723135-v2-x86-enu_00fce783b936aa2a79715154e5e896fbc25b3f83.exe /quiet /passive /norestart
start /wait windowsxp-kb2705219-v2-x86-enu_5da19122909e6616886e3d35d226fda552ebdc13.exe /quiet /passive /norestart
start /wait windowsxp-kb2691442-x86-enu_5badc4a8d9dddd74695b2d3c3cd793c029fad257.exe /quiet /passive /norestart
start /wait windowsxp-kb2655992-x86-enu_148c0a8c097733dec018854373856cc1f1c4eaa5.exe /quiet /passive /norestart
start /wait windowsxp-kb2719985-x86-enu_d33ea68905d7228777d96ba64656b26cb9aee5a2.exe /quiet /passive /norestart
start /wait windowsxp-kb2698365-x86-enu_b7e3e61d18de050ee914494dff53f1de868fb5dd.exe /quiet /passive /norestart
start /wait windowsxp-kb2712808-x86-enu_1acc8665880c78ef8bf1a3c0c40218fa9ce26185.exe /quiet /passive /norestart
start /wait windowsxp-kb2686509-x86-enu_fdbb0ff8820e54be0eefc9e4e47ca4f0116d84a6.exe /quiet /passive /norestart
start /wait windowsxp-kb2676562-x86-enu_6497fbd4ae292d06ff7b32d408196164b7ccd9e2.exe /quiet /passive /norestart
start /wait windowsxp-kb2653956-x86-enu_2fb667e1082bce2589326fcc713f9c2306f70c8d.exe /quiet /passive /norestart
start /wait windowsxp-kb2659262-x86-enu_f679467f80cf9c3dbb0a31f558e4a5f77471c27e.exe /quiet /passive /norestart
start /wait windowsxp-kb2661637-x86-enu_ba52dfa92940b58a752810151ab0d4e74deb48ba.exe /quiet /passive /norestart
start /wait windowsxp-kb2584146-x86-enu_708a4a32c115fdfe3474a22bc113129475361072.exe /quiet /passive /norestart
start /wait windowsxp-kb2631813-x86-enu_f6154b624398c24f007b66be5c96ac9ead6279d1.exe /quiet /passive /norestart
start /wait windowsxp-kb2585542-x86-enu_8812e165246f8a1b68f65330ba5621818d9d348c.exe /quiet /passive /norestart
start /wait windowsxp-kb2603381-x86-enu_f2d782a2715c9ed03ce70ce47975494f95a6b4e7.exe /quiet /passive /norestart
start /wait windowsxp-kb2598479-x86-enu_1876be74b01993fd64fdf68e8f19cad78cd878cf.exe /quiet /passive /norestart
start /wait windowsxp-kb2619339-x86-enu_b1bb039422a906a7b32159db286fd827a1781686.exe /quiet /passive /norestart
start /wait windowsxp-kb2620712-x86-enu_29f43eb377d0a420d67bd1e4908aa47cef9f079b.exe /quiet /passive /norestart
start /wait windowsxp-kb2544893-v2-x86-enu_27c268ee84f0b69a6b9efd63bc0989f0d9e3c968.exe /quiet /passive /norestart
start /wait windowsxp-kb2592799-x86-enu_9295566618f819f675688f8b088743cb21f9eb6a.exe /quiet /passive /norestart
start /wait windows-en-us-kb2564958_65c98e33d275c4410dd2dec71cf39e4e81bf530a.exe /quiet /passive /norestart
start /wait windowsxp-kb2570947-x86-enu_62e1630e0f8731279f558ccc977f8f8a2b9cb14e.exe /quiet /passive /norestart
start /wait windowsxp-kb2566454-x86-enu_334393e8002f9a92618410b7b578c97cbc14905d.exe /quiet /passive /norestart
start /wait windowsxp-kb2536276-v2-x86-enu_e8a6ac077f11902565cb5ac423df3290862fc953.exe /quiet /passive /norestart
start /wait windowsxp-kb2507938-x86-enu_5568319a9f23638b28306ec6c79f14f1c35c7414.exe /quiet /passive /norestart
start /wait msxml4-kb973688-enu_ccbcf042ade27866fd6c9b72767f9bc67ea54eb4.exe /quiet /passive /norestart
start /wait msxml4-kb954430-enu_c40d3e3035b8cea714f27532fea37c05b2d4dc65.exe /quiet /passive /norestart
start /wait windowsxp-kb2535512-x86-enu_96bcbab3c4ba3b1bb8ee912454b0e36fa8f2944b.exe /quiet /passive /norestart
start /wait windowsxp-kb2485663-x86-enu_e6142de1db2c310632af0badc06392a85f78304d.exe /quiet /passive /norestart
start /wait windowsxp-kb2508429-x86-enu_e0b40d81f2ecc1bad43439a6bd0a9e2a0ab7dd56.exe /quiet /passive /norestart
start /wait windowsxp-kb2506212-x86-enu_8d65ae1e5ccf2a10c9bd1699e316c859005ef685.exe /quiet /passive /norestart
start /wait ie8-windowsxp-kb2510531-x86-enu_d147ba2ed4f4528ecf8f0897990db53b46a230f3.exe /quiet /passive /norestart
start /wait windowsxp-kb2509553-x86-enu_b7be1af1e39194c02cad8426d3756254a7a5bc7e.exe /quiet /passive /norestart
start /wait windowsxp-kb2479943-x86-enu_0f4fe52f57ff542624050e386ac2b264ea032631.exe /quiet /passive /norestart
start /wait windowsxp-kb2481109-x86-enu_357fb75b3178fa715a5e9c209ed6c8cf86899c77.exe /quiet /passive /norestart
start /wait windowsxp-kb971029-x86-enu_c5a9081a6d7a0ba32848782ca6f4e4031cdb595f.exe /quiet /passive /norestart
start /wait windowsxp-kb2478971-x86-enu_4461eaff0dab1a7900e1b41afb5a7a9319a96253.exe /quiet /passive /norestart
start /wait windowsxp-kb2483185-x86-enu_8d3deb8249d91112891ff5a847c6debcec1dee84.exe /quiet /passive /norestart
start /wait windowsxp-kb2478960-x86-enu_56cc4e7eae7362f056ccd946e5e69d1b4a1c1e76.exe /quiet /passive /norestart
start /wait windowsxp-kb2393802-x86-enu_317d4fcbb0a230f3462f40ea2be322d5eced5866.exe /quiet /passive /norestart
start /wait windowsxp-kb2419632-x86-enu_6dfaf9fe0d89d32d3c28e8245c1fe87d4561af1f.exe /quiet /passive /norestart
start /wait windowsxp-kb2423089-x86-enu_94cce8eb153f98affd81951f2123b74f14a59925.exe /quiet /passive /norestart
start /wait windowsxp-kb2443105-x86-enu_c6025a43d53129a2f4d0def88d1f1ccaa6c622b2.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb975558-x86-enu_9ee8bd40993d20e65f4c92767dd058c48df92c84.exe /quiet /passive /norestart
start /wait windowsxp-kb979687-x86-enu_c42f90a1cdb62f35e29f0a7dc1fc9edebef69628.exe /quiet /passive /norestart
start /wait windowsxp-kb2296011-x86-enu_95ff937b7a8443ddb8ae0579da94690ac3a85d0d.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb2378111-x86-enu_d671499dc30eb76f81fcdc279f8bf3fc3df934bc.exe /quiet /passive /norestart
start /wait windowsxp-kb2387149-x86-enu_62c37617cb0c9502a135b43a161482928084cbaa.exe /quiet /passive /norestart
start /wait windowsxp-kb982132-x86-enu_1ec5258de785e380d2eb9c8634f64e736d929618.exe /quiet /passive /norestart
start /wait windowsxp-kb2347290-x86-enu_de6572122c6323cc343a9273ee0d24188b240a32.exe /quiet /passive /norestart
start /wait windowsxp-kb2115168-x86-enu_675e6a32a90807671042e4de6b1f10a2fd82b157.exe /quiet /passive /norestart
start /wait windowsxp-kb982665-x86-enu_3b611460ba349838a9e8eabcbbe4b2ffe2e3b1e7.exe /quiet /passive /norestart
start /wait windowsxp-kb981997-x86-enu_c0c210a40f1e3d801a2b9705b78b540c0e135824.exe /quiet /passive /norestart
start /wait windowsxp-kb2229593-x86-enu_745d7b032115820cef735f83660c5e3c870da33b.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb978695-x86-enu_99fe7c707b79c3585b245de5f811b295a152c3bf.exe /quiet /passive /norestart
start /wait windowsxp-kb979482-x86-enu_e848aac75a3d3361bde4486fd5185ced7b3037b8.exe /quiet /passive /norestart
start /wait windowsxp-kb978542-x86-enu_11f7b200a2bbb1b053e34b821141e72240c592d8.exe /quiet /passive /norestart
start /wait windowsxp-kb977816-x86-enu_0a99a4abced5b224ab8fdf5054d5d6cff991e064.exe /quiet /passive /norestart
start /wait windowsxp-kb978338-x86-enu_4d1317a99a8951697a0c1213687199ad89ba6d9d.exe /quiet /passive /norestart
start /wait windowsxp-kb975713-x86-enu_8143fc78eac39de3e91e31b0096adecdbe1cdd83.exe /quiet /passive /norestart
start /wait windowsxp-kb975560-x86-enu_c57ed328ab8838ecbb6ffea46fa0bcbd76b2cc59.exe /quiet /passive /norestart
start /wait windowsxp-kb977914-x86-enu_60a362b77f6e5fb22208b05624d30f817c4bd4a7.exe /quiet /passive /norestart
start /wait windowsxp-kb978706-x86-enu_f4e076b3867c2f08b6d258316aa0e11d6822b8d7.exe /quiet /passive /norestart
start /wait windowsxp-kb972270-x86-enu_5ae81de178c87a5a40ccb208d3fd762c1c34fbb1.exe /quiet /passive /norestart
start /wait windowsxp-kb974318-x86-enu_8612baba6e75a76faee0606cf9f8970824e2f8d3.exe /quiet /passive /norestart
start /wait windowsxp-kb974392-x86-enu_f2acc593bbeb6296b4b921fecb3c71dd93db076c.exe /quiet /passive /norestart
start /wait windowsxp-kb973904-x86-enu_f08c92a67f1bd7f0768eca980d885eb85a91d52c.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb952069-v2-x86-enu_7918e468c91942521b143def50e427b27efa703f.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb954155-x86-enu_4caf879b0297044df1601b2c8312cfd38b929100.exe /quiet /passive /norestart
start /wait windowsxp-kb975025-x86-enu_a7cb9fdfedb5e7b464709910afeec4cff61c89f4.exe /quiet /passive /norestart
start /wait windowsxp-kb974571-x86-enu_dcca5129a21f3ccbea4609e1bcf7763f07c1883b.exe /quiet /passive /norestart
start /wait windowsxp-kb974112-x86-enu_e2e2d805c4dc419d0f7d83652eec5379d2ba8692.exe /quiet /passive /norestart
start /wait windowsxp-kb969059-x86-enu_e0bb7f06a55b6fc94b39f75e5d9e7d9b0b3b0c5d.exe /quiet /passive /norestart
start /wait windowsxp-kb975467-x86-enu_703673b065074bb9dd7d849f420e52ea0d343f8d.exe /quiet /passive /norestart
start /wait windowsxp-kb968389-x86-enu_60547c9ff654ed09c9343b3096e726eaf44e2259.exe /quiet /passive /norestart
start /wait windowsxp-kb956844-x86-enu_926002701569eabda17630d8f9cb45d8ced0ab71.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb973540-x86-enu_bea728bec09879f6b924a6b3d781af1e77c6f5b4.exe /quiet /passive /norestart
start /wait windowsxp-kb973869-x86-enu_c0679cb2d4c07f35f39ee5d8d7b973c5e4582d34.exe /quiet /passive /norestart
start /wait windowsxp-kb973507-x86-enu_b74b10f783998bb7b15f8bc3a7a5a572749fb303.exe /quiet /passive /norestart
start /wait windowsxp-kb960859-x86-enu_c1a1e20576bc745a720053357e46be6c2a3f7faa.exe /quiet /passive /norestart
start /wait windowsxp-kb973815-x86-enu_1d84219447edee9e6989e740e7fd477360e4059d.exe /quiet /passive /norestart
start /wait windowsxp-kb971657-x86-enu_697f5d861910aa051131a58e1af607a79e14e1a9.exe /quiet /passive /norestart
start /wait windowsxp-kb923561-x86-enu_b8aac16b07ca89c7dde4d724c808ff88faa456ec.exe /quiet /passive /norestart
start /wait windowsxp-kb956572-x86-enu_a2463f484318332e8319dd931c87b27cf747b2de.exe /quiet /passive /norestart
start /wait windowsxp-kb960803-x86-enu_114aa39cb3e1e42c0f9897c99e697084dbdc656f.exe /quiet /passive /norestart
start /wait windowsxp-kb959426-x86-enu_9bdfabdec1c98057a92503cb00ce6ed623b517c5.exe /quiet /passive /norestart
start /wait windowsxp-kb950974-x86-enu_fd840632e13df756e9d1251400e6e659d16a8b27.exe /quiet /passive /norestart
start /wait windowsxp-kb952287-x86-enu_5bee5928c09f4ee44bc41cab109022cec820e5ff.exe /quiet /passive /norestart
start /wait windowsxp-kb946648-x86-enu_288da0ecf75b20e972ad58dba0a382173b548ec1.exe /quiet /passive /norestart
start /wait windowsxp-kb952954-x86-enu_0c595b08d25326ffa929efe23e29b5848e7f39ec.exe /quiet /passive /norestart
start /wait windowsxp-kb951978-x86-enu_c4f54a2ade0b013fee8c71efcf60fd412dc0cd8c.exe /quiet /passive /norestart
start /wait windowsxp-kb951376-v2-x86-enu_e9b68c5e63acb5786a05b53b4332465de0ebcebd.exe /quiet /passive /norestart
start /wait windowsxp-kb950762-x86-enu_bfa04c9d2e62b4695d1bb8953486788c8a8c11e4.exe /quiet /passive /norestart
start /wait windowsxp-kb941569-x86-enu_55e8b619dd436e8be22c381fa8643a58b5f7c2a8.exe /quiet /passive /norestart
start /wait windowsxp-kb2808679-x86-enu_3b48f4913204d1d3353a4831f1b3e2e7d74cf26e.exe /quiet /passive /norestart
start /wait ie8-windowsxp-kb2632503-x86-enu_94363940faaac821987838e0face456ff93cac4e.exe /quiet /passive /norestart
start /wait ie8-windowsxp-kb2598845-x86-enu_cb0093da2dcc2413c01b871c929d9ba425eddef9.exe /quiet /passive /norestart
start /wait windowsxp-kb2492386-x86-enu_faf6a2d18dd48898b7534359b0cf211696a5e46d.exe /quiet /passive /norestart
start /wait windows-en-us-kb971513_c18df80f512a6d9cea206825b981e33c0973abec.exe /quiet /passive /norestart
start /wait wmp11-windowsxp-x86-enu_0581874009280c186f856f079594d1ccc7a851f4.exe /quiet /passive /norestart
echo All done, please reboot
I recommend naming this one '2.bat'. Those of you with a keen eye may note that some of the stuff installed previously is being reinstalled. This is what Windows Updated did on my computer! If you've installed the first one, you should be good to go:
@echo off
title  Updates for XP 32 bit part 2
@echo off
start /wait windowsxp-mscomppackv1-x86.exe /quiet /passive /norestart
start /wait windowsmedia11-kb939683-x86-enu_17d48a1cb35ad4f1cac39bd758158efe690730b5.exe /quiet /passive /norestart
start /wait windowsmedia11-kb929399-v2-x86-intl_50e2bc6b5e79909a0061043e6211600548368431.exe /quiet /passive /norestart
start /wait windowsmedia11-kb954154-x86-enu_9b75815f8c5d57dc8e2e22e221fb1a106f9ce6a0.exe /quiet /passive /norestart
start /wait windowsserver2003.windowsxp-kb963093-x86-enu_c53606bca846117e1cebe7dd9a37251cb84aa41d.exe /quiet /passive /norestart
start /wait windowsxp-kb952004-x86-enu_28e11ce4e9083f84c7b9903716904a94dc6b7280.exe /quiet /passive /norestart
start /wait windowsxp-kb970430-x86-enu_862d51f1d8e9ae7e08db9bb4b57e0841521a98fb.exe /quiet /passive /norestart
start /wait windowsxp-kb2345886-x86-enu_f0473cd9468a3585a5da8e906ab58ad95d1ded2d.exe /quiet /passive /norestart
start /wait windowsxp-windowsmedia-kb2834904-v2-x86-enu_c38814607addf93fb06e2d8e0e4b5c08e10857c3.exe /quiet /passive /norestart
Here's the last BAT file, although not the last step (see below). I recommend naming it 3.bat. This one REQUIRES that you have added the registry entry in the previous post (above). I suspect that if you forgot the registry entry and ran this, you'd see a bunch of error messages likely complaint that the EXE files aren't valid Win32 applications. If that happens, close the BAT, add registry entries and re-run the BAT.
@echo off
title  Updates for XP 32 bit part 3
@echo off
start /wait windowsxp-kb2926765-x86-embedded-enu_fd1b4b0791354fab04ae68907436cab0c8676665.exe /quiet /passive /norestart
start /wait windowsxp-kb2993651-x86-embedded-enu_60107e4eed4850513f41778ad3a9caef35d893b8.exe /quiet /passive /norestart
start /wait windowsxp-kb2993254-x86-embedded-enu_a56e76a2cc8404722e44a938849f114431788829.exe /quiet /passive /norestart
start /wait windowsxp-kb2998579-x86-embedded-enu_166f21272c3e54fa2430ca1231b65d870ac1a1bc.exe /quiet /passive /norestart
start /wait windowsxp-kb3013126-x86-embedded-enu_a7485236ec7df12c907ac232c4d8778df1936f43.exe /quiet /passive /norestart
start /wait windowsxp-kb3020393-v2-x86-embedded-enu_8eed034b5b679808bfb76c522cede9ab48e681e5.exe /quiet /passive /norestart
start /wait windowsxp-kb3021674-x86-embedded-enu_3fc15ebe581b61c1a30ab790f97d2fb2d7d41926.exe /quiet /passive /norestart
start /wait windowsxp-kb3004361-x86-embedded-enu_47e4ec000eca37d76a17a45d1f17ac181849b45b.exe /quiet /passive /norestart
start /wait windowsxp-kb3029944-x86-embedded-enu_ecdc1784751745ae36f14c6a964f1d9701baefad.exe /quiet /passive /norestart
start /wait windowsxp-kb3033889-x86-embedded-enu_97084ab0bd0fe1c7097c6d176d61d85cc28a3609.exe /quiet /passive /norestart
start /wait windowsxp-kb3035132-x86-embedded-enu_8e7607ac53706be4b440013f5c82725c2a94a6d2.exe /quiet /passive /norestart
start /wait windowsmedia11-kb3033890-x86-enu_3da047c27ca7b35c2a15e2bdf4a87fd7243e2b49.exe /quiet /passive /norestart
start /wait windowsxp-kb3065979-x86-embedded-enu_fe0a4fbb1fcb7c6062ae3ff88dcbf388f1ec4b07.exe /quiet /passive /norestart
start /wait windowsmedia-kb3067903-x86-enu_17cadd59515063d00d9f0d92d023ae1aa2349e4e.exe /quiet /passive /norestart
start /wait windowsxp-kb3078601-x86-embedded-enu_9f428ed1e710bced0702b4097846d36429a93202.exe /quiet /passive /norestart
start /wait windowsxp-kb3087039-x86-embedded-enu_06ac33315eaa9c1d4728cb19651e72cad6186a97.exe /quiet /passive /norestart
start /wait windowsxp-kb2957503-x86-embedded-enu_34e002ae983c5a61dced1e5cb41d81e714a6cfbd.exe /quiet /passive /norestart
start /wait windowsxp-kb3109560-x86-embedded-enu_ec8a3e049d5b27bbdbb091cd3ea2ffc6c725ffc5.exe /quiet /passive /norestart
start /wait windowsxp-kb3121918-x86-embedded-enu_0415f43e728e56f42bdc3171ec7d0f59221cafc7.exe /quiet /passive /norestart
start /wait windowsxp-kb3126593-x86-embedded-enu_28707de25730ebbb4d0e5f02d156dff431bc6e6d.exe /quiet /passive /norestart
start /wait windowsxp-kb3126587-x86-embedded-enu_b638c3dc6cc42839e8f73e46306791ebc7fc6709.exe /quiet /passive /norestart
start /wait windowsxp-kb3139398-x86-embedded-enu_1a601a891b38acd2b4e92ed4695646b74b66e1d9.exe /quiet /passive /norestart
start /wait windowsxp-kb3081320-x86-embedded-enu_d8e991e08445605d85c48425684c7850d1d63a36.exe /quiet /passive /norestart
start /wait windowsxp-kb3139914-x86-embedded-enu_44ee887d5f8da7d99a521b41e3c5ba9e4954de62.exe /quiet /passive /norestart
start /wait windowsxp-kb3140709-x86-embedded-enu_26891d26d98b012dd5b42112b7e692a5cae56cdf.exe /quiet /passive /norestart
start /wait windowsxp-kb3149090-x86-embedded-enu_ee6360c61fb2bc49278a0fcbcfb9c299af436857.exe /quiet /passive /norestart
start /wait windowsxp-kb3145739-x86-embedded-enu_e958811dbe4188202eda69cdc9e797a4ae1dc923.exe /quiet /passive /norestart
start /wait windowsxp-kb3161561-x86-embedded-enu_cf0ce9294706376c9c16f927ec915f5892f31213.exe /quiet /passive /norestart
start /wait windowsxp-kb3161949-x86-embedded-enu_0973436e841ac9a6697c9439f97c7d6ab66484f6.exe /quiet /passive /norestart
start /wait windowsxp-kb3170455-x86-embedded-enu_c49f5af4f42870c20dc1f5bc1c848405dc8ad197.exe /quiet /passive /norestart
start /wait windowsxp-kb3092601-x86-embedded-enu_8ddf39236405ff94407350f62daf3ab6e0fbca65.exe /quiet /passive /norestart
start /wait windowsxp-kb3178034-x86-embedded-enu_cb20691577ade771359e8a680e75d8f0872ff5f4.exe /quiet /passive /norestart
start /wait windowsxp-kb3196718-x86-embedded-enu_6b1d637604907623f8989b3d98c9e531b122c6cd.exe /quiet /passive /norestart
start /wait windowsxp-kb3198510-x86-embedded-enu_237a0e55e051d8e10cd5510b89e25bf2da64d508.exe /quiet /passive /norestart
start /wait windowsxp-kb4012583-x86-embedded-enu_cd150712980ded7ca5765a8fdd9a9dda860877b8.exe /quiet /passive /norestart
start /wait windowsxp-kb3185911-x86-embedded-enu_2ca7c76b25bdb5024f89b4754048d0b5f884c12e.exe /quiet /passive /norestart
start /wait windowsxp-kb4012584-x86-embedded-enu_04053061cb8d03ee685554dd351594fc6f0a12ab.exe /quiet /passive /norestart
start /wait windowsxp-kb4014652-x86-embedded-enu_c2702e4f1e63d06a320c139a853fd3a578d5e228.exe /quiet /passive /norestart
start /wait windowsxp-kb4014794-x86-embedded-enu_ffefa30f0b989917a75cd5474576c6155d17d420.exe /quiet /passive /norestart
start /wait windowsxp-kb4015383-x86-embedded-enu_f2891bd693ccc72eac9aba102aed25687df5a85c.exe /quiet /passive /norestart
start /wait windowsxp-kb4022747-x86-embedded-enu_9ee3ca3c99988ec3a9cade2073f461b39706c82c.exe /quiet /passive /norestart
start /wait windowsxp-kb4024323-x86-embedded-enu_42d69f9c232fb86657c938a507388bcdf5043483.exe /quiet /passive /norestart
start /wait windowsxp-kb4025218-x86-embedded-enu_be6f91dc331c23cbb6ce78f41a3c3976fa62f904.exe /quiet /passive /norestart
start /wait windowsxp-kb4026061-x86-embedded-enu_c9e64b9686dae23b9e299fd13669019f174e26b8.exe /quiet /passive /norestart
start /wait windowsxp-kb4025497-x86-embedded-enu_4a37e35189bb8bbdc561962c3ea6e500638fccf5.exe /quiet /passive /norestart
start /wait windowsxp-kb4025409-x86-embedded-enu_3afe33a68dfc323b223c6573670bbafddcdf82f4.exe /quiet /passive /norestart
start /wait windowsxp-kb4034775-x86-embedded-enu_0c5c2f6822400aaf9fb2daf450e6373be2255e75.exe /quiet /passive /norestart
start /wait windowsxp-kb3183431-x86-embedded-enu_e1867d355002ce685fbffb06f364d2f003b9afcd.exe /quiet /passive /norestart
start /wait windowsxp-kb4047211-x86-embedded-enu_217f80951ee111cf78ea67a854c2919ddc94dceb.exe /quiet /passive /norestart
start /wait windowsxp-kb4052303-x86-embedded-enu_04ab266aa0752613a9b6c68ff33d40699a0045e5.exe /quiet /passive /norestart
start /wait windowsxp-kb4056941-x86-embedded-enu_24ebcc41e3f03048c25cf02d8d8ab6107479aabd.exe /quiet /passive /norestart
start /wait windowsxp-kb4089175-x86-embedded-enu_1caf7f6ec0b27d38070eb0385f1548776bc65e6d.exe /quiet /passive /norestart
start /wait windowsxp-kb4089082-x86-embedded-enu_56a4c587452f40f8e91f3192168f4cf1193e801c.exe /quiet /passive /norestart
start /wait windowsxp-kb4089694-x86-embedded-enu_f0698bdbb2c0dbaf56d7c4071061046865ec3526.exe /quiet /passive /norestart
start /wait windowsxp-kb4039384-x86-embedded-enu_6aabfe977264b12c8331500d97053134de7d0738.exe /quiet /passive /norestart
start /wait windowsxp-kb4091756-x86-embedded-enu_4084e5a3bf76e0a22d8d33b0c5e8ff3b57e3faf3.exe /quiet /passive /norestart
start /wait windowsxp-kb4130957-x86-embedded-enu_dab532721ce76725b35909e6d95c9d430edc1e13.exe /quiet /passive /norestart
start /wait windowsxp-kb4101477-x86-embedded-enu_867ee71e20e05bcdcab83b86466ab20771f74ac5.exe /quiet /passive /norestart
start /wait windowsxp-kb4056564-v2-x86-embedded-enu_964310efb26058c35b0233f008f8b5f6ffd102af.exe /quiet /passive /norestart
start /wait windowsxp-kb4089453-v2-x86-embedded-enu_23b1aec8d9e41242c20799e66045dc75c089df61.exe /quiet /passive /norestart
start /wait windowsxp-kb4294413-x86-embedded-enu_b211e66c425fcef8980fd16953483282cb4e6b14.exe /quiet /passive /norestart
start /wait windowsxp-kb4291391-x86-embedded-enu_a48bc4ba244b5a49d0191900c5f65f60e1568579.exe /quiet /passive /norestart
start /wait windowsxp-kb4343674-x86-embedded-enu_ca27aebe8d7a210ffbc67934c144627a9d6f5463.exe /quiet /passive /norestart
start /wait windowsxp-kb4041995-x86-embedded-enu_acee429ab4e7445545ac73a97f390628e647c1cf.exe /quiet /passive /norestart
start /wait windowsxp-kb4458000-x86-embedded-enu_cd9e39263c1b198b9d0a22529100434d3bd20e90.exe /quiet /passive /norestart
start /wait windowsxp-kb4458318-x86-embedded-enu_d2751e7d4cd301c51c010f1d193d909e64ba8466.exe /quiet /passive /norestart
start /wait windowsxp-kb4458006-x86-embedded-enu_e96b950633bde3636cffe6629b30f424acc90daf.exe /quiet /passive /norestart
start /wait windowsxp-kb4462935-x86-embedded-enu_b5de399aa37284c81ca1e26ffb93893db035ec17.exe /quiet /passive /norestart
start /wait windowsxp-kb4462987-x86-embedded-enu_2ca3c3b7b4e2f9bee24af4e46eeb7e4624aabd3d.exe /quiet /passive /norestart
start /wait windowsxp-kb4458001-x86-embedded-enu_b6ae71b9b58128d4c6a3221208c1e42d0d434f79.exe /quiet /passive /norestart
start /wait windowsxp-kb4463103-x86-embedded-enu_1d7cc48a7f1902bdd5953a1ab980db5832631339.exe /quiet /passive /norestart
start /wait windowsxp-kb4463573-x86-embedded-enu_b0e76ad95da29d0ce8ba122a6b703660b93ed49b.exe /quiet /passive /norestart
start /wait windowsxp-kb4470118-x86-embedded-enu_eb3fe70a186545d1745f48eda37ecf21a1d330d9.exe /quiet /passive /norestart
start /wait windowsxp-kb4467689-x86-embedded-enu_b974cbc4675474ddb38c41f7926f493cde207eee.exe /quiet /passive /norestart
start /wait windowsxp-kb4473077-x86-embedded-enu_2472bfb0a1921bccc30621166b26004b22203e63.exe /quiet /passive /norestart
start /wait windowsxp-kb4468323-x86-embedded-enu_6a46468fe73b3b793934d70768ab2c4ce11a03ab.exe /quiet /passive /norestart
start /wait windowsxp-kb4486463-x86-embedded-enu_8ab6c1cbd442dbdd8667993af4ee093abf09fb41.exe /quiet /passive /norestart
start /wait windowsxp-kb4457163-x86-embedded-enu_6079ca40413cb788b625ebc6c4b8b802fa3bca57.exe /quiet /passive /norestart
start /wait windowsxp-kb4487086-x86-embedded-enu_d87dffd2310c8df09892de204e6216bb447ad0db.exe /quiet /passive /norestart
start /wait windowsxp-kb4489493-x86-embedded-enu_bf5786db231541e562a8f4dececac9b8fdc3cdce.exe /quiet /passive /norestart
start /wait windowsxp-kb4490228-x86-embedded-enu_a81c03f3f775390169d890d6f99cd9d3e58cc62e.exe /quiet /passive /norestart
start /wait windowsxp-kb4489973-x86-embedded-enu_1c50f081b27c440d89300b59cd5df9ed689390b0.exe /quiet /passive /norestart
start /wait windowsxp-kb4490501-x86-embedded-enu_c0b31474df5c52c3f1794914050fdf27b0692c65.exe /quiet /passive /norestart
start /wait windowsxp-kb4490385-x86-embedded-enu_47b193ff117da1c86efc4d275b52a829c5cb00b9.exe /quiet /passive /norestart
start /wait windowsxp-kb4486468-x86-embedded-enu_491ec2dcd578becacf2ec08f65b6c6f62ca3822c.exe /quiet /passive /norestart
start /wait windowsxp-kb4486538-x86-embedded-enu_b46b867293bb21b12fe5867ff98806a98ae50fa2.exe /quiet /passive /norestart
start /wait windowsxp-kb4486536-x86-embedded-enu_4dd89d4cfab9ba6526747646e320adf407b6ece4.exe /quiet /passive /norestart
start /wait windowsxp-kb4486465-x86-embedded-enu_80c4f32abd257968871a840fd4d87cfedd0b3d4b.exe /quiet /passive /norestart
start /wait windowsxp-kb4493341-x86-embedded-enu_cfd32e1875c216557e94e1763fbc114c216d6b0c.exe /quiet /passive /norestart
start /wait windowsxp-kb4489977-x86-embedded-enu_e1b835d2c684f2953946a414fddc7fe40ef6eec2.exe /quiet /passive /norestart
start /wait windowsxp-kb4489974-x86-embedded-enu_fb9d178e51321bf47246a752c2d79dcfe6bada40.exe /quiet /passive /norestart
start /wait windowsxp-kb4487989-x86-embedded-enu_3c32c4f284fcd7208b3cf4428320e95a27513c3a.exe /quiet /passive /norestart
start /wait windowsxp-kb4491443-x86-embedded-enu_38dcb7ca4adee2236e202651b1a9feff15123fc5.exe /quiet /passive /norestart
start /wait windowsxp-kb4486924-x86-embedded-enu_49ea7629701a23dd3dbf3c21e60af54eec3baf19.exe /quiet /passive /norestart
start /wait windowsxp-kb4487085-v2-x86-embedded-enu_667f051ffe98ff99495e9b6ede2b8c321aba1ca3.exe /quiet /passive /norestart
start /wait windowsxp-kb4494059-x86-embedded-enu_58109e2522cd4e5b41840ce5d24931d52e421f72.exe /quiet /passive /norestart
start /wait windowsxp-kb4493797-x86-embedded-enu_40d780178b80a6bd6b4398ca1ca3e47973997b0b.exe /quiet /passive /norestart
start /wait windowsxp-kb4493796-x86-embedded-enu_92495fc42b0bf0fd51baa584af55f02b7d8deaa5.exe /quiet /passive /norestart
start /wait windowsxp-kb4493927-x86-embedded-enu_4123fcdc99a7976cd5791f78536a0585e0264462.exe /quiet /passive /norestart
start /wait windowsxp-kb4493795-x86-embedded-enu_9a084800b33b40776da30e70293cccfe4b0342f5.exe /quiet /passive /norestart
start /wait windowsxp-kb4493793-x86-embedded-enu_c238b0eab410f55d9b8fdc7485eba2ba0459559a.exe /quiet /passive /norestart
start /wait windowsxp-kb4493563-x86-embedded-enu_b7acbe01322ca903c920fa8a85328057ba2d9703.exe /quiet /passive /norestart
start /wait windowsxp-kb4493794-x86-embedded-enu_89c4913943e563851bd4c458f222aee21edb7bb3.exe /quiet /passive /norestart
start /wait windowsxp-kb4487990-x86-embedded-enu_8a1f84ccfc4cdcb9536864fa91ae82ef62cb3e79.exe /quiet /passive /norestart
start /wait windowsxp-kb4495022-x86-embedded-enu_6fce82c569aa5a6af6ff63769b2e901032d401ee.exe /quiet /passive /norestart
start /wait ie8-windowsxp-kb4493435-x86-embedded-enu_1029e7193ca4b683d1d0c1996bc7c66f1a2ae37f.exe /quiet /passive /norestart
start /wait windowsxp-kb4493790-x86-embedded-enu_e078da675e389cbfaba2354eae8040e438a42476.exe /quiet /passive /norestart
start /wait windowsxp-kb4494528-x86-embedded-enu_77ead5923f0753b90d935f2d6546886b063a6fe1.exe /quiet /passive /norestart
start /wait windowsxp-kb4019276-x86-embedded-enu_3822fc1692076429a7dc051b00213d5e1240ce3d.exe /quiet /passive /norestart
start /wait windowsxp-kb4459091-x86-embedded-enu_6f260244fafd69643591ded6624997eb2211b627.exe /quiet /passive /norestart
start /wait windowsxp-kb4467770-x86-embedded-enu_f61e16be7e32887953b29ae1b8ba90064f3ef0a5.exe /quiet /passive /norestart
Final Steps:
Open CMD, type 'regsvr32 MSI.DLL'. Apparently, Microsoft is as forgetful as I am :lol:
Download and install (just double click) the following:
Security Update for Windows XP SP3 (KB4500331)
Reboot if advised.
2019-10-09 02:10 »
FYI, if you don't want the BAT files to close automatically when finished add two lines to the end of them:
@echo off
pause
2019-11-26 02:36 »
I've found a couple of minor issues here, nothing too big. In my '1.BAT', the installer for Windows Media Player 11 (it's the next to last line in the BAT) does not like the '/quiet /passive /norestart' switches, change it to simply be '/q'.
In the downloads under the heading 'XP Embedded /WEPOS 2009 updates/patches', the 15th download (kB3067903) needs changed to:
I accidentally linked to an update for WMP 10, not 11. Hence, my '3.bat' needs the line that reads:
Changed to read:
start /wait windowsmedia-kb3067903-x86-enu_510155e48bfc1c08e7f2023fde514be960fa8fed.exe /quiet /passive /norestart
For those of you that already downloaded, you'll need to update your 1.BAT and 3.BAT and add the download to the files. Eh, there's always a price to pay for trying to do the right thing, you'll eventually end up with egg on your face! :lolno: Perhaps I was just out to screw Windows Media Player :lol:
2019-12-28 09:01 »
Okay, I'm about to roll out the non-ENU files. Up front, KB973688 & KB954430 (MSXML 4 related) aren't available in all languages. Kind of a dumb situation, It's officially dead according to MS, the languages that they are available in are getting SP2 related updates when there is an SP3, however, from my understanding, SP3 won't necessarily act like a drop-in replacement for SP2. My advice is if it's not available in your language, just skip it. KB963093 seems to be available only in ENU flavor, but MS point non-ENU users to that version, so that's what I'm dropping in all of the languages. I'm not gonna review everything here, READ the first post to see what all you need (visit other post to get the REG file), system requirements, blah, blah, blah. The one thing I will review:
Install SP3, reboot then install IE 8 and reboot before anything else.
2019-12-28 09:28 »
GERMAN - DEU
Official XP
1. WindowsXP-KB936929-SP3-x86-DEU.exe
2. IE8-WindowsXP-x86-DEU.exe
3. windowsxp-kb979309-x86-deu_3e1a2e3af2ab2b5c1525aa602dd3ab1905472f6d.exe
4. windowsxp-kb2922229-x86-deu_f0711f46d90d9a766d72ec97c512900963d2e3cc.exe
5. windowsxp-kb2929961-x86-deu_0a2900b3bda9aa199c61a71c63ca08baa96257b3.exe
6. windowsxp-kb2930275-x86-deu_69ab05af480a85766f433ee8a2163f675e8809cb.exe
7. windowsxp-kb2916036-x86-deu_9f9ba12140602d97b79932a0917943129466e591.exe
8. windowsxp-kb2914368-x86-deu_249e0a5cc0b07eb3afb1e94837e652a931442ff4.exe
9. windowsxp-kb2898715-x86-deu_fd961b8df3d9c3a5d099be974ef2fccf4527b509.exe
10. windowsxp-kb2892075-x86-deu_698f477b8ad4b1954b0044d8fef169787d1b81a1.exe
11. windowsxp-kb2893294-x86-deu_e00580c5ae6e30bdaa55d05d7acd1fe935ca6cd8.exe
12. windowsxp-kb2904266-x86-deu_8b895dc10f22e3666058826b90a6b50c302ec920.exe
13. windowsxp-kb2900986-x86-deu_9429ffa1be5ad2b9d6008779065316de523967ad.exe
14. windowsxp-kb2876331-x86-deu_3b9b168f17fb512761f2ec902695f8b44309da59.exe
15. windowsxp-kb2868626-x86-deu_6574daf82ea780a306b560f9d7fb65ffccc42710.exe
16. windowsxp-kb2862152-x86-deu_ec84928c2543f65d5efb65fecf26c714aa85cf4f.exe
17. windowsxp-kb2847311-x86-deu_dfe4788da5858c2cc15d928f200277004432caee.exe
18. windowsxp-kb2868038-x86-deu_47a86a447bf85ca369c725fb60e78a928e7f8c31.exe
19. windowsxp-kb2862330-x86-deu_0392603ebd5b4a4d6b9d8316848d2a1ac02c9fa9.exe
20. windowsxp-kb2862335-x86-deu_66f0e30bf64ec53f06cbb2ed50b3432c6ab883d8.exe
21. windowsxp-kb2876217-x86-deu_24f89878e747523ebf0027e3c149a8cc8d885fd5.exe
22. windowsxp-kb2864063-x86-deu_9a32f7b0b8e9f9b4e39fbb3888efa0820833f190.exe
23. windowsxp-kb2850869-x86-deu_4a1aef1a234db8cabfaf453a3016ae71b5fa48e6.exe
24. windowsxp-kb2859537-x86-deu_843af427d7f01d1be0534bd1acdb15e09edd6692.exe
25. windowsxp-kb2834886-x86-deu_2c6a50afab0699a695f9982f422a5600f14387ad.exe
26. windowsxp-kb2820917-x86-deu_54a356db283484eeef1ebb2c4ae501ed9b02fdac.exe
27. windowsxp-kb2813345-x86-deu_fff78723399a160f0ef5ea8464c330d353dee372.exe
28. windowsxp-kb2807986-x86-deu_81cf84d194e497d17d121339fee7e40a649c57e8.exe
29. windowsxp-kb2802968-x86-deu_cc2e26212a1cc31f445a2e1657b1fb134e188441.exe
30. windowsxp-kb2780091-x86-deu_1951b68e37cd197c514290a4aa8fb13a04b2f532.exe
31. windowsxp-kb2757638-x86-deu_5a373e3a5d691e1d9c107aba574faf1908bf37e8.exe
32. windowsxp-kb2770660-x86-deu_e9f0de1cb45d7787556c9a0bfa31554b5e7a1c14.exe
33. windowsxp-kb2727528-x86-deu_13014815790c88ff394f2c8222af2cf025d3cd3f.exe
34. windowsxp-kb2749655-x86-deu_e4f567daef3c747bd05c6496551f2a44711f56ef.exe
35. windowsxp-kb2723135-v2-x86-deu_d845674dff261cf38eb33742d2627d6b0019c329.exe
36. windowsxp-kb2705219-v2-x86-deu_6fe7594a28b57fd5df634f56fc706bd0fd909263.exe
37. windowsxp-kb2691442-x86-deu_70cef96791363c05945cbfade0c7cbd584e5e9f5.exe
38. windowsxp-kb2655992-x86-deu_d890cdee5195beecdd58ec8bd39411d9506aa5ba.exe
39. windowsxp-kb2719985-x86-deu_89cfb585d9bae95458688c7c60cb7883b2ce2d02.exe
40. windowsxp-kb2698365-x86-deu_ba2932468abf61140209cd9b830ee82c0863876d.exe
41. windowsxp-kb2712808-x86-deu_b346436913e51fc5b9d55f95b333736e584851d0.exe
42. windowsxp-kb2686509-x86-deu_41866a33f633d6ea16224b02ccc453b404e2c4b2.exe
43. windowsxp-kb2676562-x86-deu_4515afac9b5a2f32d7e0ac4af1c34c819cb7bb3f.exe
44. windowsxp-kb2653956-x86-deu_9b37ce09be3868832449ee523fe9a6d25ce0d892.exe
45. windowsxp-kb2659262-x86-deu_c14b5d8a99bbd688012f0e6ec9c52e6d31ad2f08.exe
46. windowsxp-kb2661637-x86-deu_b7f29e582363039f980920b632fd69e75a3d128d.exe
47. windowsxp-kb2584146-x86-deu_2fe976d6c593518d89ed0ff78b4d7bc4d8c988f5.exe
48. windowsxp-kb2631813-x86-deu_84124669ee4f9eb306ba38281d73402848034333.exe
49. windowsxp-kb2585542-x86-deu_891ed1275a11717ee27a92a0b7fecd3a2044eebf.exe
50. windowsxp-kb2603381-x86-deu_f13229c95a912a90c6bff999788755373a8488f8.exe
51. windowsxp-kb2598479-x86-deu_285fe1ba2caedc7fa6cae307bd3445c77a794b5b.exe
52. windowsxp-kb2619339-x86-deu_54a23a32127000d7cab89f2b3bd20cea70f64f2d.exe
53. windowsxp-kb2620712-x86-deu_a6c807504e6c5ed758f73607b638ccf3423923a6.exe
54. windowsxp-kb2544893-v2-x86-deu_69b5503b11129c3de7c7d7b6d0b158b1702f0674.exe
55. windowsxp-kb2592799-x86-deu_651e608ec6bca1519ae8199c55390bf13ad005a9.exe
56. windows-de-de-kb2564958_8ae021f34b5b17a6322fc51754bf82be541b8a75.exe
57. windowsxp-kb2570947-x86-deu_e017ccd1cfb5be140cd77f84ab9cbbe13c5a8769.exe
58. windowsxp-kb2566454-x86-deu_02a718d10f5f4f93643ba7152bf126bf589d905c.exe
59. windowsxp-kb2536276-v2-x86-deu_9ca23d04a59888583de60c916b72f1dfb1c9079b.exe
60. windowsxp-kb2507938-x86-deu_f3b9036d4b2671cc2d29b8157841aa45d639c1e0.exe
61. msxml4-kb973688-deu_85a572e14263dbee4526979b9b52d1b0f10b90a9.exe
62. msxml4-kb954430-deu_490ad43316dfe4057db3495324916c910f3fec1b.exe
63. windowsxp-kb2535512-x86-deu_7044d3217d7d39ba0c17f9f9f607e45190291cf3.exe
64. windowsxp-kb2485663-x86-deu_d2624922cefad4ae97acaf5693a49e925932e63a.exe
65. windowsxp-kb2508429-x86-deu_e3c57486f0caf8e4bd387d2f7dbcd3ce0229d6ba.exe
66. windowsxp-kb2506212-x86-deu_da2b388c036e4f58c1f067b2ed74cb04dd55dd1b.exe
67. ie8-windowsxp-kb2510531-x86-deu_d10cd98099f115059086ee9317ec42103c6b4b05.exe
68. windowsxp-kb2509553-x86-deu_072f198c63c516291d4e6e25ddd2bc2e1427a514.exe
69. windowsxp-kb2479943-x86-deu_5c6bc52fe2a7f3b6adec195df49319dff4187413.exe
70. windowsxp-kb2481109-x86-deu_2b876e8edef06a4c7a36f119bcbf7a6decfe180d.exe
71. windowsxp-kb971029-x86-deu_751a12c16dac9774fe378fd0a78929bfdc5ce6ef.exe
72. windowsxp-kb2478971-x86-deu_6e4e9a157b66402750f5abb808b5df703f94aa43.exe
73. windowsxp-kb2483185-x86-deu_a4c9c996e40da68682223d35fa7c20e5da173a61.exe
74. windowsxp-kb2478960-x86-deu_9631f562454698341d0cf2f58f52c5a52c37ba9f.exe
75. windowsxp-kb2393802-x86-deu_4c75a0f0aa12ab09de03dd7c4e38bdb919dfb261.exe
76. windowsxp-kb2419632-x86-deu_fafc7b5cd1c46445357cedb084c9665b5ea04613.exe
77. windowsxp-kb2423089-x86-deu_913718d290c409cfe20abe06ecbbea2cb0709680.exe
78. windowsxp-kb2443105-x86-deu_272fa59814c106f9be133c7b11f9f5cdd38e4952.exe
79. windowsxp-windowsmedia-kb975558-x86-deu_547fccf8d5b076c60646f33a653e090a57d85295.exe
80. windowsxp-kb979687-x86-deu_56cf26f775d48283d3a478e3de9c77f7606ae394.exe
81. windowsxp-kb2296011-x86-deu_f3d62a877f30f18324908ba97f2a2302ea1e4981.exe
82. windowsxp-windowsmedia-kb2378111-x86-deu_5ecc5bc343c6fafdd6a55f2145a29ce9068d4cf1.exe
83. windowsxp-kb2387149-x86-deu_fb2b8366d355bb911a06607d6d65128e9d65472e.exe
84. windowsxp-kb982132-x86-deu_36f5651b05b27350d86ab2fda4c3f0c7c7446772.exe
85. windowsxp-kb2347290-x86-deu_4d4057af1813129c9822188a0d5c2d928ef2dcc2.exe
86. windowsxp-kb2115168-x86-deu_5c7103c23635aa7739ad3604ece9c40e39529bb7.exe
87. windowsxp-kb982665-x86-deu_4ffbcdd33ec002182869e84ff41ad6ab32925b65.exe
88. windowsxp-kb981997-x86-deu_eda4bb238e0c1f715f1577539b5b74c1fb741bb5.exe
89. windowsxp-kb2229593-x86-deu_656064c08387c51c6612c92477ebc4ed6e390396.exe
90. windowsxp-windowsmedia-kb978695-x86-deu_087108b470354b3d1f4bbf6d8983e38c1f1fb0bf.exe
91. windowsxp-kb979482-x86-deu_479364d026a7ba444ae176b084a9b7a200c61e88.exe
92. windowsxp-kb978542-x86-deu_5c4175999da446364a8d823d8a442d41f83355d4.exe
93. windowsxp-kb977816-x86-deu_0b72bcdaceca4a8132a6121e1623e1e811562ee0.exe
94. windowsxp-kb978338-x86-deu_134f94e894466a0b66f3d5d2f755665cc6d7ee1c.exe
95. windowsxp-kb975713-x86-deu_a4233e6225ab2fa84605de14d8d24c8cc1cff3f5.exe
96. windowsxp-kb975560-x86-deu_a387d1718237fac06f8e07a7db8cf97190680142.exe
97. windowsxp-kb977914-x86-deu_5718766a6e2637f2223b78b4239ce85eca28df7f.exe
98. windowsxp-kb978706-x86-deu_b23b1963e63c8acba8a4c644d18019341ce384d2.exe
99. windowsxp-kb972270-x86-deu_3215b9c387f599d73d209ac22b7ab68423566016.exe
100. windowsxp-kb974318-x86-deu_fe1fa5176c77394b20e6bc4396b35e2825623074.exe
101. windowsxp-kb974392-x86-deu_cf110bf3e66aca3752ab0661cf1de1e057e6e2d5.exe
102. windowsxp-kb973904-x86-deu_777e2b1954656bff6005cbacef2d8755d1f27530.exe
103. windowsxp-windowsmedia-kb952069-v2-x86-deu_87f9aeeaf57dbc86ff31eb9b856d18a42e308738.exe
104. windowsxp-windowsmedia-kb954155-x86-deu_ae8c7d6d385108c7a3749ed30bd1c0b560dd13bb.exe
105. windowsxp-kb975025-x86-deu_5ac01419cb805a842f8ca75d4652d6bd45083325.exe
106. windowsxp-kb974571-x86-deu_9601a32f9ebcd7acf50463bde877ddbcd6f3074f.exe
107. windowsxp-kb974112-x86-deu_9e899c0fbfe06daae43b9df2fa4adc210540cbbe.exe
108. windowsxp-kb969059-x86-deu_44baf6c9d9390647b73f6f147f3db92539612826.exe
109. windowsxp-kb975467-x86-deu_547a3c495e277458431e5b69295a4ea05e04e51d.exe
110. windowsxp-kb968389-x86-deu_c5099895340d6c67cf867c11e1c951fb40298a7b.exe
111. windowsxp-kb956844-x86-deu_4f2537ad7b78febd66d5534bc230b96038ba3c36.exe
112. windowsxp-windowsmedia-kb973540-x86-deu_f2e2cb9b65fc6cc20a0b466b5a677f4341ed1b97.exe
113. windowsxp-kb973869-x86-deu_c7a9d1b53f1631078b3c162af045b7dd94dddd44.exe
114. windowsxp-kb973507-x86-deu_b6cf429401128937303082f3d44bde64310a570b.exe
115. windowsxp-kb960859-x86-deu_739f567460b0fc38bb9578af93a6c43d31df6a47.exe
116. windowsxp-kb973815-x86-deu_1869f3c2d3bf48239589171ed9f48e42167851a3.exe
117. windowsxp-kb971657-x86-deu_3afe87d70dac8a6352b392d92b863053b3c3badc.exe
118. windowsxp-kb923561-x86-deu_3f1dee678b66f2ecf08570ae198696601f0a9c98.exe
119. windowsxp-kb956572-x86-deu_99122b3a29b7455624721aaca0c8c4241e78d2ab.exe
120. windowsxp-kb960803-x86-deu_3ca32c0b863aed207a4907d058841ea0355e6859.exe
121. windowsxp-kb959426-x86-deu_76263d1e1f49d927517c49f2c570e5f3af84847c.exe
122. windowsxp-kb950974-x86-deu_afb216e90fdbc32bd7df4ad41ce7ea09f89ceb5a.exe
123. windowsxp-kb952287-x86-deu_5e44d3ec9b6500ca6bfc3fa4f6dd0dd946aa7235.exe
124. windowsxp-kb946648-x86-deu_2415eede56fe688aae38f149eb8b0cb8ab9fe6da.exe
125. windowsxp-kb952954-x86-deu_950750b938475f80ff21c18632d7a418e8dc0e02.exe
126. windowsxp-kb951978-x86-deu_a4881b5352c37c557630d8b8db9cb8b246704601.exe
127. windowsxp-kb951376-v2-x86-deu_b15635c29bcf1214e5c4388923a9c924ac1c55d4.exe
128. windowsxp-kb950762-x86-deu_97bf711d852b723bbde49390295c42170e50b087.exe
129. windowsxp-kb941569-x86-deu_e41b608297acf4070c229f8f62b639c3c3af5fea.exe
130. windowsxp-kb2808679-x86-deu_8672086a45f0a40601e78a949fe2c0a3674c94e0.exe
131. ie8-windowsxp-kb2632503-x86-deu_ced434b2dc224fc2f8bab211ff597cc61cc04885.exe
132. ie8-windowsxp-kb2598845-x86-deu_abbfddc2fa764ce5453da2b666b518a19755fbc9.exe
133. windowsxp-kb2492386-x86-deu_bfaa8daf2765df2b5e4da1ff48cdf1f415872197.exe
134. windows-de-de-kb971513_e47749e7458c92e0db84293439ce2f85f778ab0c.exe
135. wmp11-windowsxp-x86-de-de_421436944b0bb18a0e9c1a8e61cb91ad2abfab6a.exe
136.
137. windowsmedia11-kb939683-x86-deu_e142439cf38fff3aa54a91c40f54f2606bf9c208.exe
138. windowsmedia11-kb929399-v2-x86-intl_50e2bc6b5e79909a0061043e6211600548368431.exe
139. windowsmedia11-kb954154-x86-deu_349589c31d3210e102f97936fb7d8e97030fde8e.exe
140. windowsserver2003.windowsxp-kb963093-x86-enu_c53606bca846117e1cebe7dd9a37251cb84aa41d.exe
141. windowsxp-kb952004-x86-deu_ad282f76179619c2f125922683fc397762cbb59a.exe
142. windowsxp-kb970430-x86-deu_b8ce3c948a2af96849f12cd925932a9878e32c4a.exe
143. windowsxp-kb2345886-x86-deu_a5b3a537bd6297a9ebf159e350d9a6ade66a8517.exe
144. windowsxp-windowsmedia-kb2834904-v2-x86-deu_15ce3ab9e814e274e28a30374a51b652ca2eb1a1.exe
POS 2009:
145. windowsxp-kb2926765-x86-embedded-deu_5bd881de9013125045e38aabcd01cb2f4afc9db7.exe
146. windowsxp-kb2993651-x86-embedded-deu_2868e8443780d722e627b131c341660d30d0f461.exe
147. windowsxp-kb2993254-x86-embedded-deu_2783a701fcc211ab1937c22f4dc3b726d4e5333f.exe
148. windowsxp-kb2998579-x86-embedded-deu_31be7198c1f5d83302f8b005da9fa6a3c8fe84f5.exe
149. windowsxp-kb3013126-x86-embedded-deu_f077765211e6a732790fedbf083cf079bffe460e.exe
150. windowsxp-kb3020393-v2-x86-embedded-deu_a2de018b26cd7de64fd42c11eef9d3d2ab83c9f0.exe
151. windowsxp-kb3021674-x86-embedded-deu_7083998fa4ac36a6f28907d800b2f9615014e276.exe
152. windowsxp-kb3004361-x86-embedded-deu_74d3f625c4044ba4a2907e2c9c80bd3364a85bb4.exe
153. windowsxp-kb3029944-x86-embedded-deu_ee007a29d1d6fa59d6862ab02c56d41a34bb739e.exe
154. windowsxp-kb3033889-x86-embedded-deu_53f4df68bb412393ca64eef72aea63abf1facfad.exe
155. windowsxp-kb3035132-x86-embedded-deu_4cfc27ada29a6f7b83e3134f43256ade22c6f547.exe
156. windowsmedia11-kb3033890-x86-deu_5a12d27c63747f10dec45e648a78ac04ef38f583.exe
157. windowsxp-kb3065979-x86-embedded-deu_51736dcbb99339cc6c00a1aa3032345a100b7e03.exe
158. windowsmedia-kb3067903-x86-deu_d52c6d232498d52841fd3f230321156f2b900014.exe
159. windowsxp-kb3078601-x86-embedded-deu_62688e57781f27b87278c89e7c29f433b9979954.exe
160. windowsxp-kb3087039-x86-embedded-deu_d2df59bbb7583b79d613f1e91ed3f1faac4aa99c.exe
161. windowsxp-kb2957503-x86-embedded-deu_6a47e96c8b468dade7ceaf2c60c704321296b59f.exe
162. windowsxp-kb3109560-x86-embedded-deu_c344bb6ffe7820575314d4df93acd94119dc6be5.exe
163. windowsxp-kb3121918-x86-embedded-deu_0ee06b64e1d6e1617b6ed9b2d696fb7f88c3ac60.exe
164. windowsxp-kb3126593-x86-embedded-deu_7c62688e67961e68f135855a0d2cc5f7d9d96cf2.exe
165. windowsxp-kb3126587-x86-embedded-deu_a5b45596cba97035e50c619a58a9d243c41f2dad.exe
166. windowsxp-kb3139398-x86-embedded-deu_e22144a682f0faa7944785dd209fe20ad0dd6efd.exe
167. windowsxp-kb3081320-x86-embedded-deu_9af777598ce7ec7a36e360e769d57685305cab7d.exe
168. windowsxp-kb3139914-x86-embedded-deu_96b928ab4654b78b4c5d275c9302c74698cdb3c1.exe
169. windowsxp-kb3140709-x86-embedded-deu_68ac7c2ce54309b9d03d31b24256d897e6012062.exe
170. windowsxp-kb3149090-x86-embedded-deu_e3a36e80ee52637264f5323e073ac990105903c4.exe
171. windowsxp-kb3145739-x86-embedded-deu_d9515c11cfdde0fc78729d4c7ae839d74f87bf68.exe
172. windowsxp-kb3161561-x86-embedded-deu_e05755f96d6ceb4050e53be977f897cf8c7bc8f5.exe
173. windowsxp-kb3161949-x86-embedded-deu_6652e7dfd2c0b124e72fada9c14465503cb07e7b.exe
174. windowsxp-kb3170455-x86-embedded-deu_54a4201c6387bbb211d15a3c99344d35f2768dbd.exe
175. windowsxp-kb3092601-x86-embedded-deu_5a9965419415d9ab9d0ee67c4fc57dea350ed2e4.exe
176. windowsxp-kb3178034-x86-embedded-deu_0d8d9cff062ab7e1770ca7b8e48f5cbaf154ce36.exe
177. windowsxp-kb3196718-x86-embedded-deu_358d918d27c66292363a5002bc3a1df39fe206c7.exe
178. windowsxp-kb3198510-x86-embedded-deu_c5fab81f62a2e3516207c9cb6979ed22cf8e60be.exe
179. windowsxp-kb4012583-x86-embedded-deu_f4cbfe31341c4c003abe44c95fd984a0f0b0b6da.exe
180. windowsxp-kb3185911-x86-embedded-deu_9c19c24de034e64957f378c37964f3245a19731b.exe
181. windowsxp-kb4012584-x86-embedded-deu_da2c437f17e81caa40cd0924eba4539968a4aede.exe
182. windowsxp-kb4014652-x86-embedded-deu_10ada6ca41ce53fcf4dc7d77a58b7c0bec188d30.exe
183. windowsxp-kb4014794-x86-embedded-deu_c42a2c191c00b3d186c3f01c5aa3ce8b90d58e67.exe
184. windowsxp-kb4015383-x86-embedded-deu_56c2fdf072155c4f802c75ffe5d40768629894d3.exe
185. windowsxp-kb4022747-x86-embedded-deu_e1eaf8b50be6dbe18c56b9faeb0e909705d197c3.exe
186. windowsxp-kb4024323-x86-embedded-deu_455a3982800a273f67ec2c2a707b01c067452cf1.exe
187. windowsxp-kb4025218-x86-embedded-deu_d930729261f179e2f7ad16844621d53269b22b81.exe
188. windowsxp-kb4026061-x86-embedded-deu_4b6283af355d55f7935ff0dfa6a9cb38ba086bdb.exe
189. windowsxp-kb4025497-x86-embedded-deu_c4fa2017a37f31baaa0236943faa5e9e8fa44f4e.exe
190. windowsxp-kb4025409-x86-embedded-deu_8624ee3d166c9215eff72ca080f59614cc141ab3.exe
191. windowsxp-kb4034775-x86-embedded-deu_1b0a406f727aa30a20d1db37b299b02e0b2723da.exe
192. windowsxp-kb3183431-x86-embedded-deu_d6100e9e1c5d85eeaeb1bdd5a4e34e7bf1f6ea91.exe
193. windowsxp-kb4047211-x86-embedded-deu_fd90e609d1c6ac311ecd73f08310523bf35bc53c.exe
194. windowsxp-kb4052303-x86-embedded-deu_ab6508825dabd1d5ee97d1cd2bac2c8def988a88.exe
195. windowsxp-kb4056941-x86-embedded-deu_c634c79dffa84d150ad48e7c58a484a7de6e774a.exe
196. windowsxp-kb4089175-x86-embedded-deu_4ffea17fa85caea9920ff10586f810ad2970d1d2.exe
197. windowsxp-kb4089082-x86-embedded-deu_2e5afa9571b9eae65081a73ebc643bb9932b7b54.exe
198. windowsxp-kb4089694-x86-embedded-deu_5712f17d25e0296863a28bf3194aea32b8f936a3.exe
199. windowsxp-kb4039384-x86-embedded-deu_9b5dd8f8d575c53c8121204bcb513a8dd83062e6.exe
200. windowsxp-kb4091756-x86-embedded-deu_a6c6254cf621693949fc0bbb37767c2132041ba6.exe
201. windowsxp-kb4130957-x86-embedded-deu_d87394fa6a91f2209004242a773f833a641b4c86.exe
202. windowsxp-kb4101477-x86-embedded-deu_e10095bbd960c12b49c45d9d9f4dde1d1264a0ae.exe
203. windowsxp-kb4056564-v2-x86-embedded-deu_aae8e36452a3397572a9d5f22673c214fdf80b28.exe
204. windowsxp-kb4089453-v2-x86-embedded-deu_3e4cff17232cd23e56ff79ef98a813a74c362a07.exe
205. windowsxp-kb4294413-x86-embedded-deu_fb30304a5f81c8dfafb146d5cf8d3dc8c9b031a7.exe
206. windowsxp-kb4291391-x86-embedded-deu_182d6c91d9b944721576cd588df62726078ebcc0.exe
207. windowsxp-kb4343674-x86-embedded-deu_b6430478d4d3981b13cc3a324cb686597eda57d8.exe
208. windowsxp-kb4041995-x86-embedded-deu_eb76a641a4252b0887d52ecc8662a0a28ae467fe.exe
209. windowsxp-kb4458000-x86-embedded-deu_f304f38cb08de982391567134cb42b823bc1d39c.exe
210. windowsxp-kb4458318-x86-embedded-deu_91f898c94d3a9a82cc9a54f137d1a9ad898e8133.exe
211. windowsxp-kb4458006-x86-embedded-deu_27779245f5dbc72711464d8bee65b91705dcf529.exe
212. windowsxp-kb4462935-x86-embedded-deu_945421dc055bb9298a82d4a15e1410b5a61f204b.exe
213. windowsxp-kb4462987-x86-embedded-deu_489cd1985fa6788a247ae8b7d2130c9a9c16849b.exe
214. windowsxp-kb4458001-x86-embedded-deu_c73adce0cff2629ff7ca44d1126e417525c50ae0.exe
215. windowsxp-kb4463103-x86-embedded-deu_6209a457a256dbe96eae7cef2ccf59991fd9ee3a.exe
216. windowsxp-kb4463573-x86-embedded-deu_7ee685404eba3ae7ca5ee29214d05c2bcceda1dd.exe
217. windowsxp-kb4470118-x86-embedded-deu_eea009ee02c4bf9442ce032e621f8e17414cdd5e.exe
218. windowsxp-kb4467689-x86-embedded-deu_87700f8b7e9cd5c57b625003527592f48b167611.exe
219. windowsxp-kb4473077-x86-embedded-deu_cf84d214264c5a5865623e1cdadade50ffb6348e.exe
220. windowsxp-kb4468323-x86-embedded-deu_c3db71f4d174afa7a7f02cf58419632ca8dcef9e.exe
221. windowsxp-kb4486463-x86-embedded-deu_329784debca6c6e513a77c7b294d91b95e43e7e1.exe
222. windowsxp-kb4457163-x86-embedded-deu_2d21373a9c7354d533c557512766508edadc8a79.exe
223. windowsxp-kb4487086-x86-embedded-deu_88d3145a04bb4897c6afc98ef35d95adb75e4765.exe
224. windowsxp-kb4489493-x86-embedded-deu_0975430891bd63f15d4eff8b29e0d6ae6020cc14.exe
225. windowsxp-kb4490228-x86-embedded-deu_c9ac4cb6a09c12182de9b7fafc099d69af1ee2f2.exe
226. windowsxp-kb4489973-x86-embedded-deu_91a426d59e92a5461f1fb405f9c4bd621fe12242.exe
227. windowsxp-kb4490501-x86-embedded-deu_122e6b237b5a39e0994f1bbcb14d8c0b09b09009.exe
228. windowsxp-kb4490385-x86-embedded-deu_d37f1e5800567a44d606a5f79f1c1c604c930fa6.exe
229. windowsxp-kb4486468-x86-embedded-deu_932e0ab3fae327b704221a212070dc51d12638ec.exe
230. windowsxp-kb4486538-x86-embedded-deu_0ad0b69b735b4cb210c910883feef448423f4734.exe
231. windowsxp-kb4486536-x86-embedded-deu_834e770b3fa6fc8a321a684603a5a6d4eb1acc8a.exe
232. windowsxp-kb4486465-x86-embedded-deu_16f93512e5bdf66b5157d7b25e747a039dd6718b.exe
233. windowsxp-kb4493341-x86-embedded-deu_dad1366d6659bc61ca1d7d1ce50b40e9c677e535.exe
234. windowsxp-kb4489977-x86-embedded-deu_0204a60fc088df292e0fae3975bc4e7c30604655.exe
235. windowsxp-kb4489974-x86-embedded-deu_0e05552068526d4ed7ce9019cf275f53cac74ad8.exe
236. windowsxp-kb4487989-x86-embedded-deu_e71655f4545f455eca5e66b6bc415f4d0a0efa65.exe
237. windowsxp-kb4491443-x86-embedded-deu_3f8b11f84f1f7b92c4bceefc237064b047f23964.exe
238. windowsxp-kb4486924-x86-embedded-deu_47f1dc44b59e24b98b2a8bcb849dfb5038ec5037.exe
239. windowsxp-kb4487085-v2-x86-embedded-deu_3d24ff1ab0b12f39b55738c6e2f35bd08d1b6c3b.exe
240. windowsxp-kb4494059-x86-embedded-deu_fade3da7da47cd6eec4453445be8f2fcaef79bed.exe
241. windowsxp-kb4493797-x86-embedded-deu_d40b2db5266782d60525ecf7b80f86b5ea45e05b.exe
242. windowsxp-kb4493796-x86-embedded-deu_379e11dad0ae1fd3362f34000f8995ec9370e981.exe
243. windowsxp-kb4493927-x86-embedded-deu_211a481dacbfa1cc9e7e66775d049e65cfcd1bb8.exe
244. windowsxp-kb4493795-x86-embedded-deu_4e8c9231b3da24a6871b8dba1405d7d4dff46084.exe
245. windowsxp-kb4493793-x86-embedded-deu_959b727ab60c9ca28cd41eca0d6a400fbe4eb6f1.exe
246. windowsxp-kb4493563-x86-embedded-deu_f3cb3e92109a52f0954281da4e5865c6fef92ba4.exe
247. windowsxp-kb4493794-x86-embedded-deu_9e42fa0f1239d38ca47e1f2df447322598256037.exe
248. windowsxp-kb4487990-x86-embedded-deu_e8d6e187d3b3440bd3314cbc8a0d5052cc77c7b1.exe
249. windowsxp-kb4495022-x86-embedded-deu_8a36f4b0ac2883a90617b6458f463aa6f6bc0c09.exe
250. ie8-windowsxp-kb4493435-x86-embedded-deu_cca09f60eef31acbefac834940d8dc385c63f1be.exe
251. windowsxp-kb4493790-x86-embedded-deu_c4e0e7eb6d2691050c205112d6d2631ace48f14c.exe
252. windowsxp-kb4494528-x86-embedded-deu_a1e4a6d0688b2fdd180d3122de610a92369f92c2.exe
253. windowsxp-kb4019276-x86-embedded-deu_8b5a4c16e096ad03a5adba4a6985470bdb46e512.exe
254. windowsxp-kb4459091-x86-embedded-deu_47206d8f43c44d33cf44b2295f9a807a7ee6af93.exe
255. windowsxp-kb4467770-x86-embedded-deu_758e1e540b44cd5afe9b28795f3cf46fdec8a485.exe
2019-12-28 12:48 »
German/DEU
1.BAT
@echo off
echo Ensure SP3 and IE 8 have been installed before continuing. If SP3 and IE 8 aren't installed close this update by clicking 'X' in upper right-hand corner.
pause
@echo off
start/wait windowsxp-kb979309-x86-deu_3e1a2e3af2ab2b5c1525aa602dd3ab1905472f6d.exe /quiet /passive /norestart
start/wait windowsxp-kb2922229-x86-deu_f0711f46d90d9a766d72ec97c512900963d2e3cc.exe /quiet /passive /norestart
start/wait windowsxp-kb2929961-x86-deu_0a2900b3bda9aa199c61a71c63ca08baa96257b3.exe /quiet /passive /norestart
start/wait windowsxp-kb2930275-x86-deu_69ab05af480a85766f433ee8a2163f675e8809cb.exe /quiet /passive /norestart
start/wait windowsxp-kb2916036-x86-deu_9f9ba12140602d97b79932a0917943129466e591.exe /quiet /passive /norestart
start/wait windowsxp-kb2914368-x86-deu_249e0a5cc0b07eb3afb1e94837e652a931442ff4.exe /quiet /passive /norestart
start/wait windowsxp-kb2898715-x86-deu_fd961b8df3d9c3a5d099be974ef2fccf4527b509.exe /quiet /passive /norestart
start/wait windowsxp-kb2892075-x86-deu_698f477b8ad4b1954b0044d8fef169787d1b81a1.exe /quiet /passive /norestart
start/wait windowsxp-kb2893294-x86-deu_e00580c5ae6e30bdaa55d05d7acd1fe935ca6cd8.exe /quiet /passive /norestart
start/wait windowsxp-kb2904266-x86-deu_8b895dc10f22e3666058826b90a6b50c302ec920.exe /quiet /passive /norestart
start/wait windowsxp-kb2900986-x86-deu_9429ffa1be5ad2b9d6008779065316de523967ad.exe /quiet /passive /norestart
start/wait windowsxp-kb2876331-x86-deu_3b9b168f17fb512761f2ec902695f8b44309da59.exe /quiet /passive /norestart
start/wait windowsxp-kb2868626-x86-deu_6574daf82ea780a306b560f9d7fb65ffccc42710.exe /quiet /passive /norestart
start/wait windowsxp-kb2862152-x86-deu_ec84928c2543f65d5efb65fecf26c714aa85cf4f.exe /quiet /passive /norestart
start/wait windowsxp-kb2847311-x86-deu_dfe4788da5858c2cc15d928f200277004432caee.exe /quiet /passive /norestart
start/wait windowsxp-kb2868038-x86-deu_47a86a447bf85ca369c725fb60e78a928e7f8c31.exe /quiet /passive /norestart
start/wait windowsxp-kb2862330-x86-deu_0392603ebd5b4a4d6b9d8316848d2a1ac02c9fa9.exe /quiet /passive /norestart
start/wait windowsxp-kb2862335-x86-deu_66f0e30bf64ec53f06cbb2ed50b3432c6ab883d8.exe /quiet /passive /norestart
start/wait windowsxp-kb2876217-x86-deu_24f89878e747523ebf0027e3c149a8cc8d885fd5.exe /quiet /passive /norestart
start/wait windowsxp-kb2864063-x86-deu_9a32f7b0b8e9f9b4e39fbb3888efa0820833f190.exe /quiet /passive /norestart
start/wait windowsxp-kb2850869-x86-deu_4a1aef1a234db8cabfaf453a3016ae71b5fa48e6.exe /quiet /passive /norestart
start/wait windowsxp-kb2859537-x86-deu_843af427d7f01d1be0534bd1acdb15e09edd6692.exe /quiet /passive /norestart
start/wait windowsxp-kb2834886-x86-deu_2c6a50afab0699a695f9982f422a5600f14387ad.exe /quiet /passive /norestart
start/wait windowsxp-kb2820917-x86-deu_54a356db283484eeef1ebb2c4ae501ed9b02fdac.exe /quiet /passive /norestart
start/wait windowsxp-kb2813345-x86-deu_fff78723399a160f0ef5ea8464c330d353dee372.exe /quiet /passive /norestart
start/wait windowsxp-kb2807986-x86-deu_81cf84d194e497d17d121339fee7e40a649c57e8.exe /quiet /passive /norestart
start/wait windowsxp-kb2802968-x86-deu_cc2e26212a1cc31f445a2e1657b1fb134e188441.exe /quiet /passive /norestart
start/wait windowsxp-kb2780091-x86-deu_1951b68e37cd197c514290a4aa8fb13a04b2f532.exe /quiet /passive /norestart
start/wait windowsxp-kb2757638-x86-deu_5a373e3a5d691e1d9c107aba574faf1908bf37e8.exe /quiet /passive /norestart
start/wait windowsxp-kb2770660-x86-deu_e9f0de1cb45d7787556c9a0bfa31554b5e7a1c14.exe /quiet /passive /norestart
start/wait windowsxp-kb2727528-x86-deu_13014815790c88ff394f2c8222af2cf025d3cd3f.exe /quiet /passive /norestart
start/wait windowsxp-kb2749655-x86-deu_e4f567daef3c747bd05c6496551f2a44711f56ef.exe /quiet /passive /norestart
start/wait windowsxp-kb2723135-v2-x86-deu_d845674dff261cf38eb33742d2627d6b0019c329.exe /quiet /passive /norestart
start/wait windowsxp-kb2705219-v2-x86-deu_6fe7594a28b57fd5df634f56fc706bd0fd909263.exe /quiet /passive /norestart
start/wait windowsxp-kb2691442-x86-deu_70cef96791363c05945cbfade0c7cbd584e5e9f5.exe /quiet /passive /norestart
start/wait windowsxp-kb2655992-x86-deu_d890cdee5195beecdd58ec8bd39411d9506aa5ba.exe /quiet /passive /norestart
start/wait windowsxp-kb2719985-x86-deu_89cfb585d9bae95458688c7c60cb7883b2ce2d02.exe /quiet /passive /norestart
start/wait windowsxp-kb2698365-x86-deu_ba2932468abf61140209cd9b830ee82c0863876d.exe /quiet /passive /norestart
start/wait windowsxp-kb2712808-x86-deu_b346436913e51fc5b9d55f95b333736e584851d0.exe /quiet /passive /norestart
start/wait windowsxp-kb2686509-x86-deu_41866a33f633d6ea16224b02ccc453b404e2c4b2.exe /quiet /passive /norestart
start/wait windowsxp-kb2676562-x86-deu_4515afac9b5a2f32d7e0ac4af1c34c819cb7bb3f.exe /quiet /passive /norestart
start/wait windowsxp-kb2653956-x86-deu_9b37ce09be3868832449ee523fe9a6d25ce0d892.exe /quiet /passive /norestart
start/wait windowsxp-kb2659262-x86-deu_c14b5d8a99bbd688012f0e6ec9c52e6d31ad2f08.exe /quiet /passive /norestart
start/wait windowsxp-kb2661637-x86-deu_b7f29e582363039f980920b632fd69e75a3d128d.exe /quiet /passive /norestart
start/wait windowsxp-kb2584146-x86-deu_2fe976d6c593518d89ed0ff78b4d7bc4d8c988f5.exe /quiet /passive /norestart
start/wait windowsxp-kb2631813-x86-deu_84124669ee4f9eb306ba38281d73402848034333.exe /quiet /passive /norestart
start/wait windowsxp-kb2585542-x86-deu_891ed1275a11717ee27a92a0b7fecd3a2044eebf.exe /quiet /passive /norestart
start/wait windowsxp-kb2603381-x86-deu_f13229c95a912a90c6bff999788755373a8488f8.exe /quiet /passive /norestart
start/wait windowsxp-kb2598479-x86-deu_285fe1ba2caedc7fa6cae307bd3445c77a794b5b.exe /quiet /passive /norestart
start/wait windowsxp-kb2619339-x86-deu_54a23a32127000d7cab89f2b3bd20cea70f64f2d.exe /quiet /passive /norestart
start/wait windowsxp-kb2620712-x86-deu_a6c807504e6c5ed758f73607b638ccf3423923a6.exe /quiet /passive /norestart
start/wait windowsxp-kb2544893-v2-x86-deu_69b5503b11129c3de7c7d7b6d0b158b1702f0674.exe /quiet /passive /norestart
start/wait windowsxp-kb2592799-x86-deu_651e608ec6bca1519ae8199c55390bf13ad005a9.exe /quiet /passive /norestart
start/wait windows-de-de-kb2564958_8ae021f34b5b17a6322fc51754bf82be541b8a75.exe /quiet /passive /norestart
start/wait windowsxp-kb2570947-x86-deu_e017ccd1cfb5be140cd77f84ab9cbbe13c5a8769.exe /quiet /passive /norestart
start/wait windowsxp-kb2566454-x86-deu_02a718d10f5f4f93643ba7152bf126bf589d905c.exe /quiet /passive /norestart
start/wait windowsxp-kb2536276-v2-x86-deu_9ca23d04a59888583de60c916b72f1dfb1c9079b.exe /quiet /passive /norestart
start/wait windowsxp-kb2507938-x86-deu_f3b9036d4b2671cc2d29b8157841aa45d639c1e0.exe /quiet /passive /norestart
start/wait msxml4-kb973688-deu_85a572e14263dbee4526979b9b52d1b0f10b90a9.exe /quiet /passive /norestart
start/wait msxml4-kb954430-deu_490ad43316dfe4057db3495324916c910f3fec1b.exe /quiet /passive /norestart
start/wait windowsxp-kb2535512-x86-deu_7044d3217d7d39ba0c17f9f9f607e45190291cf3.exe /quiet /passive /norestart
start/wait windowsxp-kb2485663-x86-deu_d2624922cefad4ae97acaf5693a49e925932e63a.exe /quiet /passive /norestart
start/wait windowsxp-kb2508429-x86-deu_e3c57486f0caf8e4bd387d2f7dbcd3ce0229d6ba.exe /quiet /passive /norestart
start/wait windowsxp-kb2506212-x86-deu_da2b388c036e4f58c1f067b2ed74cb04dd55dd1b.exe /quiet /passive /norestart
start/wait ie8-windowsxp-kb2510531-x86-deu_d10cd98099f115059086ee9317ec42103c6b4b05.exe /quiet /passive /norestart
start/wait windowsxp-kb2509553-x86-deu_072f198c63c516291d4e6e25ddd2bc2e1427a514.exe /quiet /passive /norestart
start/wait windowsxp-kb2479943-x86-deu_5c6bc52fe2a7f3b6adec195df49319dff4187413.exe /quiet /passive /norestart
start/wait windowsxp-kb2481109-x86-deu_2b876e8edef06a4c7a36f119bcbf7a6decfe180d.exe /quiet /passive /norestart
start/wait windowsxp-kb971029-x86-deu_751a12c16dac9774fe378fd0a78929bfdc5ce6ef.exe /quiet /passive /norestart
start/wait windowsxp-kb2478971-x86-deu_6e4e9a157b66402750f5abb808b5df703f94aa43.exe /quiet /passive /norestart
start/wait windowsxp-kb2483185-x86-deu_a4c9c996e40da68682223d35fa7c20e5da173a61.exe /quiet /passive /norestart
start/wait windowsxp-kb2478960-x86-deu_9631f562454698341d0cf2f58f52c5a52c37ba9f.exe /quiet /passive /norestart
start/wait windowsxp-kb2393802-x86-deu_4c75a0f0aa12ab09de03dd7c4e38bdb919dfb261.exe /quiet /passive /norestart
start/wait windowsxp-kb2419632-x86-deu_fafc7b5cd1c46445357cedb084c9665b5ea04613.exe /quiet /passive /norestart
start/wait windowsxp-kb2423089-x86-deu_913718d290c409cfe20abe06ecbbea2cb0709680.exe /quiet /passive /norestart
start/wait windowsxp-kb2443105-x86-deu_272fa59814c106f9be133c7b11f9f5cdd38e4952.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb975558-x86-deu_547fccf8d5b076c60646f33a653e090a57d85295.exe /quiet /passive /norestart
start/wait windowsxp-kb979687-x86-deu_56cf26f775d48283d3a478e3de9c77f7606ae394.exe /quiet /passive /norestart
start/wait windowsxp-kb2296011-x86-deu_f3d62a877f30f18324908ba97f2a2302ea1e4981.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb2378111-x86-deu_5ecc5bc343c6fafdd6a55f2145a29ce9068d4cf1.exe /quiet /passive /norestart
start/wait windowsxp-kb2387149-x86-deu_fb2b8366d355bb911a06607d6d65128e9d65472e.exe /quiet /passive /norestart
start/wait windowsxp-kb982132-x86-deu_36f5651b05b27350d86ab2fda4c3f0c7c7446772.exe /quiet /passive /norestart
start/wait windowsxp-kb2347290-x86-deu_4d4057af1813129c9822188a0d5c2d928ef2dcc2.exe /quiet /passive /norestart
start/wait windowsxp-kb2115168-x86-deu_5c7103c23635aa7739ad3604ece9c40e39529bb7.exe /quiet /passive /norestart
start/wait windowsxp-kb982665-x86-deu_4ffbcdd33ec002182869e84ff41ad6ab32925b65.exe /quiet /passive /norestart
start/wait windowsxp-kb981997-x86-deu_eda4bb238e0c1f715f1577539b5b74c1fb741bb5.exe /quiet /passive /norestart
start/wait windowsxp-kb2229593-x86-deu_656064c08387c51c6612c92477ebc4ed6e390396.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb978695-x86-deu_087108b470354b3d1f4bbf6d8983e38c1f1fb0bf.exe /quiet /passive /norestart
start/wait windowsxp-kb979482-x86-deu_479364d026a7ba444ae176b084a9b7a200c61e88.exe /quiet /passive /norestart
start/wait windowsxp-kb978542-x86-deu_5c4175999da446364a8d823d8a442d41f83355d4.exe /quiet /passive /norestart
start/wait windowsxp-kb977816-x86-deu_0b72bcdaceca4a8132a6121e1623e1e811562ee0.exe /quiet /passive /norestart
start/wait windowsxp-kb978338-x86-deu_134f94e894466a0b66f3d5d2f755665cc6d7ee1c.exe /quiet /passive /norestart
start/wait windowsxp-kb975713-x86-deu_a4233e6225ab2fa84605de14d8d24c8cc1cff3f5.exe /quiet /passive /norestart
start/wait windowsxp-kb975560-x86-deu_a387d1718237fac06f8e07a7db8cf97190680142.exe /quiet /passive /norestart
start/wait windowsxp-kb977914-x86-deu_5718766a6e2637f2223b78b4239ce85eca28df7f.exe /quiet /passive /norestart
start/wait windowsxp-kb978706-x86-deu_b23b1963e63c8acba8a4c644d18019341ce384d2.exe /quiet /passive /norestart
start/wait windowsxp-kb972270-x86-deu_3215b9c387f599d73d209ac22b7ab68423566016.exe /quiet /passive /norestart
start/wait windowsxp-kb974318-x86-deu_fe1fa5176c77394b20e6bc4396b35e2825623074.exe /quiet /passive /norestart
start/wait windowsxp-kb974392-x86-deu_cf110bf3e66aca3752ab0661cf1de1e057e6e2d5.exe /quiet /passive /norestart
start/wait windowsxp-kb973904-x86-deu_777e2b1954656bff6005cbacef2d8755d1f27530.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb952069-v2-x86-deu_87f9aeeaf57dbc86ff31eb9b856d18a42e308738.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb954155-x86-deu_ae8c7d6d385108c7a3749ed30bd1c0b560dd13bb.exe /quiet /passive /norestart
start/wait windowsxp-kb975025-x86-deu_5ac01419cb805a842f8ca75d4652d6bd45083325.exe /quiet /passive /norestart
start/wait windowsxp-kb974571-x86-deu_9601a32f9ebcd7acf50463bde877ddbcd6f3074f.exe /quiet /passive /norestart
start/wait windowsxp-kb974112-x86-deu_9e899c0fbfe06daae43b9df2fa4adc210540cbbe.exe /quiet /passive /norestart
start/wait windowsxp-kb969059-x86-deu_44baf6c9d9390647b73f6f147f3db92539612826.exe /quiet /passive /norestart
start/wait windowsxp-kb975467-x86-deu_547a3c495e277458431e5b69295a4ea05e04e51d.exe /quiet /passive /norestart
start/wait windowsxp-kb968389-x86-deu_c5099895340d6c67cf867c11e1c951fb40298a7b.exe /quiet /passive /norestart
start/wait windowsxp-kb956844-x86-deu_4f2537ad7b78febd66d5534bc230b96038ba3c36.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb973540-x86-deu_f2e2cb9b65fc6cc20a0b466b5a677f4341ed1b97.exe /quiet /passive /norestart
start/wait windowsxp-kb973869-x86-deu_c7a9d1b53f1631078b3c162af045b7dd94dddd44.exe /quiet /passive /norestart
start/wait windowsxp-kb973507-x86-deu_b6cf429401128937303082f3d44bde64310a570b.exe /quiet /passive /norestart
start/wait windowsxp-kb960859-x86-deu_739f567460b0fc38bb9578af93a6c43d31df6a47.exe /quiet /passive /norestart
start/wait windowsxp-kb973815-x86-deu_1869f3c2d3bf48239589171ed9f48e42167851a3.exe /quiet /passive /norestart
start/wait windowsxp-kb971657-x86-deu_3afe87d70dac8a6352b392d92b863053b3c3badc.exe /quiet /passive /norestart
start/wait windowsxp-kb923561-x86-deu_3f1dee678b66f2ecf08570ae198696601f0a9c98.exe /quiet /passive /norestart
start/wait windowsxp-kb956572-x86-deu_99122b3a29b7455624721aaca0c8c4241e78d2ab.exe /quiet /passive /norestart
start/wait windowsxp-kb960803-x86-deu_3ca32c0b863aed207a4907d058841ea0355e6859.exe /quiet /passive /norestart
start/wait windowsxp-kb959426-x86-deu_76263d1e1f49d927517c49f2c570e5f3af84847c.exe /quiet /passive /norestart
start/wait windowsxp-kb950974-x86-deu_afb216e90fdbc32bd7df4ad41ce7ea09f89ceb5a.exe /quiet /passive /norestart
start/wait windowsxp-kb952287-x86-deu_5e44d3ec9b6500ca6bfc3fa4f6dd0dd946aa7235.exe /quiet /passive /norestart
start/wait windowsxp-kb946648-x86-deu_2415eede56fe688aae38f149eb8b0cb8ab9fe6da.exe /quiet /passive /norestart
start/wait windowsxp-kb952954-x86-deu_950750b938475f80ff21c18632d7a418e8dc0e02.exe /quiet /passive /norestart
start/wait windowsxp-kb951978-x86-deu_a4881b5352c37c557630d8b8db9cb8b246704601.exe /quiet /passive /norestart
start/wait windowsxp-kb951376-v2-x86-deu_b15635c29bcf1214e5c4388923a9c924ac1c55d4.exe /quiet /passive /norestart
start/wait windowsxp-kb950762-x86-deu_97bf711d852b723bbde49390295c42170e50b087.exe /quiet /passive /norestart
start/wait windowsxp-kb941569-x86-deu_e41b608297acf4070c229f8f62b639c3c3af5fea.exe /quiet /passive /norestart
start/wait windowsxp-kb2808679-x86-deu_8672086a45f0a40601e78a949fe2c0a3674c94e0.exe /quiet /passive /norestart
start/wait ie8-windowsxp-kb2632503-x86-deu_ced434b2dc224fc2f8bab211ff597cc61cc04885.exe /quiet /passive /norestart
start/wait ie8-windowsxp-kb2598845-x86-deu_abbfddc2fa764ce5453da2b666b518a19755fbc9.exe /quiet /passive /norestart
start/wait windowsxp-kb2492386-x86-deu_bfaa8daf2765df2b5e4da1ff48cdf1f415872197.exe /quiet /passive /norestart
start/wait windows-de-de-kb971513_e47749e7458c92e0db84293439ce2f85f778ab0c.exe /quiet /passive /norestart
start/wait wmp11-windowsxp-x86-de-de_421436944b0bb18a0e9c1a8e61cb91ad2abfab6a.exe /q
echo All done please reboot
@echo off
pause
2.BAT:
@echo off
echo Installing updates and patches please wait.…
@echo off
start/wait windowsxp-mscomppackv1-x86.exe  /quiet /passive /norestart
start/wait windowsmedia11-kb939683-x86-deu_e142439cf38fff3aa54a91c40f54f2606bf9c208.exe /quiet /passive /norestart
start/wait windowsmedia11-kb929399-v2-x86-intl_50e2bc6b5e79909a0061043e6211600548368431.exe  /quiet /passive /norestart
start/wait windowsmedia11-kb954154-x86-deu_349589c31d3210e102f97936fb7d8e97030fde8e.exe /quiet /passive /norestart
start/wait windowsserver2003.windowsxp-kb963093-x86-enu_c53606bca846117e1cebe7dd9a37251cb84aa41d.exe  /quiet /passive /norestart
start/wait windowsxp-kb952004-x86-deu_ad282f76179619c2f125922683fc397762cbb59a.exe /quiet /passive /norestart
start/wait windowsxp-kb970430-x86-deu_b8ce3c948a2af96849f12cd925932a9878e32c4a.exe /quiet /passive /norestart
start/wait windowsxp-kb2345886-x86-deu_a5b3a537bd6297a9ebf159e350d9a6ade66a8517.exe /quiet /passive /norestart
start/wait windowsxp-windowsmedia-kb2834904-v2-x86-deu_15ce3ab9e814e274e28a30374a51b652ca2eb1a1.exe /quiet /passive /norestart
@echo off
pause
3.BAT (Don't forget REG file!!)
@echo off
@echo off
start/wait windowsxp-kb2926765-x86-embedded-deu_5bd881de9013125045e38aabcd01cb2f4afc9db7.exe /quiet /passive /norestart
start/wait windowsxp-kb2993651-x86-embedded-deu_2868e8443780d722e627b131c341660d30d0f461.exe /quiet /passive /norestart
start/wait windowsxp-kb2993254-x86-embedded-deu_2783a701fcc211ab1937c22f4dc3b726d4e5333f.exe /quiet /passive /norestart
start/wait windowsxp-kb2998579-x86-embedded-deu_31be7198c1f5d83302f8b005da9fa6a3c8fe84f5.exe /quiet /passive /norestart
start/wait windowsxp-kb3013126-x86-embedded-deu_f077765211e6a732790fedbf083cf079bffe460e.exe /quiet /passive /norestart
start/wait windowsxp-kb3020393-v2-x86-embedded-deu_a2de018b26cd7de64fd42c11eef9d3d2ab83c9f0.exe /quiet /passive /norestart
start/wait windowsxp-kb3021674-x86-embedded-deu_7083998fa4ac36a6f28907d800b2f9615014e276.exe /quiet /passive /norestart
start/wait windowsxp-kb3004361-x86-embedded-deu_74d3f625c4044ba4a2907e2c9c80bd3364a85bb4.exe /quiet /passive /norestart
start/wait windowsxp-kb3029944-x86-embedded-deu_ee007a29d1d6fa59d6862ab02c56d41a34bb739e.exe /quiet /passive /norestart
start/wait windowsxp-kb3033889-x86-embedded-deu_53f4df68bb412393ca64eef72aea63abf1facfad.exe /quiet /passive /norestart
start/wait windowsxp-kb3035132-x86-embedded-deu_4cfc27ada29a6f7b83e3134f43256ade22c6f547.exe /quiet /passive /norestart
start/wait windowsmedia11-kb3033890-x86-deu_5a12d27c63747f10dec45e648a78ac04ef38f583.exe /quiet /passive /norestart
start/wait windowsxp-kb3065979-x86-embedded-deu_51736dcbb99339cc6c00a1aa3032345a100b7e03.exe /quiet /passive /norestart
start/wait windowsmedia-kb3067903-x86-deu_d52c6d232498d52841fd3f230321156f2b900014.exe /quiet /passive /norestart
start/wait windowsxp-kb3078601-x86-embedded-deu_62688e57781f27b87278c89e7c29f433b9979954.exe /quiet /passive /norestart
start/wait windowsxp-kb3087039-x86-embedded-deu_d2df59bbb7583b79d613f1e91ed3f1faac4aa99c.exe /quiet /passive /norestart
start/wait windowsxp-kb2957503-x86-embedded-deu_6a47e96c8b468dade7ceaf2c60c704321296b59f.exe /quiet /passive /norestart
start/wait windowsxp-kb3109560-x86-embedded-deu_c344bb6ffe7820575314d4df93acd94119dc6be5.exe /quiet /passive /norestart
start/wait windowsxp-kb3121918-x86-embedded-deu_0ee06b64e1d6e1617b6ed9b2d696fb7f88c3ac60.exe /quiet /passive /norestart
start/wait windowsxp-kb3126593-x86-embedded-deu_7c62688e67961e68f135855a0d2cc5f7d9d96cf2.exe /quiet /passive /norestart
start/wait windowsxp-kb3126587-x86-embedded-deu_a5b45596cba97035e50c619a58a9d243c41f2dad.exe /quiet /passive /norestart
start/wait windowsxp-kb3139398-x86-embedded-deu_e22144a682f0faa7944785dd209fe20ad0dd6efd.exe /quiet /passive /norestart
start/wait windowsxp-kb3081320-x86-embedded-deu_9af777598ce7ec7a36e360e769d57685305cab7d.exe /quiet /passive /norestart
start/wait windowsxp-kb3139914-x86-embedded-deu_96b928ab4654b78b4c5d275c9302c74698cdb3c1.exe /quiet /passive /norestart
start/wait windowsxp-kb3140709-x86-embedded-deu_68ac7c2ce54309b9d03d31b24256d897e6012062.exe /quiet /passive /norestart
start/wait windowsxp-kb3149090-x86-embedded-deu_e3a36e80ee52637264f5323e073ac990105903c4.exe /quiet /passive /norestart
start/wait windowsxp-kb3145739-x86-embedded-deu_d9515c11cfdde0fc78729d4c7ae839d74f87bf68.exe /quiet /passive /norestart
start/wait windowsxp-kb3161561-x86-embedded-deu_e05755f96d6ceb4050e53be977f897cf8c7bc8f5.exe /quiet /passive /norestart
start/wait windowsxp-kb3161949-x86-embedded-deu_6652e7dfd2c0b124e72fada9c14465503cb07e7b.exe /quiet /passive /norestart
start/wait windowsxp-kb3170455-x86-embedded-deu_54a4201c6387bbb211d15a3c99344d35f2768dbd.exe /quiet /passive /norestart
start/wait windowsxp-kb3092601-x86-embedded-deu_5a9965419415d9ab9d0ee67c4fc57dea350ed2e4.exe /quiet /passive /norestart
start/wait windowsxp-kb3178034-x86-embedded-deu_0d8d9cff062ab7e1770ca7b8e48f5cbaf154ce36.exe /quiet /passive /norestart
start/wait windowsxp-kb3196718-x86-embedded-deu_358d918d27c66292363a5002bc3a1df39fe206c7.exe /quiet /passive /norestart
start/wait windowsxp-kb3198510-x86-embedded-deu_c5fab81f62a2e3516207c9cb6979ed22cf8e60be.exe /quiet /passive /norestart
start/wait windowsxp-kb4012583-x86-embedded-deu_f4cbfe31341c4c003abe44c95fd984a0f0b0b6da.exe /quiet /passive /norestart
start/wait windowsxp-kb3185911-x86-embedded-deu_9c19c24de034e64957f378c37964f3245a19731b.exe /quiet /passive /norestart
start/wait windowsxp-kb4012584-x86-embedded-deu_da2c437f17e81caa40cd0924eba4539968a4aede.exe /quiet /passive /norestart
start/wait windowsxp-kb4014652-x86-embedded-deu_10ada6ca41ce53fcf4dc7d77a58b7c0bec188d30.exe /quiet /passive /norestart
start/wait windowsxp-kb4014794-x86-embedded-deu_c42a2c191c00b3d186c3f01c5aa3ce8b90d58e67.exe /quiet /passive /norestart
start/wait windowsxp-kb4015383-x86-embedded-deu_56c2fdf072155c4f802c75ffe5d40768629894d3.exe /quiet /passive /norestart
start/wait windowsxp-kb4022747-x86-embedded-deu_e1eaf8b50be6dbe18c56b9faeb0e909705d197c3.exe /quiet /passive /norestart
start/wait windowsxp-kb4024323-x86-embedded-deu_455a3982800a273f67ec2c2a707b01c067452cf1.exe /quiet /passive /norestart
start/wait windowsxp-kb4025218-x86-embedded-deu_d930729261f179e2f7ad16844621d53269b22b81.exe /quiet /passive /norestart
start/wait windowsxp-kb4026061-x86-embedded-deu_4b6283af355d55f7935ff0dfa6a9cb38ba086bdb.exe /quiet /passive /norestart
start/wait windowsxp-kb4025497-x86-embedded-deu_c4fa2017a37f31baaa0236943faa5e9e8fa44f4e.exe /quiet /passive /norestart
start/wait windowsxp-kb4025409-x86-embedded-deu_8624ee3d166c9215eff72ca080f59614cc141ab3.exe /quiet /passive /norestart
start/wait windowsxp-kb4034775-x86-embedded-deu_1b0a406f727aa30a20d1db37b299b02e0b2723da.exe /quiet /passive /norestart
start/wait windowsxp-kb3183431-x86-embedded-deu_d6100e9e1c5d85eeaeb1bdd5a4e34e7bf1f6ea91.exe /quiet /passive /norestart
start/wait windowsxp-kb4047211-x86-embedded-deu_fd90e609d1c6ac311ecd73f08310523bf35bc53c.exe /quiet /passive /norestart
start/wait windowsxp-kb4052303-x86-embedded-deu_ab6508825dabd1d5ee97d1cd2bac2c8def988a88.exe /quiet /passive /norestart
start/wait windowsxp-kb4056941-x86-embedded-deu_c634c79dffa84d150ad48e7c58a484a7de6e774a.exe /quiet /passive /norestart
start/wait windowsxp-kb4089175-x86-embedded-deu_4ffea17fa85caea9920ff10586f810ad2970d1d2.exe /quiet /passive /norestart
start/wait windowsxp-kb4089082-x86-embedded-deu_2e5afa9571b9eae65081a73ebc643bb9932b7b54.exe /quiet /passive /norestart
start/wait windowsxp-kb4089694-x86-embedded-deu_5712f17d25e0296863a28bf3194aea32b8f936a3.exe /quiet /passive /norestart
start/wait windowsxp-kb4039384-x86-embedded-deu_9b5dd8f8d575c53c8121204bcb513a8dd83062e6.exe /quiet /passive /norestart
start/wait windowsxp-kb4091756-x86-embedded-deu_a6c6254cf621693949fc0bbb37767c2132041ba6.exe /quiet /passive /norestart
start/wait windowsxp-kb4130957-x86-embedded-deu_d87394fa6a91f2209004242a773f833a641b4c86.exe /quiet /passive /norestart
start/wait windowsxp-kb4101477-x86-embedded-deu_e10095bbd960c12b49c45d9d9f4dde1d1264a0ae.exe /quiet /passive /norestart
start/wait windowsxp-kb4056564-v2-x86-embedded-deu_aae8e36452a3397572a9d5f22673c214fdf80b28.exe /quiet /passive /norestart
start/wait windowsxp-kb4089453-v2-x86-embedded-deu_3e4cff17232cd23e56ff79ef98a813a74c362a07.exe /quiet /passive /norestart
start/wait windowsxp-kb4294413-x86-embedded-deu_fb30304a5f81c8dfafb146d5cf8d3dc8c9b031a7.exe /quiet /passive /norestart
start/wait windowsxp-kb4291391-x86-embedded-deu_182d6c91d9b944721576cd588df62726078ebcc0.exe /quiet /passive /norestart
start/wait windowsxp-kb4343674-x86-embedded-deu_b6430478d4d3981b13cc3a324cb686597eda57d8.exe /quiet /passive /norestart
start/wait windowsxp-kb4041995-x86-embedded-deu_eb76a641a4252b0887d52ecc8662a0a28ae467fe.exe /quiet /passive /norestart
start/wait windowsxp-kb4458000-x86-embedded-deu_f304f38cb08de982391567134cb42b823bc1d39c.exe /quiet /passive /norestart
start/wait windowsxp-kb4458318-x86-embedded-deu_91f898c94d3a9a82cc9a54f137d1a9ad898e8133.exe /quiet /passive /norestart
start/wait windowsxp-kb4458006-x86-embedded-deu_27779245f5dbc72711464d8bee65b91705dcf529.exe /quiet /passive /norestart
start/wait windowsxp-kb4462935-x86-embedded-deu_945421dc055bb9298a82d4a15e1410b5a61f204b.exe /quiet /passive /norestart
start/wait windowsxp-kb4462987-x86-embedded-deu_489cd1985fa6788a247ae8b7d2130c9a9c16849b.exe /quiet /passive /norestart
start/wait windowsxp-kb4458001-x86-embedded-deu_c73adce0cff2629ff7ca44d1126e417525c50ae0.exe /quiet /passive /norestart
start/wait windowsxp-kb4463103-x86-embedded-deu_6209a457a256dbe96eae7cef2ccf59991fd9ee3a.exe /quiet /passive /norestart
start/wait windowsxp-kb4463573-x86-embedded-deu_7ee685404eba3ae7ca5ee29214d05c2bcceda1dd.exe /quiet /passive /norestart
start/wait windowsxp-kb4470118-x86-embedded-deu_eea009ee02c4bf9442ce032e621f8e17414cdd5e.exe /quiet /passive /norestart
start/wait windowsxp-kb4467689-x86-embedded-deu_87700f8b7e9cd5c57b625003527592f48b167611.exe /quiet /passive /norestart
start/wait windowsxp-kb4473077-x86-embedded-deu_cf84d214264c5a5865623e1cdadade50ffb6348e.exe /quiet /passive /norestart
start/wait windowsxp-kb4468323-x86-embedded-deu_c3db71f4d174afa7a7f02cf58419632ca8dcef9e.exe /quiet /passive /norestart
start/wait windowsxp-kb4486463-x86-embedded-deu_329784debca6c6e513a77c7b294d91b95e43e7e1.exe /quiet /passive /norestart
start/wait windowsxp-kb4457163-x86-embedded-deu_2d21373a9c7354d533c557512766508edadc8a79.exe /quiet /passive /norestart
start/wait windowsxp-kb4487086-x86-embedded-deu_88d3145a04bb4897c6afc98ef35d95adb75e4765.exe /quiet /passive /norestart
start/wait windowsxp-kb4489493-x86-embedded-deu_0975430891bd63f15d4eff8b29e0d6ae6020cc14.exe /quiet /passive /norestart
start/wait windowsxp-kb4490228-x86-embedded-deu_c9ac4cb6a09c12182de9b7fafc099d69af1ee2f2.exe /quiet /passive /norestart
start/wait windowsxp-kb4489973-x86-embedded-deu_91a426d59e92a5461f1fb405f9c4bd621fe12242.exe /quiet /passive /norestart
start/wait windowsxp-kb4490501-x86-embedded-deu_122e6b237b5a39e0994f1bbcb14d8c0b09b09009.exe /quiet /passive /norestart
start/wait windowsxp-kb4490385-x86-embedded-deu_d37f1e5800567a44d606a5f79f1c1c604c930fa6.exe /quiet /passive /norestart
start/wait windowsxp-kb4486468-x86-embedded-deu_932e0ab3fae327b704221a212070dc51d12638ec.exe /quiet /passive /norestart
start/wait windowsxp-kb4486538-x86-embedded-deu_0ad0b69b735b4cb210c910883feef448423f4734.exe /quiet /passive /norestart
start/wait windowsxp-kb4486536-x86-embedded-deu_834e770b3fa6fc8a321a684603a5a6d4eb1acc8a.exe /quiet /passive /norestart
start/wait windowsxp-kb4486465-x86-embedded-deu_16f93512e5bdf66b5157d7b25e747a039dd6718b.exe /quiet /passive /norestart
start/wait windowsxp-kb4493341-x86-embedded-deu_dad1366d6659bc61ca1d7d1ce50b40e9c677e535.exe /quiet /passive /norestart
start/wait windowsxp-kb4489977-x86-embedded-deu_0204a60fc088df292e0fae3975bc4e7c30604655.exe /quiet /passive /norestart
start/wait windowsxp-kb4489974-x86-embedded-deu_0e05552068526d4ed7ce9019cf275f53cac74ad8.exe /quiet /passive /norestart
start/wait windowsxp-kb4487989-x86-embedded-deu_e71655f4545f455eca5e66b6bc415f4d0a0efa65.exe /quiet /passive /norestart
start/wait windowsxp-kb4491443-x86-embedded-deu_3f8b11f84f1f7b92c4bceefc237064b047f23964.exe /quiet /passive /norestart
start/wait windowsxp-kb4486924-x86-embedded-deu_47f1dc44b59e24b98b2a8bcb849dfb5038ec5037.exe /quiet /passive /norestart
start/wait windowsxp-kb4487085-v2-x86-embedded-deu_3d24ff1ab0b12f39b55738c6e2f35bd08d1b6c3b.exe /quiet /passive /norestart
start/wait windowsxp-kb4494059-x86-embedded-deu_fade3da7da47cd6eec4453445be8f2fcaef79bed.exe /quiet /passive /norestart
start/wait windowsxp-kb4493797-x86-embedded-deu_d40b2db5266782d60525ecf7b80f86b5ea45e05b.exe /quiet /passive /norestart
start/wait windowsxp-kb4493796-x86-embedded-deu_379e11dad0ae1fd3362f34000f8995ec9370e981.exe /quiet /passive /norestart
start/wait windowsxp-kb4493927-x86-embedded-deu_211a481dacbfa1cc9e7e66775d049e65cfcd1bb8.exe /quiet /passive /norestart
start/wait windowsxp-kb4493795-x86-embedded-deu_4e8c9231b3da24a6871b8dba1405d7d4dff46084.exe /quiet /passive /norestart
start/wait windowsxp-kb4493793-x86-embedded-deu_959b727ab60c9ca28cd41eca0d6a400fbe4eb6f1.exe /quiet /passive /norestart
start/wait windowsxp-kb4493563-x86-embedded-deu_f3cb3e92109a52f0954281da4e5865c6fef92ba4.exe /quiet /passive /norestart
start/wait windowsxp-kb4493794-x86-embedded-deu_9e42fa0f1239d38ca47e1f2df447322598256037.exe /quiet /passive /norestart
start/wait windowsxp-kb4487990-x86-embedded-deu_e8d6e187d3b3440bd3314cbc8a0d5052cc77c7b1.exe /quiet /passive /norestart
start/wait windowsxp-kb4495022-x86-embedded-deu_8a36f4b0ac2883a90617b6458f463aa6f6bc0c09.exe /quiet /passive /norestart
start/wait ie8-windowsxp-kb4493435-x86-embedded-deu_cca09f60eef31acbefac834940d8dc385c63f1be.exe /quiet /passive /norestart
start/wait windowsxp-kb4493790-x86-embedded-deu_c4e0e7eb6d2691050c205112d6d2631ace48f14c.exe /quiet /passive /norestart
start/wait windowsxp-kb4494528-x86-embedded-deu_a1e4a6d0688b2fdd180d3122de610a92369f92c2.exe /quiet /passive /norestart
start/wait windowsxp-kb4019276-x86-embedded-deu_8b5a4c16e096ad03a5adba4a6985470bdb46e512.exe /quiet /passive /norestart
start/wait windowsxp-kb4459091-x86-embedded-deu_47206d8f43c44d33cf44b2295f9a807a7ee6af93.exe /quiet /passive /norestart
start/wait windowsxp-kb4467770-x86-embedded-deu_758e1e540b44cd5afe9b28795f3cf46fdec8a485.exe /quiet /passive /norestart
@echo off
pause
2019-12-28 13:11 »
German/DEU
windowsxp-kb4500331-x86-custom-deu_f6b19dd13775e252ee6ca329d911010b90edabbd.exe
Reboot!
2019-12-28 20:13 »
French/FRA
Official XP
1. WindowsXP-KB936929-SP3-x86-FRA.exe
2. IE8-WindowsXP-x86-FRA.exe
3. windowsxp-kb979309-x86-fra_6d262848eab348911d630c9a1a366bf95d81b8e7.exe
4. windowsxp-kb2922229-x86-fra_38eec4daec23c08c205e997a6934c1c9a7a1001c.exe
5. windowsxp-kb2929961-x86-fra_d0428eee5f18a50faf9c07d10883dfb07a381218.exe
6. windowsxp-kb2930275-x86-fra_73d058bedbe23204b8cf1f297e2a64ea3dd056f2.exe
7. windowsxp-kb2916036-x86-fra_de806608e795a688b02d3766245c4b89ead35b46.exe
8. windowsxp-kb2914368-x86-fra_deb5e04f8438d106363329260bbdbe58766b5e5e.exe
9. windowsxp-kb2898715-x86-fra_b448187549763a5952d43ef5f43efae496847d9e.exe
10. windowsxp-kb2892075-x86-fra_2c283b5f6d05800d0d0f20c6272aa36db1f39d25.exe
11. windowsxp-kb2893294-x86-fra_37dd8b8bc7706f8f263719eac2d7351c589fedad.exe
12. windowsxp-kb2904266-x86-fra_c78d43dfe0d529eaf156c32014b6937372ae5c6a.exe
13. windowsxp-kb2900986-x86-fra_b6b05983ca0d5647a514f2801f660a377ab95cd3.exe
14. windowsxp-kb2876331-x86-fra_a946e4a4108508a342570bc2556b476d78957bf8.exe
15. windowsxp-kb2868626-x86-fra_a4a180aefd4bcdd316c48064e4f6af0afcb0b831.exe
16. windowsxp-kb2862152-x86-fra_d0f53aad13b2b0a79762801d134e7e40d805f105.exe
17. windowsxp-kb2847311-x86-fra_6c793a7bafe7c29128071ffedd71844d72daa2bc.exe
18. windowsxp-kb2868038-x86-fra_f164d28e6f3a42eac3687c2e9dddcfd33a0eeabe.exe
19. windowsxp-kb2862330-x86-fra_b561d615a0282f714e005abbf7c4ba2077e94846.exe
20. windowsxp-kb2862335-x86-fra_e8216c0a93e7d2a66fe8f5569716a0061c7b5967.exe
21. windowsxp-kb2876217-x86-fra_1718c04223bf62160bc570c4909f52fa42f790c6.exe
22. windowsxp-kb2864063-x86-fra_1f46a63d370ee00860d52ed3c3dcab7d1be32e63.exe
23. windowsxp-kb2850869-x86-fra_e4bd83eab491936fe7ed715b0f8f782b89a40c08.exe
24. windowsxp-kb2859537-x86-fra_09790146ff30ce9660e3abddd810de369733977b.exe
25. windowsxp-kb2834886-x86-fra_f9f8d24ad9243867536a5540c6f5e7e730045196.exe
26. windowsxp-kb2820917-x86-fra_c4a7c7862a209915b75d5cc35ed8c78663068e67.exe
27. windowsxp-kb2813345-x86-fra_cf5ecae0ec3898efbb72050f06388f03b17e72ca.exe
28. windowsxp-kb2807986-x86-fra_e70ceecec7de6d8396b38dd99b1aa99b693d796d.exe
29. windowsxp-kb2802968-x86-fra_5684830a14b2ff03134d2e197bb911175758982c.exe
30. windowsxp-kb2780091-x86-fra_32535047dd9bb3f39980899d54cfd64ea84a77d2.exe
31. windowsxp-kb2757638-x86-fra_70f1d2a16feb5eae14db923d721ec8efae6e1fdd.exe
32. windowsxp-kb2770660-x86-fra_1d5b6f6630b897b75dd768cb4ca43987757b3d91.exe
33. windowsxp-kb2727528-x86-fra_7db54f78e617491013cc7039d13ff84604cc932d.exe
34. windowsxp-kb2749655-x86-fra_c3696874ef16f116b2e17caccc0b3d2b57e70dab.exe
35. windowsxp-kb2723135-v2-x86-fra_9d1f1096273972a4b0eca541f6f0bdbdb2207fc4.exe
36. windowsxp-kb2705219-v2-x86-fra_ef80f21b5bfb3d655ebe6e2e409d42b7c33dab46.exe
37. windowsxp-kb2691442-x86-fra_4f035a064cf71dc1b9d106e108c36b59242d01e7.exe
38. windowsxp-kb2655992-x86-fra_0a5d8417f5db6cb0050e28414e83fe9e7df92543.exe
39. windowsxp-kb2719985-x86-fra_5c3e607a2d401ee2563ce12e53e91326e54dc2a4.exe
40. windowsxp-kb2698365-x86-fra_639b97a54741aee89eff8bdc18431f2bc296f886.exe
41. windowsxp-kb2712808-x86-fra_f2e8bb6761b56e1fc824706864d7c7df8c9857ee.exe
42. windowsxp-kb2686509-x86-fra_2ffa0dd365ebf5f3d28c60c111e5ac547749effb.exe
43. windowsxp-kb2676562-x86-fra_a1534f836f5dd88bf97334daf61ff17915ed8941.exe
44. windowsxp-kb2653956-x86-fra_d7329abe4f8518bff988af38839d2d9ef4cf7586.exe
45. windowsxp-kb2659262-x86-fra_4340b20f587536cf2f59944aa688d42e2da3b50d.exe
46. windowsxp-kb2661637-x86-fra_8e4a7750367b6ba9d6118de61db3e146e3e02708.exe
47. windowsxp-kb2584146-x86-fra_881a53107317f560855a6a8f54bfe6e3054547e2.exe
48. windowsxp-kb2631813-x86-fra_8d40cf67f59972e285dcef944bb1bd87cbfde552.exe
49. windowsxp-kb2585542-x86-fra_4cdf66f47d380ed21ccb3c5a22a70c2f5f37f023.exe
50. windowsxp-kb2603381-x86-fra_d5c9c44bb71a8ddb159aa64ed18d651d917de5f6.exe
51. windowsxp-kb2598479-x86-fra_53b30306576f2ed5854c4dac86e08a629a8e0705.exe
52. windowsxp-kb2619339-x86-fra_d72919bcbf9e58fb81e54c01ea5e63763578ab31.exe
53. windowsxp-kb2620712-x86-fra_4c1830ef9edff030258f704651ff7d20f1045f99.exe
54. windowsxp-kb2544893-v2-x86-fra_6d13f787c767be627e61b4acbc8af60de23078b6.exe
55. windowsxp-kb2592799-x86-fra_d30ffedf75460f4cfc03a04a6b7380913c7ece12.exe
56. windows-fr-fr-kb2564958_542a9a2adc8fd7a40aa6deb756f156da1562b767.exe
57. windowsxp-kb2570947-x86-fra_46d81f78d6a5d1c2190c24b322e675f93fb9f57c.exe
58. windowsxp-kb2566454-x86-fra_7a4cde623fcad462d843464a14c483740b0847b9.exe
59. windowsxp-kb2536276-v2-x86-fra_9ffadc0cd78ffce265dc943556787708039f68cc.exe
60. windowsxp-kb2507938-x86-fra_9583aa7f2cca90c4b99d5ccb8e4c6b7fecf5870a.exe
61. msxml4-kb973688-fra_720624d5b05e6eca8c583423342b9054db45f450.exe
62. msxml4-kb954430-fra_801ac30305d0205b59e58dc21afe7d095ffe795a.exe
63. windowsxp-kb2535512-x86-fra_f834ad29b7a9d6f1fe47a11d3a4ec8dd22c73908.exe
64. windowsxp-kb2485663-x86-fra_b8ec3e47cf4ea719cbe315f3c23c7df381fdc36e.exe
65. windowsxp-kb2508429-x86-fra_e7dc41154dca470c3441bed05490f7e038102c4e.exe
66. windowsxp-kb2506212-x86-fra_6dd03e0e7bfdcf4755babd7cf3c6be928e912815.exe
67. ie8-windowsxp-kb2510531-x86-fra_e139c8dd85b0b5e02228fffa0f5f2ea1db70b3d4.exe
68. windowsxp-kb2509553-x86-fra_14f0ac8c16f3ef4b153ea760cbe366e6b9513fee.exe
69. windowsxp-kb2479943-x86-fra_e56dbc143da69e37c8576b81bf2607023a89c5dd.exe
70. windowsxp-kb2481109-x86-fra_6ad1e76456a148e2a25fbf11af4b9b11cb3dd9f3.exe
71. windowsxp-kb971029-x86-fra_733a092981170031b2da0f8e9648cc9acb56b3a4.exe
72. windowsxp-kb2478971-x86-fra_5527a6870cd2910a69bc33a5bb05620c1001743d.exe
73. windowsxp-kb2483185-x86-fra_e933e23bfc4ad414bdc12f09260aee708d0a3b6a.exe
74. windowsxp-kb2478960-x86-fra_187bb1b339546433e7552d98a5e79d5d262ae56f.exe
75. windowsxp-kb2393802-x86-fra_4cd46d329fadf46f93a5016c5800804045bfd65a.exe
76. windowsxp-kb2419632-x86-fra_266a545a362ea36243f63b59982a57e73906c577.exe
77. windowsxp-kb2423089-x86-fra_92ffccc6f420949bd65f6311a8dda71ce7c9f5db.exe
78. windowsxp-kb2443105-x86-fra_2cce70e03cfb99286ea146656a0f9a6cca3e7014.exe
79. windowsxp-windowsmedia-kb975558-x86-fra_858324baa6e922bd6109b6e016ef68ea8afd7066.exe
80. windowsxp-kb979687-x86-fra_1e531d32f6d7caeab2e0d873172190812ed0e99c.exe
81. windowsxp-kb2296011-x86-fra_8b764b838f04d6dd3bc56d3c3870e16a25fc5eeb.exe
82. windowsxp-windowsmedia-kb2378111-x86-fra_25c88b67725dc90e338f1df16b064e25bd786bb2.exe
83. windowsxp-kb2387149-x86-fra_0b268aab355ed01c8c0f26ba094d20b139dc4f21.exe
84. windowsxp-kb982132-x86-fra_61dd0ce599e824b202923f3015dc3fb335a79b9e.exe
85. windowsxp-kb2347290-x86-fra_6e30167ab439fc9a851d0c18646bf533deef0f20.exe
86. windowsxp-kb2115168-x86-fra_eaa602e948f9858eb6b863eaf908a25ae399eddf.exe
87. windowsxp-kb982665-x86-fra_b83e71907fb440c0502ed5219783ea2e744f9bf4.exe
88. windowsxp-kb981997-x86-fra_fc3b2f7252aedaa95a1bd6c2f7a153266f976afe.exe
89. windowsxp-kb2229593-x86-fra_df9d16a089b4d431ff79d9b4d814aeb5fd86f1cc.exe
90. windowsxp-windowsmedia-kb978695-x86-fra_71338575ec468299ceae0f5d60e8f70f26bad5dc.exe
91. windowsxp-kb979482-x86-fra_0029a51943fd2cb54ecd7a604bb2c532e6b2c80d.exe
92. windowsxp-kb978542-x86-fra_7876ce5f6e33b7c0d18c954838baa3b37cddbdc1.exe
93. windowsxp-kb977816-x86-fra_136b56a526869af6aaf3b9b676190c5d5df35895.exe
94. windowsxp-kb978338-x86-fra_95a1c3aeaaf3e5817b48368fe0f27d8c842c7f7e.exe
95. windowsxp-kb975713-x86-fra_2fcb1b8e194cda2cf0c102051a48f4090d500bf2.exe
96. windowsxp-kb975560-x86-fra_6f7e2b9532460d438ea555ea963bea0cabcb5c22.exe
97. windowsxp-kb977914-x86-fra_a8144d88ee7393b8ba9a73a0047e0f67c3d28719.exe
98. windowsxp-kb978706-x86-fra_7d0d8599c5d7272c7a0338673876cc3d8f143e7b.exe
99. windowsxp-kb972270-x86-fra_35a23117cc752666970bdb9531a7bc48dc5660c4.exe
100. windowsxp-kb974318-x86-fra_4ad25a0f507802c4f4ee4b0e7094381ec24daf78.exe
101. windowsxp-kb974392-x86-fra_0786f059b5a7f458a22b356f38302a67874ed313.exe
102. windowsxp-kb973904-x86-fra_47e1a0e456db598cbcfa9c30767ddfb8b94cbd06.exe
103. windowsxp-windowsmedia-kb952069-v2-x86-fra_7966151067cecb61bb9a109e6d919ab1dfb6e0f6.exe
104. windowsxp-windowsmedia-kb954155-x86-fra_9964fe12c75d8930f23fc1813f1b73e66973ea26.exe
105. windowsxp-kb975025-x86-fra_73744a65cc62737cb29cf19e58f873d6d21e9004.exe
106. windowsxp-kb974571-x86-fra_d982c563ad114bc8eae6a9d062db2ec0fd90ae1e.exe
107. windowsxp-kb974112-x86-fra_d6198af9ac029e9f00ea8df49205e6472c0c5f50.exe
108. windowsxp-kb969059-x86-fra_86776dc8183750bbc6a8dba093c68b89eb35c57e.exe
109. windowsxp-kb975467-x86-fra_887c3c52a52c9001fddc80544970a9cb53a21bcf.exe
110. windowsxp-kb968389-x86-fra_deb3ae7253b28b45da288307a97abdc919153e21.exe
111. windowsxp-kb956844-x86-fra_1b6604c5090a3deae04a59e3165def1512da71df.exe
112. windowsxp-windowsmedia-kb973540-x86-fra_b81617387f881da2409ed4d94dec80b5b2a60937.exe
113. windowsxp-kb973869-x86-fra_67ba8d8e5f8724abc9b6946589ca069a68c05c72.exe
114. windowsxp-kb973507-x86-fra_4659a34e1b1c894f7d735ff964be88bfc35e95a8.exe
115. windowsxp-kb960859-x86-fra_8486688e8290ce8eeff58b09dada9c53d278f191.exe
116. windowsxp-kb973815-x86-fra_a8295ed09f2ad24e804ec347e26057a0939ed6a1.exe
117. windowsxp-kb971657-x86-fra_48bf43f8085a51c2ef4d13db2ce445a1f2b5f951.exe
118. windowsxp-kb923561-x86-fra_ab1a2bc76f20dda42f424de3c9e0e3dbb839aa50.exe
119. windowsxp-kb956572-x86-fra_0a4bc6b5283278c08356ef9f9b4804d1168eff0d.exe
120. windowsxp-kb960803-x86-fra_b037ae1f31b7da3970a0bdf0f98bf3615a03fe61.exe
121. windowsxp-kb959426-x86-fra_00ae77f6913605380bde32a387fa0898e1d14aa4.exe
122. windowsxp-kb950974-x86-fra_a018257343518801ce058c53fb74cb6025273246.exe
123. windowsxp-kb952287-x86-fra_fe9854ab4b3165961c318b320c9999548ab91831.exe
124. windowsxp-kb946648-x86-fra_a0536cf2ad0aa6eee89dcad24d61b341697adaa3.exe
125. windowsxp-kb952954-x86-fra_1cf3f9bb15f39eb716ad9ba1fbbc1f71598cb879.exe
126. windowsxp-kb951978-x86-fra_addece515a2e4fe068263e908e2844e73a88b475.exe
127. windowsxp-kb951376-v2-x86-fra_002eef16106ba0cbcef234150e75c2e67ead14a6.exe
128. windowsxp-kb950762-x86-fra_98630e0c97ea8f4558f3d45c32597cbfe34d9eeb.exe
129. windowsxp-kb941569-x86-fra_67b76669155511f7b2e9469dd9482deb54ed09d7.exe
130. windowsxp-kb2808679-x86-fra_4dada0c0e96a06513ab299a3e7d1c0fecaddf603.exe
131. ie8-windowsxp-kb2632503-x86-fra_2f53f2dc30989c2344953f2d0e2709b5470510e5.exe
132. ie8-windowsxp-kb2598845-x86-fra_718c3eb3d6dc662aae1dde659844ae4024015e83.exe
133. windowsxp-kb2492386-x86-fra_475c72484670d80a497d5480e40280248d2b5828.exe
134. windows-fr-fr-kb971513_dc5b55ee3574b3552c9a119d4cbc155143e1f4d5.exe
135. wmp11-windowsxp-x86-fr-fr_614eef4c7563eea4e2097d4270666e5ea58dfeaf.exe
136.
137. windowsmedia11-kb939683-x86-fra_e313b7de96183f4aeaa23069ff09b75174ae223e.exe
139. windowsmedia11-kb954154-x86-fra_65bf0a3a8a245d44ea9134c4c6e31d7e55b56694.exe
141. windowsxp-kb952004-x86-fra_4ca9736b24d3fc7f50acc3ec0474c8dadae1373d.exe
142. windowsxp-kb970430-x86-fra_88a7300418ff2108edae3f8b7bfeda814e2fff69.exe
143. windowsxp-kb2345886-x86-fra_c2f64a929a22bf5aaba89cc6c9479cfa2cd9b1c8.exe
144. windowsxp-windowsmedia-kb2834904-v2-x86-fra_766f4fb5d80e29217f9ed2824ebe0d0cce3c19e1.exe
POS 2009
145. windowsxp-kb2926765-x86-embedded-fra_473dedea2284f80414199d4d1ce8eb74747d4988.exe
146. windowsxp-kb2993651-x86-embedded-fra_2478abe417502f875b9929593f9cf8dbc6e78eab.exe
147. windowsxp-kb2993254-x86-embedded-fra_1ede6e26bc6a6d613e52e0b01d8dee1a21331ae5.exe
148. windowsxp-kb2998579-x86-embedded-fra_e6119982560a4d3e80636c84b1ac735724cb4d58.exe
149. windowsxp-kb3013126-x86-embedded-fra_35635880dac31ea4675fef076815dc99b0224fb4.exe
150. windowsxp-kb3020393-v2-x86-embedded-fra_dd567fa3d260f18d8299314a4d61dc1ea7d75308.exe
151. windowsxp-kb3021674-x86-embedded-fra_08d84ae81d3556abdbc4cf3781adb7fafcc2781c.exe
152. windowsxp-kb3004361-x86-embedded-fra_ce69c6bfc307e62e60a825f43a983f0064bd302f.exe
153. windowsxp-kb3029944-x86-embedded-fra_0d2b9203307f834f0b1379dbc0e52581177c0d97.exe
154. windowsxp-kb3033889-x86-embedded-fra_3357dbc788827c6bff710b8b3e23b67af5b9cfc6.exe
155. windowsxp-kb3035132-x86-embedded-fra_2d5780bc7c6f12b0aa3a09fd47d5998efa4fc3dd.exe
156. windowsmedia11-kb3033890-x86-fra_b621d15c9f8276659496257f46b894a38d9f7413.exe
157. windowsxp-kb2926765-x86-embedded-fra_473dedea2284f80414199d4d1ce8eb74747d4988.exe
158. windowsxp-kb3065979-x86-embedded-fra_0a497f3aa28713a46295208d88d5d4f33b4c4ed3.exe
159. windowsmedia-kb3067903-x86-fra_5025fc6940832eac4110166589b036745a524c05.exe
160. windowsxp-kb3078601-x86-embedded-fra_247aeb9bcb89de84b46c09c45d0d4065b002b8f6.exe
161. windowsxp-kb3087039-x86-embedded-fra_1c69e5d4f985d2ade834a1ebab8dee6979d23fde.exe
162. windowsxp-kb2957503-x86-embedded-fra_525ace14866f393a8107d8cd28df2021aaa6ed1a.exe
163. windowsxp-kb3109560-x86-embedded-fra_dffa7f360854d42c8a0c88abe84f50ba9b9a8dee.exe
164. windowsxp-kb3121918-x86-embedded-fra_fddc52013a843464f56cc3d12d98b59c8e28d6b3.exe
165. windowsxp-kb3126593-x86-embedded-fra_242fb72339a629192a597a409efc1008ab565b5c.exe
166. windowsxp-kb3126587-x86-embedded-fra_5d2355a51dd1855730adb629a4c7335f4b0e272d.exe
167. windowsxp-kb3139398-x86-embedded-fra_a61edf9ec3e894726ceec58e23bed146a296fe2b.exe
168. windowsxp-kb3081320-x86-embedded-fra_c9808400d925bcf4edf05583e5e89bf8455d41af.exe
169. windowsxp-kb3139914-x86-embedded-fra_8d7c07401025a684a464b95beb2a2d9e7033c15e.exe
170. windowsxp-kb3140709-x86-embedded-fra_51c48a1fea047d4be86ed05cfb7eae5f72f07732.exe
171. windowsxp-kb3149090-x86-embedded-fra_8a55843f3e0888492b8748f925b953146a419421.exe
172. windowsxp-kb3145739-x86-embedded-fra_20bf0a0279ba4d899ba1a872bf073ad1f5551b8f.exe
173. windowsxp-kb3161561-x86-embedded-fra_a12fb86e9680f778ad8ea0e073026bdcb0399818.exe
174. windowsxp-kb3161949-x86-embedded-fra_6e2305effdf91e3574446b86d712943c65a738eb.exe
175. windowsxp-kb3170455-x86-embedded-fra_06d8e7f0bf4b6110800bb2fb8e486cdd508c301e.exe
176. windowsxp-kb3092601-x86-embedded-fra_cedea6194c50b23febec96bdfbb3cbe534c3deaf.exe
177. windowsxp-kb3178034-x86-embedded-fra_5c9eaab7d9b3996f9ee946feb0f5231b727749bd.exe
178. windowsxp-kb3196718-x86-embedded-fra_d25fc6aa1c1158757403ef609473cb9d67399c13.exe
179. windowsxp-kb3198510-x86-embedded-fra_b61bebb2b9c44c70b01d0459676b3be4184696c1.exe
180. windowsxp-kb4012583-x86-embedded-fra_fcb09571c8a7237721d7e8470dc0d066b6118211.exe
181. windowsxp-kb3185911-x86-embedded-fra_e4855327596e8ffb2881232593f173bae668c485.exe
182. windowsxp-kb4012584-x86-embedded-fra_cf58fe322101f4706c1da4bac2761b25830a9c42.exe
183. windowsxp-kb4014652-x86-embedded-fra_aa2f2c9a765ad9757a4756b50d85cdfd2abdf1ca.exe
184. windowsxp-kb4014794-x86-embedded-fra_eca8ac9bec3f4ec7c03afdfc6fa1d51a9548d181.exe
185. windowsxp-kb4015383-x86-embedded-fra_b75ecf6dfbbdc32e776f9ab186c11f9595b4985c.exe
186. windowsxp-kb4022747-x86-embedded-fra_691038032376c1e633a9d66486c3deb336737e68.exe
187. windowsxp-kb4024323-x86-embedded-fra_6742bc29b736aa90d127f997a0e2b09e3fb658b4.exe
188. windowsxp-kb4025218-x86-embedded-fra_2fa510d324490a41930c6e04612a604800758b42.exe
189. windowsxp-kb4026061-x86-embedded-fra_4ba0504dc585a239740b2313a6a9c95fb57925d1.exe
190. windowsxp-kb4025497-x86-embedded-fra_41c6ce9a9cde29695d935a8e59ae047e12b56cb2.exe
191. windowsxp-kb4025409-x86-embedded-fra_8fd16ab9535b7a58dfab89b9535d4038d53af191.exe
192. windowsxp-kb4034775-x86-embedded-fra_f96a404e5470a5ad162ac519b2448305f7d2bacf.exe
193. windowsxp-kb3183431-x86-embedded-fra_951812b505925b2180548d30f7e70ffa0db2c55c.exe
194. windowsxp-kb4047211-x86-embedded-fra_a0e321b8878f34f164422e5e2bfbfaf48ea80cfc.exe
195. windowsxp-kb4052303-x86-embedded-fra_e693bd59db87dd84cecd3be3e5e7b8cd2b7aa170.exe
196. windowsxp-kb4056941-x86-embedded-fra_56a5c2d419f9542a528b8729b034bd316f2e1e81.exe
197. windowsxp-kb4089175-x86-embedded-fra_24e9bbae33d694236a197f69e8b28744bfdfd931.exe
198. windowsxp-kb4089082-x86-embedded-fra_3bb675d1723e9ddcf2963d44ac3ce1e7904713d9.exe
199. windowsxp-kb4089694-x86-embedded-fra_d0ddc3794515b8af26e77d3746334176132bdac8.exe
200. windowsxp-kb4039384-x86-embedded-fra_a69fd614dd68dfad916f1dba8993d3dfba2eba8b.exe
201. windowsxp-kb4091756-x86-embedded-fra_993789edfdd179e6ba7011327ff9562f45d24ef2.exe
202. windowsxp-kb4130957-x86-embedded-fra_f1a5c868d8c7a566ae64486a5f745a42637dc496.exe
203. windowsxp-kb4101477-x86-embedded-fra_b2c3f15fb5dbc1be67b5eb399b7cba384e33863b.exe
204. windowsxp-kb4056564-v2-x86-embedded-fra_adf0ba092e0e09d606ccc69201dba5680c52f2d2.exe
205. windowsxp-kb4089453-v2-x86-embedded-fra_8a6ef0ee6297278b429b731f760b013c97ebf4df.exe
206. windowsxp-kb4294413-x86-embedded-fra_7c71363c2312c1e04cafcff2e090256f354d80b7.exe
207. windowsxp-kb4291391-x86-embedded-fra_907ee4e2209e3df52b98d01d8760ca52e1f5a512.exe
208. windowsxp-kb4343674-x86-embedded-fra_f0f3692f98a230a9ac89c446b0b798afa3a77787.exe
209. windowsxp-kb4041995-x86-embedded-fra_d0794b129e78e06621b93d1dfa14fc6a2226dbcc.exe
210. windowsxp-kb4458000-x86-embedded-fra_9775e47aa9b96293695e443817eb135e6b154750.exe
211. windowsxp-kb4458318-x86-embedded-fra_23b3069c5dca17ae7ba5dfab857c8fe88d605cbe.exe
212. windowsxp-kb4458006-x86-embedded-fra_9fbd7db76ae29c3790fc3cc0cfd6ec5a2d665dd2.exe
213. windowsxp-kb4462935-x86-embedded-fra_13116255c2eda02fbd5d2d624e01b7f9fd9ff779.exe
214. windowsxp-kb4462987-x86-embedded-fra_62944d120818693b6e3a83dfabb8ee84767af9d1.exe
215. windowsxp-kb4458001-x86-embedded-fra_249568bedcc1107e47786f79ee1f611245b1966b.exe
216. windowsxp-kb4463103-x86-embedded-fra_dab35a7bc9f3d96274a4a4cfa09adc417e6d096e.exe
217. windowsxp-kb4463573-x86-embedded-fra_6dbc107850ea2ecce188c85f8c4329ded0d1b31f.exe
218. windowsxp-kb4470118-x86-embedded-fra_c2509c9d9162fbe7ebd7179ff33756a1dd03c01d.exe
219. windowsxp-kb4467689-x86-embedded-fra_07b294183f0a09e59e48abe9a0f6528ebf50b400.exe
220. windowsxp-kb4473077-x86-embedded-fra_edb4f447ff44da2333503ec1b7ac5b6cea8fc0aa.exe
221. windowsxp-kb4468323-x86-embedded-fra_0eb7d4a0f02d37628356f404347fe58aab5a9575.exe
222. windowsxp-kb4486463-x86-embedded-fra_c29d7cb609e2179324ae30d03439fed398869502.exe
223. windowsxp-kb4457163-x86-embedded-fra_7b01ee905db51eec50d649465e59ef21dd9767ca.exe
224. windowsxp-kb4487086-x86-embedded-fra_3fafe74c8230aad770c464db689d90f5e0e78b2d.exe
225. windowsxp-kb4489493-x86-embedded-fra_34e4de235eeca5b2856a27430bc184bd1247e31f.exe
226. windowsxp-kb4490228-x86-embedded-fra_3bf86c8118753262cacd41279d31a0b259a75268.exe
227. windowsxp-kb4489973-x86-embedded-fra_75ab9f9c8c1f74a367967d1f2b1f1325ec94fe84.exe
228. windowsxp-kb4490501-x86-embedded-fra_6f8697bffcc21c1b5c1685e254c6c29baf55c03e.exe
229. windowsxp-kb4490385-x86-embedded-fra_cf099544095cb37f8e93c49f77a82664cc94c06a.exe
230. windowsxp-kb4486468-x86-embedded-fra_d708decbe2bb4b62005612299c51aa9a7106954d.exe
231. windowsxp-kb4486538-x86-embedded-fra_c5fba76fcf21dc3bd4a1479c4af8d3f23b857304.exe
232. windowsxp-kb4486536-x86-embedded-fra_4f7dd5750e853844cf1943d51ed718937bd9009b.exe
233. windowsxp-kb4486465-x86-embedded-fra_c374a759e632dc6295e174499b5811f2392a925e.exe
234. windowsxp-kb4493341-x86-embedded-fra_085cd9ac5de90d2f781710eaab873147a3159909.exe
235. windowsxp-kb4489977-x86-embedded-fra_739e66c447ada8cf456a18474015f07bae14078a.exe
236. windowsxp-kb4489974-x86-embedded-fra_2af9b504edffbfb1f8394783ec2c715d08296871.exe
237. windowsxp-kb4487989-x86-embedded-fra_cdd23467512190dcbe4fee77ac64ce8ff951d10d.exe
238. windowsxp-kb4491443-x86-embedded-fra_66541d9dfe5660072fb95cee4fc297d3a7915ccd.exe
239. windowsxp-kb4486924-x86-embedded-fra_dd925f117175df5e7ffc0ed98fc1e75409c0fa86.exe
240. windowsxp-kb4487085-v2-x86-embedded-fra_a2eb75ff0c8adebaf337581b64ffe43ebad92ed7.exe
241. windowsxp-kb4494059-x86-embedded-fra_4f097574bdcef8c7873304bc713ff65fdeab4f08.exe
242. windowsxp-kb4493797-x86-embedded-fra_cfb09ff913fd1fcb89b3be26801be6aa4ba9fd73.exe
243. windowsxp-kb4493796-x86-embedded-fra_558c7a134ebc9dbe8923c68a3839e9bad3e4a3f7.exe
244. windowsxp-kb4493927-x86-embedded-fra_d721cc156d4dfc21ac4a6acfc888f2879ec230cc.exe
245. windowsxp-kb4493795-x86-embedded-fra_ad8f2cb46bb21c957a8d87c68cb3ba2770c92324.exe
246. windowsxp-kb4493793-x86-embedded-fra_4ee0a692de4bf4758de655c05ace597f6835f754.exe
247. windowsxp-kb4493563-x86-embedded-fra_e88338d01d5edd93f3ec14098fbf7d0b8c457004.exe
248. windowsxp-kb4493794-x86-embedded-fra_b07bd09bf80e680547635be79b5b3b0f88718e3b.exe
249. windowsxp-kb4487990-x86-embedded-fra_ad2c84efa422b390598d22186b9ba455610a0e06.exe
250. windowsxp-kb4495022-x86-embedded-fra_224b0762a60862ad05ac6b1ae9951f537d52afac.exe
251. ie8-windowsxp-kb4493435-x86-embedded-fra_14c3d3122eb7fcc3dc71b59e4f4f929b36ede76e.exe
252. windowsxp-kb4493790-x86-embedded-fra_bc0ad4bee8ee8ff38072bd241ba145cc51036cbe.exe
253. windowsxp-kb4494528-x86-embedded-fra_a96c2ee93cee34f3cabea5451aad294fb5501e1c.exe
254. windowsxp-kb4019276-x86-embedded-fra_e64620dd209adce9e506c1a3ead9f11b73bb3397.exe
255. windowsxp-kb4459091-x86-embedded-fra_85e0159f2c48bf7cbe0ecb67a8a4d0d76b612e68.exe
256. windowsxp-kb4467770-x86-embedded-fra_20a8538822f17115481f0c9db7c470c26523948e.exe
