2021-04-19 08:19 »
It was FTP login tries. I checked log files. It's all good because FTP root is empty but still annoying to see these. It's not a lot of hits so I can't bothered to block the IPs. I'm dying without a computer. 😭🤢 :sick: :cry:
2021-05-12 20:30 »
Got another try today, someone "TEST"... well, here is your test mother fucker, I blocked the entire range! :lol: :sick: :mrgreen:
2021-05-15 21:18 »
https://serverfault.com/questions/23322 ... pts/397637
The file log doesn't seem to work but meh, I'm giving it a try. I ran it manually and seemed to work! It added the IPs to the firewall block rule! Very cool! Hopefully it will work when the event triggers it too. I cleared all the IPs, but I altered it so that it will add on first failed RDP login attempt, should be good.
#Checks for IP addresses that used incorrect password more than 10 times
#within 24 hours and blocks them using a firewall rule 'BlockAttackers'
#Check only last 24 hours
$DT = [DateTime]::Now.AddHours(-24)
#Select Ip addresses that has audit failure
$l = Get-EventLog -LogName 'Security' -InstanceId 4625 -After $DT | Select-Object @{n='IpAddress';e={$_.ReplacementStrings[-2]} }
#Get ip adresses, that have more than 10 wrong logins
$g = $l | group-object -property IpAddress | where {$_.Count -gt 10} | Select -property Name
#Get firewall object
$fw = New-Object -ComObject hnetcfg.fwpolicy2
#Get firewall rule named 'BlockAttackers' (must be created manually)
$ar = $fw.rules | where {$_.name -eq 'BlockAttackers'}
#Split the existing IPs into an array so we can search it for existing IPs
$arRemote = $ar.RemoteAddresses -split(',')
#Only collect IPs that aren't already in the firewall rule
$w = $g | where {$_.Name.Length -gt 1 -and !($arRemote -contains $_.Name + '/255.255.255.255') }
#Add the new IPs to firewall rule
$w| %{
  if ($ar.RemoteAddresses -eq '*') {
    $ar.remoteaddresses = $_.Name
  }else{
    $ar.remoteaddresses += ',' + $_.Name
#Write to logfile
if ($w.length -gt 1) {
  $w| %{(Get-Date).ToString() + ' ' + $_.Name >> '.\blocked.txt'}
2021-05-16 00:57 »
$w| %{
  }else{
#Write to logfile
Log: Security.
Source: Microsoft Windows security auditing.
That's how it should be I think. It didn't trigger so I adjusted it this way. Now it should work. Waiting for new login attempts now.
2021-05-16 01:53 »
$w| %{
  }else{
#Write to logfile
Log: Security.
The task triggered now but the .PS1 file didn't run. Trying to execute it this way instead of directly pointing to the file:
2021-05-16 02:00 »
$w| %{
  }else{
#Write to logfile
Log: Security.
Didn't run. Trying to put the command in a .BAT file instead. I think I locked Windows to not allow running .PS1 files. The task itself triggers fine though.
2021-05-16 02:20 »
$w| %{
  }else{
#Write to logfile
Log: Security.
Cool! It works now! :thumbup: :clap: :smile:
2021-05-16 02:39 »
This script is so cool! I set it to block in the first failed login try. I'll probably catch a looot of infected IPs now in this list. Too bad the Windows log doesn't go back more than 30 days I think. This removed such a big headache from me. :sick:
2021-05-16 21:05 »
Hahaha this works great! Although, it seems that the event triggers late, so each IP manages to get a few tries in the first few seconds but should be fine.
2021-05-18 23:04 »
There was an IP from Russia that did a "test" login, to see if it is active, after that, a lot of login tried started from Europe, probably infected servers that are controlled by this person. I don't remember the IP though, can't be bothered to save these stuff without a computer. So far I added ~33 IPs in the firewall block list, they seemed to have stopped. Probably will be seeing another "test" login soon. :sick: :mrgreen: :mrgreen:
