2021-05-27 04:01 »
https://redmondmag.com/articles/2021/05 ... ility.aspx:
Using any of the following?
Dell firmware update utility packages
Dell Command Update
Dell Update
Alienware Update
Dell System Inventory Agent or
Dell Platform Tags, "including when using any Dell notification solution to update drivers, BIOS, or firmware for your system."
Then you should read up here:
https://www.dell.com/support/kbdoc/en-u ... nerability
According to the article:
Alternatively, users of Dell notification solutions can use that service to run the DSA-2021-088 utility starting "on or after May 10, 2021" to remove the driver.
