2021-06-24 07:24 »
https://www.howtogeek.com/351164/secret ... d-drivers/
To restart your graphics drivers, press Win+Ctrl+Shift+B on your keyboard.
Your screen will go black for a split second and you’ll hear a beep. Everything will then reappear just as it was before you pressed the hotkey. All your current applications remain open, and you won’t lose any work.
We even tried this shortcut while playing a PC game. The game kept running properly after we used the shortcut. That’s because Windows just restarts the graphics subsystem. All your applications are left alone and will continue running normally.
2021-06-25 03:03 »
Very very very very cool. I needed it many times when I had a computer but didn't know about it.
2021-06-25 07:36 »
Indeed! I sorta wish I had found this before removing Win10. Oh well.
2021-06-30 00:58 »
hahaha aw
2021-07-12 08:09 »
FYI, I can confirm that this DOES work. :thumbup:
2021-07-24 07:49 »
Are all 'gaming' video cards essentially experimental junk?
2021-07-24 08:40 »
sudo dpkg-reconfigure keyboard-configuration :wink:
2021-07-24 09:01 »
I was about to pull my hair out, thinking this would apply to the current session. A reboot was require :relaxed:
2021-07-26 18:25 »
Cool theme and background wallpaper! :thumbup:
