2024-04-22 00:26 »
Putting a call out, in case someone knows where to find this file. Someone at MDL was looking for it:
https://ftp.zx.net.nz/pub/Patches/ftp.m ... 96/128.HTM
The Computer May Stop Responding When Loading MSHBIOS (296128)
The information in this article applies to:
Microsoft Windows 98 Second Edition
Microsoft Windows Millennium Edition
This article was previously published under Q296128
SYMPTOMS
Some computers may stop responding (hang) when loading MSHBIOS, a component of the Far East version of Windows that enables users to enter double-byte character set (DBCS) characters in an MS-DOS prompt window.
CAUSE
Some newer video basic input/output systems (BIOS) may require more stack space than MSHBIOS provides. Video interrupts may then cause Windows to hang.
RESOLUTION
A supported hotfix is now available from Microsoft, but it is only intended to correct the problem that this article describes. Apply it only to systems that are experiencing this specific problem.
To resolve this problem, contact Microsoft Product Support Services to obtain the hotfix. For a complete list of Microsoft Product Support Services telephone numbers and information about support costs, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/?ws=support
Note In special cases, charges that are ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The usual support costs will apply to additional support questions and issues that do not qualify for the specific update in question.
The Korean version of this fix should have the following file attributes or later:
Date Time Size File name Operating system
20-Apr-2001 09:38am 58,480 Mshbios.com Windows 98
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
MORE INFORMATION
This problem has been observed on a limited number of computer models, all of which are available with the update that this article describes pre-installed.
For additional information about Windows 98 and Windows 98 Second Edition hotfixes, click the article number below to view the article in the Microsoft Knowledge Base:
206071 General Information About Windows 98 and Windows 98 Second Edition Hotfixes
Note that verbiage:
Also not the file 'mshbios.com' has a file size of 58,480 bytes.
It pre-installed on some systems. Further:
https://www.sony-asia.com/electronics/s ... S500030314
The startup disk that was created cannot boot the VAIO computer.
To resolve this symptom, please contact Sony Korea VAIO Helpdesk for the following patch program.
Patch Name: 296128KORM.EXE
For infomation on this symptom, please refer to the following solution in Microsoft's technical support website.
Article ID: Q296128
Last Modified: March 13, 2002
Title: The Computer May Stop Responding When Loading MSHBIOS
URL: http://support.microsoft.com/directory/ ... .asp?ID=KB
Some Sony VAIO laptops would have had to have this file for the Emergency Boot Disk to work. I'm assuming this *mostly* would have been for WinME.
