You probably have some other package installed because its suppose to display Windows 98 Second Edition
I double and triple-checked any check-boxes before installation and none of them were checked except Main Updates / System core files. (even though I could've been blind at first glance)PROBLEMCHYLD wrote: ↑2020-11-19 19:39You probably have some other package installed because its suppose to display Windows 98 Second Edition
At this point I'm having doubts if it's actually Win98 SE that is installed on my rig and not the standard Win98 (non-SE).
Desk.cpl is broken anyway because of some fishy nVidia drivers I installed so I'll have to reformat and throw in another Win98 SE installation.
Thank you for your reply :) I will pay more attention to the check-boxes on the next Win98 installation
I just re-read this whole topic from Beginning to Ending. Shit is hilarious
Added AUTOCHK.EXE 5.1.2600.5512 Windows XP SP3
Added FILE64.DLL + FILE64.VXD 4GB file size limit rloew patch
Added IMAGING.DLL 5.00.2210.1 WinME CD (Image Preview)
Added PATCHMEM.EXE rloew patch
Added SATA + SATA.INF rloew patch
Added SHIMGVW.DLL 5.50.4134.100 WinME CD (Image Preview)
Added WDMEX.VXD rloew patch
Fixed TIMEZONE.INF
Removed WDMSTUB.SYS
Tailored the SP to work on Qemu VM
This is what my future holds, what about yours?
Fixed TIMEZONE.INF
Removed WDMSTUB.SYS
Don't spoil the ending...PROBLEMCHYLD wrote: ↑2020-11-21 04:10I just re-read this whole topic from Beginning to Ending. Shit is hilarious
Hello ! I have a problem with the way folders are displayed.
Every time I install Windows 98 SP3 v3.65 - Main Updates / System core files ( only )
the information bar on the left of the window disappears, although the [as Web Page] option is checked,
and on the internet explorer 6 I can no longer access web pages. Looks like it stuck in a kind of refresh loop.
I already searched on google without finding any solution.
How can I restore the "View Folders as Web Page" option?
Thank you in advance !
- Attachments
- 2.jpg (807.74 KiB) Viewed 5065 times
- 1.jpg (1.06 MiB) Viewed 5065 times
