Software development, scripting and programming.
2014-06-10 21:57 »
Does anyone here no how to create VB Scripts. I need a VBS to disable the Recycle Bin, but giving you the option to choose which drive to disable.
RFMaster
2014-06-11 00:43 »
http://msdn.microsoft.com/en-us/library/yfdfhz1b.aspx
And your target is -> [HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionexplorerBitBucket]
2014-06-11 01:50 »
I saved that page which RFMaster linked to in here. Microsoft MSDN URLs tend to die a hard death and I hate dead links. :oops:
RegWrite Method_files.zip
(47.21 KiB) Downloaded 17438 times
2014-06-25 20:10 »
Can anyone write up one?
2014-06-25 23:23 »
PROBLEMCHYLD, I'm on XP and under:
There's keys for my drives c,d,f:
Anyway, this works for me:
Dim WshShell, bKey
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.RegWrite "HKLMSoftwareMicrosoftWindowsCurrentVersionexplorerBitBucketCNoRecycleFiles", &H00000001&, "REG_DWORD"
The Dword "NoRecycleFiles" and its value were created by the script. Not sure if this would suit your needs.
RFMaster
2014-06-25 23:49 »
Which OS is target?
2014-06-26 00:01 »
Win98
RFMaster
2014-06-26 00:20 »
Ok.
It's complicated on Win9x
i'll start to work on it tomorrow.
RFMaster
2014-06-27 06:16 »
This RegWrite f**cn shit do not support writing more then 4 bytes of binary data". "PurgeInfo" Key is 72 bytes of binary data.
^PROBLEMCHYLD, Is it necessary to be VBScript?
I can write a "normal" program for such purposes, if you want?
2014-06-27 21:36 »
I need it in VB Script if you can do it. It will be needed in the SP, one of the reasons I haven't released 3.34 yet. Its no rush, take your time.
