2013-07-27 00:38 »
I found this one on http://startisback.com Web site. These motherfuckers even use blurry pictures as a desktop background! Fucking sickos!
2013-07-27 14:37 »
2013-07-31 20:16 »
Fully blurred pictures are now the new normal on most Web sites. Bastards. Filthy, scumbags.
2013-08-02 00:43 »
What else to expect from those morons at Microsoft other than using fully blurry pictures.
2013-08-04 02:38 »
Another one here:
http://www.pcgamer.com/2013/08/03/intel ... on-the-go/
These are really obnoxious!
2013-08-04 11:36 »
Oh great, it is a feature in the Lumia 1020 according to Thurrott.
http://winsupersite.com/windows-phone/l ... nual-focus
What's different with the Lumia 1020 is that manually focusing on a particular object in a scene often creates a pleasant effect in which the object you focused on is perfectly clear while other objects in the scene are blurred out. This is called a bokeh effect, and while it can be abused, I've found myself using it a lot.
Here's an obvious example of how your choice of focus can impact a shot. In the first version of the shot, I've tapped to focus on the flowers in the foreground, so the background of the scene is blurred out.
In the second version, I focused instead on the background, so now the flowers in the front are blurry.
I didn't do this, but I could have taken a third short in which the focus was set to auto-or to "infinity" while the focus was in manual mode-and both the flowers and the background (i.e. the entire scene) would have been in focus.
Here's another perhaps too-artistic example.
It's never gonna end!
2013-08-07 00:33 »
2013-08-16 16:16 »
Another nice on from Neowin fools. Tiny AND blurry! LOL!
2013-08-16 22:52 »
Half the blur cases comes from camera lens and/or focusing choices. But yes the blur stuff is annoying...
2013-08-19 21:31 »
Here is another one. From marketwatch.com. Apparently the first picture they used was "too sharp" LOL which was this:
So they removed it and changed it to this one:
Damn idiots.
